Old Apr 07, 2014, 04:24 PM
FPV-disturbed
TheSwedishRatboy's Avatar
Sweden, Skåne County, Malmö
Joined Dec 2013
Mini-HowTo
Cheap NTSC/PAL Mini SD Card DVR on Ebay
I recently bought this of Ebay NTSC/PAL Mini SD Card DVR
The resolution is quite low, but for ground recording in case of a crash, i think that 40$ is an ok price, so i would recommend it if you don´t have any other ground recording. Like an insurance
However when i connected it the picture was way over exposed. Like many Ebay products it can be improved with just a little work, and in this case this can be fixed by soldering a 50 ohm resistor to the video in port. If you need a more thorough how-to guide, this can be found on my blog http://www.rccaptain.com/?page_id=221
For reference the video quality is as follows
VGA:
Resulotion - 640x480
Bitrate - 4332
FPS - 15
QVGA:
Resulotion - 320x240
Bitrate - 2348
FPS - 15
TheSwedishRatboy is offline Find More Posts by TheSwedishRatboy
Old Apr 08, 2014, 08:02 AM
Portugal
Joined Nov 2009
Does it remove blue screen when connected in-line?
HF_ATL is online now Find More Posts by HF_ATL
Old Apr 08, 2014, 09:23 AM
FPV-disturbed
Joined Dec 2013
Hmm...i don´t know, i havn´t had that problem on my unit.
Another possibility is to use an AV-amplifier and connect the DVR and screen in parallell,
but the DVR would still record way to bright, so you would still be helped by the resistor-fix.
Old Apr 08, 2014, 09:29 AM
Portugal
Joined Nov 2009
Thanks for the info.
Do you have with you any device that does bluescreen? If so, I'd appreciate if you can test if that device can remove it.
Old Apr 08, 2014, 01:23 PM
FPV-disturbed
Joined Dec 2013
I don´t think this mod will fix the bluescreen problem. The bluescreen is
because the screen used thinks the video signal is to weak (typically
when loosing signal due to being at the end of video range).
Perhaps someone knows if an AV-amplifier will fix or minimise the
bluescreen problem?
Old Apr 08, 2014, 03:10 PM
Beaumont ,peoples republic of Kalifornia
Joined Jan 2004
I found one 2channel for 70 bucks on ebay ......got it in 3days ,seller in california....
640x480 and D1.....
I have it hooked to the other vidieo out and use fatsharks.
I do know that every 5 minutes or so the video freezes for a second so using it as a pass through to fly with wont work....
Great for checking gear while flying LOS ...before commiting to googles
The monitor that I have it on is a $100 8" from hobby wireless that doesnt go blue
debogus is offline Find More Posts by debogus
Old Apr 08, 2014, 03:11 PM
FPV-disturbed
Joined Dec 2013
I just shot this indoor video to show what the quality is like on the recorded video. Actually i´m pleasently surprised.
When i tried it with my 808-keychain camera and 1,2ghz vtx/rx the quality was poor (i dont know why exactly,
but i´ll look into that) but now when i filmed with my cheap surveilzone camera and 5,8ghz vtx/rx the quality was
much better.
I think the video is alright actually!
(This video is taken in QVGA mode)
Cheap DV recorder test (0 min 42 sec)
Old Apr 08, 2014, 10:23 PM
FPVing for fun...
rcall's Avatar
Joined Jul 2003
does it record 640x480 @30fps?
rcall is offline Find More Posts by rcall
Old Apr 08, 2014, 11:15 PM
FPV-disturbed
Joined Dec 2013
Well, the settings are VGA or QVGA. How many fps, i don't know, but it looks ok.
I don't know why the footage is so muh better with my board camera then it is with my 808-keychain. It just is! I've tried different settings but i can't seem to fix the problem.
Old Apr 09, 2014, 07:20 AM
FPVing for fun...
rcall's Avatar
Joined Jul 2003
can you post an unedited VGA recording here?... just a few seconds is enough...
Old Apr 09, 2014, 07:36 AM
FPV-disturbed
Joined Dec 2013
Sure, the recording above is in QVGA, but i can post one in VGA as well.
Old Apr 09, 2014, 08:16 AM
FPVing for fun...
rcall's Avatar
Joined Jul 2003
attach the file here so we can check fps, bit rate, etc...
Old Apr 09, 2014, 03:51 PM
FPV-disturbed
Joined Dec 2013
Oh, i thought the QVGA was the better resolution, but i can see now on the file size it´s obviously not.
If i look at the properties for the files, my computer says
VGA:
Bitrate - 4332
FPS - 15
QVGA:
Bitrate - 2348
FPS - 15
Old Apr 11, 2014, 03:34 AM
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
Looks very nice I bought one similar from Foxtech
http://www.foxtechfpv.com/mini-d1-qu...sed-p-533.html
for nearly twice the price and a strange resolution and a strange video format (ASF) works pretty well though, but this looks like better resolution and a better price.
Heppy Ket is offline Find More Posts by Heppy Ket
Old Apr 11, 2014, 04:22 AM
mike_o's Avatar
Denmark, Capital Region of Denmark, Charlottenlund
Joined Jan 2012
Ratboy,
thanks for sharing! I noted the 1A power requirement, which does seem rather high. Did you measure the actual current draw?
thanks
PS: Will we ever meet over Oeresund?
mike_o is online now Find More Posts by mike_o
Sold FPV1000 DVR plus 16 GB SD card flyhighview FPV Equipment (FS/W) 0 Feb 04, 2014 09:07 AM
Sold New Mini DVR, Supports 32GB SD Card - $65 Shipped Sean C FPV Equipment (FS/W) 4 Aug 08, 2013 10:27 AM
Discussion Mini DVR Camera Video SD Card Recorder HD Motion Detect rimshotcopter FPV Talk 2 Apr 24, 2012 02:43 PM
Question 2 channels Mini DVR, Support SD Card, Can be connected to two cameras simultaneously, MikeTheCrash FPV Talk 90 Jun 13, 2011 04:10 AM
Discussion High Resolution Mini Sporting DVR Recorder with 4GB SD Card SC 2000 Product Announcements 0 Apr 22, 2011 02:03 AM
