Old Feb 14, 2015, 10:06 AM
maguro's Avatar
United States, DE, Bear
Joined Apr 2007
FrSky Taranis for multicopters "How To"
This thread is specifically for all things Taranis as relates to multicopters. Want to find how to properly configure your Taranis for your Naza ask here. Got a great eepe for a multicopter, why not post it here? This is your thread. I hope you make use of it.
Roger
maguro is online now Find More Posts by maguro
Old Feb 14, 2015, 10:23 AM
United States, FL, Melbourne
Joined Jan 2010
Subscribed !
fltekdiver is online now Find More Posts by fltekdiver
Old Feb 14, 2015, 11:24 AM
Joined Jan 2010
Under Model set up, I have failsafe mode programmed to ( HOLD )
Is this correct? I'm using Naza M V2
Also I cannot register on open RC Fourms , says I'm blocked , and I was never even on it
The email address on the webpage isn't valid, any suggestions:
http://openrcforums.com/forum/index.php
Old Feb 14, 2015, 11:55 AM
Johninarky
Rogers,Arkansas
Joined Jul 2005
Thanks Maguro, I see more and more Taranis users on the miltirotor forums.
John
jlremr is offline Find More Posts by jlremr
Old Feb 14, 2015, 01:39 PM
United States, CA, Pleasanton
Joined Feb 2013
Many setups can be found here:
http://rcsettings.com/index.php/view.../6-multirotors
Noircogi is online now Find More Posts by Noircogi
Old Feb 14, 2015, 05:45 PM
United States, AZ, Tucson
Joined Dec 2011
Originally Posted by Noircogi View Post
Thanks for the link, just got my Taranis and was wondering where to look for examples and of course my first two aircraft were listed there so I grabbed them.
LarryCnAZ is offline Find More Posts by LarryCnAZ
Old Feb 15, 2015, 05:48 AM
Scotland
Cumbernauld's Avatar
Joined Nov 2008
As a newbie to quadcopters I would be interested in how the flight modes are setup using 2 switches and a separate 'panic' switch for RTL. My flight controller is an APM 2.5.
Cumbernauld is offline Find More Posts by Cumbernauld
Old Feb 15, 2015, 11:07 AM
Just call me CRASH
wild.bill's Avatar
Joined Oct 2014
For NAZA-M this is how I have my fail safe setup in Mixes
CH7 (mode) SG weight(+100%) (naza mode)
R SF Weight(+62%) Switch(SFdown) (failsafe)
I can't find the proper symbol but SFdown is SF in the down position,
and the +62% needs to be tweeked in NAZA assistant to make sure its correct for your controller.
Adding after reading more, in addition to having the failsafe switch I have the receiver (X8R) failsafe set to stop sending pulses so the NAZA failsafe can take over when it no longer can hear the TX.
wild.bill is online now Find More Posts by wild.bill
Old Feb 15, 2015, 08:13 PM
Free fall is not free
FunN4Lo's Avatar
United States, LA, Baton Rouge
Joined Aug 2014
I don't know what is there now, but 6 months ago the Naza ones I downloaded were horrible. One was designed in such a fashion the motors would not energize. Being new at the time, I had no clue how to overcome that.
The other drained my Taranis battery in about an hour. The vendor couldn't help me figure out what was wrong. I had an approval to return when I decided to delete the eepe and all was good again.
So... buyer beware.
FunN4Lo is online now Find More Posts by FunN4Lo
Old Feb 15, 2015, 08:54 PM
Joined Jan 2010
Thanks Wild.Bill
I had to do the same thing. I had to move the weights in the Naza Asst to get them to line up
Here's a Video I made yesterday on You Tube, showing all the switch functions with
Naza M V2 , using Amber Voice commands
Frsky Taranis Plus with Amber Voice Alerts for Multicopter , DJI F450 , DJI F550 , Tarot 680 Pro (2 min 5 sec)
Old Feb 15, 2015, 09:06 PM
Just call me CRASH
wild.bill's Avatar
Joined Oct 2014
Thanks Wild.Bill
https://www.youtube.com/watch?v=MlH34oXhqcI
Looking at the video you have yours set up the same as mine with all the same messages. The only difference is I use SG for mode and SE for IOC. I have this setup on a QAV400. I also have a Phantom and chose the switches to match the Phantom so I don't have to stop and think about which I am flying.
What receiver are you using and how did you set it up?
Old Feb 15, 2015, 09:15 PM
Joined Jan 2010
I'm using the X8R. I just got the package Friday with the receiver and carrying case from Aloft Hobbies
It took me longer to find the information then to program it. I watched Dennis Baldwins You Tube videos, and set it up pretty quickly using his videos
Then I spent a few hours trying to watch videos on how to load the voice files. In another thread here, they helped me quickly, and I was set up within a half hour once I knew how to do it
Since the video. I added Ambers voice to throttle up, once the throttle is raised more then 25% it's says " Take Off "
The voice commands is what leaned me towards this radio. It was the most Important feature for myself, lol
Old Feb 15, 2015, 09:54 PM
Just call me CRASH
wild.bill's Avatar
Joined Oct 2014
A little while back I was using a Spectrum DX6 and receiver so I had been through the process once on how to set it all up. I used the same video as you to figure out hot to setup the Taranis. The part that took me the longest was to figure out how to use the S-bus so I only and to hook up one servo cable between the receiver and the NAZA-M. My only problem now is that I have not been able to fly it since changing to the X8R because we have more than 60" of snow on the ground. I know that it works but can only move a few feet in any direction in the house.
Old Feb 15, 2015, 10:04 PM
Joined Jan 2010
Wow, I moved from using the Spektrum DX8, very similiar
Stinks about the weather. I tried my F450 out yesturday only in a hover,for a few minutes
It was to windy today, so I'll try later this week
If all goes well, I'll copy the settings over to create another model, and use the same settings on my Tarot 680 Pro
The F450 is for FPV
The Tarot is FPV and also carries a H3-3D gimbal with a gopro hero 4
I'm pretty happy so far programming the Taranis
I was expecting it to be harder, but a few hours here and their watching You Tube Videos and asking questions , and I was up and running
Old Feb 15, 2015, 10:11 PM
Australia, SA, Adelaide
Joined Aug 2012
Here's an example. Amber sound pack.
mpjf01 is online now Find More Posts by mpjf01
FAQ FRSKY Taranis "How to" Thread snipeworm Radios 16949 Today 08:31 PM
Discussion Radio Option for DLG -- FrSky Taranis mnowell129 Hand Launch 495 Mar 24, 2015 03:48 PM
Question Transmitter for model crane (Frsky taranis?) cheeta Radios 16 Dec 14, 2013 12:39 PM
Question When is the Frsky Taranis coming out and will it be sold out for 6 months? RC Aerobat Radios 13 Aug 10, 2013 11:27 PM
