5 miles...
well you need a UHF signal TX/RX so Thomas, DragonLink, or EZUHF Now you need a very good setup for Video signal, so two very high gain antenna(15+dBi) plus an omni antenna for launch(2-3Dbi) Diversity setup for all three antennas plus antenna tracker for the high gain. Then you need a low-noise area to fly in to minimize interference. If all that works out right and your video camera is not noisy you can do this. Probably around $1000-$2000 in equipment when it's all said and done. Good luck. |
10 KM, EASY !!!
www.dragonlinklabs.com A long range UHF system is the only way to get RELIABLE RC control at long distances. There may be a couple isolated cases of 35 MHZ going far, but it is under ideal and special conditions, and the rare exception. Trying to fly more than 3 KM with a standard RC system is a very good way to crash or loose your plane. Average RC range is 3 KM or 1.5 miles for normal RC systems, and even less for 2.4 GHZ RC systems. Mike |
Idea | DX6i Hack to increase range? | StealthWorkx | FPV Talk | 10 | Dec 24, 2009 10:29 PM |
Discussion | how to increase range on stock micro citabria plane.? | raptorddd | Micro Ready-to-Fly | 1 | Dec 04, 2009 11:03 PM |
Discussion | Mounting antenna on a mast to increase range | SugarLandFlyer | FPV Talk | 14 | Oct 11, 2009 12:30 AM |
Discussion | DX6i increase range | Snaydher | Radios | 6 | Aug 25, 2009 09:06 AM |
Does flying near wire/metal fencing increase radio range? | RPatrick | Electric Plane Talk | 10 | Feb 02, 2002 09:08 PM |
