Espritmodel.com Heli Air
Old Aug 05, 2012, 12:00 PM
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
Ldm,
Bethpage polo field is a top 10 venue to rly r/c from!!!! the polo field is large enough for the biggest models to fly from, perfectly groomed,the grass is cut to close to putting surface flat. behind the flight line is a group of shade trees that keep the area cool and comfortable, and the hosting club does a wonderful job of making all flyers feel welcome and at home... there are also many benches with tables to sit and share time and converse with fellow r/c nuts. they also serve fresly cooked food all day. don't miss this event, swing by our easy-ups, have a seat and enjoy some friendly low stress good times!! heres a video we shot from the nose of a Stryker with a hk videocam!!
whitman field Strykercam (5 min 48 sec)
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Aug 11, 2012, 01:47 AM
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Lipo Selection
Hi Guys
About to order the Skyraider but after a little bit of lipo info.
I've already got a 4S 4000MAH 40C (actually 2 x 2S 4000) which I presume it'll fly ok on.
But I've also already got a Turnigy 4S 3600 30C. Should it balance/fly ok with that as well?
I'm just after scale speed/performance.
Otherwise I'll order another lipo (whatever is recommended).
Cheers for any advice!!!
Dave
Goody63 is offline Find More Posts by Goody63
Old Aug 11, 2012, 06:05 AM
Ldm
Ldm's Avatar
Pa
Joined Jun 2006
Ifly , thank you very much for the info , I sincerly wanted to make the trip but elderly mom in need of a visit at the senior care facility . I have to make this my bucket list trip !!.
Looks like a great field and a great group of guys . Hope to make the next event and more then one plane !!!
Ldm is offline Find More Posts by Ldm
Old Aug 11, 2012, 06:30 AM
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by Goody63 View Post
Hi Guys
Dave
tape some quarters onto the battery to add the weight need to get the CG right.
or move the battery as far forward as possable and check your CG to make sure its right .
the only drawback with the lower amp battery is less flight time .
im running a 4000mah battery and im getting 4.5 min flight time with a few speed passes adding one min to land so im around 5 n half mins of fying . so im guessing your going to get a min less flight time.
the good thing about this plane is that you can fly it to a crawl ,i have flown it at 1/4 throttle and she putts around smoothly , so you can use the lower amp battery just to do slow fly byes.
THESANDMAN is offline Find More Posts by THESANDMAN
Latest blog entry: Rainbow f3a
Old Aug 11, 2012, 09:09 AM
Goody63's Avatar
Joined Apr 2008
Thanks for that advice. Just remembered ive got a couple of 2200 4S lipos that I could run in parallel too.
Cheers
Old Aug 11, 2012, 12:25 PM
iflyrc1012's Avatar
bklyn n.y.
on the other side of that i'm flying my Skyraider with 5000 mah 25c batteries and with them pushed as far towards the nose as possible, they balance this bird perfectly..i extended the battery tray to the firewall with a piece of balsa added some velcro for security, and she flys like a 60 sized low winged sport plane.....this plane has no bad habits at all. here's a video of my Sandy flying and landing. you can see she's not nose heavy in the least by the way she lands........
Warwick airport fly-in...Patrick's Skyraider (0 min 56 sec)
Old Aug 12, 2012, 01:29 AM
Goody63's Avatar
Joined Apr 2008
http://youtu.be/8imoHPkbYeQ
Very nice landing.
Putting bigger lipos in doesn't seem to be an issue!!
Cheers
Old Aug 12, 2012, 04:22 PM
iflyrc1012's Avatar
bklyn n.y.
my bud Sandman tried a 6 cell battery in his Skyraider today....i didn't go well..it flew for about 4 minutes, the stock motor smoked, left a nice smoke trail for about 100 yards!!! then Deadstick landing.....the plane will fly again, but the motor is kaput!!!
Old Aug 12, 2012, 06:52 PM
Goody63's Avatar
Joined Apr 2008
Ordered mine last night from the HK Oz warehouse.
Looking forward to getting it in the air!!
Old Aug 12, 2012, 07:28 PM
THESANDMAN's Avatar
Joined Oct 2010
As my club member stated do not use a 6cell battery the motor cannot handle the volts.unfortunely i wasnt able to make it to the runway i got as far as the gravel (ABOUT A FOOT AWAY)where it landing hard on the retracts bending one and breaking another,.the good thing was there was no damage at all to the plane itself .so i am out on motor and retracts .ive decided to go with a single prop so now i have to look for a motor,any recomendations will be greatly apriciated.
Old Aug 12, 2012, 08:27 PM
Too much power...nonsense
MNMadman's Avatar
Minneapolis Minnesnowtah
Joined Nov 2007
I went with an emp/turnigy 5065-380kv and have had great success with it, I have posted a video of mine with the stock prop earlier in this thread or it's on my blog. If you decide to stick with the stock motor and your prop adapter is still good pm me I have two stock motors but no adapters. Good luck getting her back together, this bird has become my favorite and I put over forty flights on her last week alone.
MNMadman is offline Find More Posts by MNMadman
Old Aug 12, 2012, 09:04 PM
THESANDMAN's Avatar
Joined Oct 2010
Originally Posted by mnmadman View Post
i went with an emp/turnigy 5065-380kv and have had great success with it, i have posted a video of mine with the stock prop earlier in this thread or it's on my blog. If you decide to stick with the stock motor and your prop adapter is still good pm me i have two stock motors but no adapters. Good luck getting her back together, this bird has become my favorite and i put over forty flights on her last week alone.
thanks for the info . I gave away the prop adapter and prop since i want to run a different motor . As for the plane she flies great no bad tendencies. Ive only been flying for a year n half and this plane makes me look like a pro , thanks to iflyrc who taught me alot
on a side note
whatsize prop are you using with the turnigy motor
Old Aug 13, 2012, 12:44 AM
MNMadman's Avatar
Joined Nov 2007
I'm using the stock four blade but I've tried a cut down 18x10 apc prop, cut to 15", and I've tried a 15x14 zinger wood prop. All 3 set-ups were on 6s and all three have similar climb rates but the two blade props were slightly faster which I found unnecessary as even with the stock prop the majority of my flight is at half throttle or less.
Old Aug 13, 2012, 01:39 AM
Australia, VIC, Melbourne
Joined Nov 2006
It is probably not the 'volts' it couldn't handle, but the total WATTS. (resultant of higher Amps the higher Volts cause).
Was this a 4S stock plane? Then a move to 6S is a lot more power, and would likely be more than required. eg if it was a bit slow on 4S, 5S should do. 6S would make a rocket! (if the motor could handle it).
Volts rarely kill motors, but the Amps do it. (within X cells of reason. ie 10S voltage level would then be in a region of killing it just via volts due to wire insulation breakdown - let alone the Amps that would also cause)
6S would likely work IF you changed to a much lower output prop. Lower pitch, or diameter (or both).
Thus reducing the power (Watts) output of it.
You might choose this manner if you had lots of 6S and no 5S. Otherwise, use 5S on the stock prop.
PeterVRC is online now Find More Posts by PeterVRC
Old Aug 13, 2012, 05:11 PM
iflyrc1012's Avatar
bklyn n.y.
Peter,
do you have a Skyraider?
MN,
i beat you to the prop adapter!! i have been looking to buy one, but nobody has had them in stock for months.... i am planning to throw this one on a lathe and make it flush all the way to the bottom,removing that bump so i can run the stock prop on one, and experiment with other props using the 2nd one that i am going to modify. i'm going to try a 16x8 3 bladed prop, a 16x8 apc electric prop, along with a few others also.
Discussion 1600mm Starmax P-51 Build Report (lots of pics) rgd1065 Electric Warbirds 3803 Today 01:33 AM
New Product Banana Hobby 1600mm Corsair and Skyraider Mikemynameis Electric Warbirds 0 Apr 25, 2011 07:16 PM
Discussion Anyone order 1400mm Starmax Cub from Hobbyshop Warehouse? highrailer Parkflyers 7 Mar 22, 2011 10:27 PM
Wanted Ziroli ad-1 Skyraider Low Show Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2011 04:06 PM
Poll Douglas Skyraider ARF 40-50" Fsk Eflite Parkzone Starmax Hobbylobby Great Planes BigTonE Scale Electric Planes 32 Sep 10, 2009 11:48 PM
