Old Mar 25, 2015, 12:10 PM
Joined Mar 2015
Build Log
Pilatus PC-6
Hi all. Had to have one of these. Set up so far, power110/castle ecs100A/BECpro20. Flight power rxbattery 2000lipo, & 8s 4000m. 7-HT hs5645mg. Hopefully near or better than unlimited above 7k. Stand off 44mm, with no washer on the firewall, 2mm backplate clearance. Tru turn Ultimate 3.5" custom cut lightened backplate w/12mm shaft, and 1-1/2" CNC Ultimate prop adaptor. You could go for the 160 but , it's an STOL, the 110 will be hard enough to CG.
Pic of the never cry wolf Pilatus
Piper down 7878 is offline Find More Posts by Piper down 7878
Old Mar 25, 2015, 12:22 PM
Joined Mar 2015
6" tundra
Nylon bushing on inner wheel, 6" air filled DOBRO. Grease filled, sealed rotation points.
Old Mar 25, 2015, 12:59 PM
United States, MN, Elk River
Joined Oct 2011
The landing gear looks sweet on that bird. Is that factory?
Bipesexual is offline Find More Posts by Bipesexual
Old Mar 25, 2015, 06:50 PM
Joined Mar 2015
It is , Bipe. wheels with the ARF are light, bit small for high grass. Added the 6" tundra wheels. The gear is fragile, hoping the big wheels will help.
Old Mar 25, 2015, 07:30 PM
Joined Mar 2015
Motor mount 44mm stand off
43mm stand offs, Giving 1mm washer space, 2mm back plate clearance. Each model may differ down to the mm.
A few avionics for the fuze. Tow hitch
If you mount the tail gear too low, there's a seem, screws having less bite. If you want higher tail gear, have the top Colette in the center of the mount, wire going up flush to the mount top.
Old Mar 28, 2015, 06:23 AM
Joined Mar 2015
looking at the stress points on the landing gear, like the idea of larger carbon fiber washer on the top of the shocks; posted in another thread I think it's ok though, STOL,s are kittens on the runway. All I added a was cushioned fuze washer here, same dia. As original
Old Mar 28, 2015, 08:18 AM
Joined Mar 2015
This model has some scale potential, more advanced than most ARF's, possibly fragile in a few places. finding tail gear assembly would help, for now ill use the stock.
Old Mar 28, 2015, 09:46 AM
Joined Mar 2015
possible solution for landing gear. Transfer stress back to the bulk head above the gear mount plate. A paper thin aluminum tube shaped as support strut. This was a quick mock up, may use the idea.
Old Mar 28, 2015, 11:16 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I think all I would do is install a 1/8 aircraft ply a couple of inches long centred under the steel cross brace and epoxied into the vertical former. That woulddistribute the load into the thick former and boost the brace strength, fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Mar 28, 2015, 07:38 PM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Nice flying plane, I'm reviewing that as we speak for Fly RC
barracudahockey is offline Find More Posts by barracudahockey
Old Mar 29, 2015, 08:28 AM
Joined Mar 2015
That's sounds great, I'll check it out so far I'm pretty impressed.
Old Mar 29, 2015, 08:34 AM
Joined Mar 2015
Good idea Doug, thanx. I'll mock one up.
Old Mar 29, 2015, 11:53 AM
Joined Mar 2015
1.5mm Carbon fiber stock, sides and top
Old Mar 29, 2015, 12:11 PM
Joined Mar 2015
More
Old Mar 29, 2015, 03:56 PM
Joined Mar 2015
Turnbuckle
Gear assembly
Build Log Pilatus PC-6 Porter 61rcpilot Scale Kit/Scratch Built 6 Dec 15, 2014 11:39 AM
Found Flitework Midi Pilatus PC-6 Hsestes Aircraft - Electric - Airplanes (FS/W) 1 Nov 22, 2014 10:28 PM
Build Log Pat Tritle Pilatus PC-6 Porter 60'' Build mstukel16 Scale Kit/Scratch Built 11 Nov 18, 2014 11:51 PM
Sold Flitework Midi Pilatus PC-6 mnahmia Aircraft - Electric - Airplanes (FS/W) 1 Oct 20, 2014 03:06 PM
