Old Oct 25, 2014, 02:52 PM
Joined Apr 2013
RC800...power drain when OFF...and where is latest firmware?
Hi guys,
Been looking around for a solution...
I just bought an RC800 FPV monitor. Overall pretty happy with it.
But...
Last night I left a 3S flight battery battery plugged in with the monitor turned OFF...woke up to a DEAD battery (charger says "low voltage" and won't charge it).
I have two problems:
1) "Auto power off" does not work...I suspect this is because the monitor is not recognizing that there is no signal after I turn off my transmitter...the monitor does NOT say "no signal", which seems to be a requirement for it to start the auto-power-off countdown, but that's just a guess.
2) Even with the monitor OFF, it'll drain a battery DEAD...I have seen references to someone attaching a power meter, and saw the same power drain whether the unit is OFF or ON...not good.
I have firmware version 1.2.11, and thru a lot of searching, found firmware version 1.2.13 here:
http://www.multiwiicopter.com/produc...-pvr-with-xt60
But I have no idea if this is the latest firmware, or if it will fix anything. I hesitate to do the upgrade without knowing.
So...
Anyone know of a firmware version that fixes this power issue and where to find it?
Thanks...
Bill
wsalopek is offline Find More Posts by wsalopek
Discussion Latest (V2 901 V3.3) FreeX firmware - HERE! faceplant FreeX SkyView Quad Copters 15 Nov 18, 2014 06:47 PM
Discussion Where do birds go when it rains? dll932 Life, The Universe, and Politics 18 Oct 17, 2014 01:21 PM
Help! 1 of 4 Motors Spins with much less resistance when powered off. MarylandFly Multirotor Electronics 0 Aug 02, 2014 11:34 AM
Question Why are my lipos draining when my plane is switched off RcjunkieAZ Batteries and Chargers 7 Jan 07, 2014 06:58 AM
Where to get latest CC firmware? hingus2000 Micro Helis 7 Mar 20, 2005 03:08 PM
