Old Feb 18, 2014, 10:13 AM
United Kingdom, England, Peterborough
Joined Feb 2014
Battery suggestion for newbie
Hi
I have a 42" twin prop coast guard cutter which I want to use as a camera platform for a couple of video cameras. The boat has 2 x 550 torpedo (6v to15v) motors and 2 ESC's. Can anyone make a suggestion as to what batteries I should use to give enough time for filming several RC yacht races (approx 20 mins each race).
Any help would be appreciated.
Regards
Graham
laser173 is offline Find More Posts by laser173
Old Feb 18, 2014, 12:06 PM
Blackpool, Lancs
Joined Feb 2006
The usual answer for batteries is "as much as possible". It will want about 12 volts, and as many AH as possible for the run time. Current draw will depend on the props - the best way to figure this is to measure with the props in water. Once the current draw is known, you can make your choice of ESCs, probably from the Mtroniks or ACTion lists.
mfr02 is offline Find More Posts by mfr02
Old Feb 18, 2014, 04:22 PM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Li-po gives you the best bang for volume and weight, you can fit about 4 X the capacity in the same volume as a Sealed lead Acid (SLA) battery at about 1/2 the weight as well.
nick_75au is offline Find More Posts by nick_75au
Old Feb 24, 2014, 04:41 AM
Mike-A's Avatar
Sweden
Joined Oct 2002
Its a trade off. You can use a 3 stick lipo at 11 volts or a 2 stick at 7.4 if you use 3 stick you will have speed, if you use 2 you could have the same size battery but even double your running time. For your purposes you probably want duration. So you may seriously consider a 2 stick lipo.
Mike-A is offline Find More Posts by Mike-A
Discussion Prop/Battery Suggestions for 3D Hobbyshop 47" Extra 300 SHP APD Power Systems 3 Dec 27, 2013 02:22 PM
Discussion Radio and Battery suggestions for 54" Tugboat? 98 SNAKE EATER Scale Boats 24 Oct 20, 2013 11:20 PM
Discussion HELP- suggest a Radio for FPV for a newbie garik111 Radios 6 Dec 03, 2011 10:18 AM
Discussion HELP- suggest a Radio for FPV for a newbie garik111 Beginner Training Area (Aircraft-Electric) 4 Dec 01, 2011 09:59 PM
Discussion Battery Suggestions, Electric Newbie T_om Power Systems 7 Oct 18, 2009 09:17 PM
