Old Mar 11, 2015, 12:21 PM
United States, GA, Savannah
Joined Jan 2013
Build Help Needed - F16 Fiberglass 90 MM Jet
I purchased this airframe recently and am trying to piece together a nice flying jet. I know you can easily spend $2,000 on a jet like this but trying outfit it decently without getting out of hand $ wise. I'm probably wanting to see 100 MPH - 125 MPH, maybe more.
F-16 Falcon Edf
90 MM fan size
Fiberglass Fuse
Balsa Covered Foam Core wings
Wingspan 940MM
Length 1470MM
Sold by Extreme Flight in Australia. You can see the jet on this page, the fuselage sells for $399.00 before components. http://tinyurl.com/o4y3r8j
I picked up some parts, some of which I'm not sure are a good fit.
Motor:
Medusa 36MM Motor MR-036-060-1500V2-5
HobbyWing Platinum Pro 150 Amp Opto No Bec 2-6s Lipo Optical Signal Trans usb supported
Midi Fan - looks used MD001-5 with metal cone and hardware
Servo Recommendations?
Tommy (TCAT has been helpful via Text) I thought I could get away with 6S since The Stinger 90 flies on 6 Cell but Tommy thinks it will be a dog and I tend to defer to him as he has way more experience than I do in building jets.
Medusa is out of business but I think the motor sold for $115 when new and its still new in the box. If I need to dump the motor and ESC, I will do so. Right now the ESC won't go above 6s.
Also on the retracts, they are good quality and new but not sure if they will work with the F16 as many retracts go onto the wings. On the F16 they are in the main fuselage.
Any help in the right direction would be very helpful. I already have some fiberglass jets on the build table as I have hit some road blocks and daily life keeps me from finishing them. I'd really like to get this bird built and fly it.
If anyone of you have components that would work, I would be open to that as well. I have alot of Castle Stuff and other quality stuff just sitting around that I would trade out for equal trade or trade and $.
Thanks in advance for your help.
bulldog2012 is offline Find More Posts by bulldog2012
Old Mar 13, 2015, 08:51 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
I believe this is a thread on your plane....should get all your questions answered.
http://www.rcgroups.com/forums/showthread.php?t=1238266
Madmax1965 is offline Find More Posts by Madmax1965
Old Mar 16, 2015, 01:21 PM
Joined Jan 2013
I owe you big time mad max. Thank you soo much.
Old Mar 16, 2015, 01:22 PM
Joined Jan 2013
Here is what I'm dealing with
Thanks! Appreciate it
Old Mar 16, 2015, 02:05 PM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
The 1500kv motor will not perform very strong on 6S with your Midi fan. Perhaps 8S?
For 6S I think 1800kv would be more suitable.
4stripes is online now Find More Posts by 4stripes
Sold Tam Jets 90 mm fan Pandissix Aircraft - Electric - Jets (FS/W) 0 Dec 13, 2014 11:06 AM
Discussion Best 80 or 90 mm plug n play jet ? jazzmanb Foamy EDFs 9 Nov 30, 2014 08:22 PM
Found help 90 mm fan unit needed adgnade Aircraft - Electric - Jets (FS/W) 2 Oct 05, 2014 06:47 PM
Wanted any jet-teng kit 90 mm or 1.7 m jtm viper jet konviser Aircraft - Electric - Jets (FS/W) 4 Oct 15, 2013 04:27 PM
