Old Jun 17, 2014, 05:48 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
HobbyKing Boscam TR1 FPV All-In-One Camera
Well,
Hobbyking listed this camera that is being already sold in different stores - Boscam TR1.
Description: Name: 56990s1.jpg
Description: Name: 56990s2.jpg
Description:
Looks like an interesting product that will simplify the wiring for a beginner, but it is not something one might need on a more long range plane The application where I see it useful is Ground vehicles or multicopters to have fun around in your yard.
The features and specs looks good though, and the price is competitive, I would say, at only $80 mark it is cheaper than other stores.
Features:
  • HD recording
  • 32GB micro SD card support
  • 130 deg field of view lens (optimal for FPV)
  • 5.8Ghz Video transmiter built in
Specs:
Video sensor: 1/3 CMOS 5.0 Mega Pixel
Lens: 2.6mm 130deg
Exposure: Automatic
White Balance: Automatic
Video: 1440x1080 30FPS
Trans Flash: Micro SD up to 32GB high speed
Transmitting power: 200mw
Transmitting Frequency: 5645~5945Ghz (8ch)
Weight: 40g
Connector: SMA-RP
Power: Via the multi-function port @12v or 5v @ the USB port
schumixmd is offline Find More Posts by schumixmd
Old Jun 17, 2014, 07:00 AM
Per Ardua Ad Astra
Berkie's Avatar
Australia, VIC, Rosebud
Joined Feb 2007
So this is a much higher res. camera than the fatshark 600 tvl that comes with the fatshark attitude system, but does that mean you will see a better picture on the Attitude fatshark goggles?
Also, why do you think it may not be suited for long range?
I have ordered one.
Berkie is offline Find More Posts by Berkie
Old Jun 17, 2014, 07:05 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
Absolutely no. The higher resolution you see listed in the specs is for internal recorder (dvr). Actually the video that will be saved on SD card. Unfortunately they don't tell how many TVL lines have the live output that goes to transmitter. But I think it is not anyhow higher than 600 TVL.
What is good about this, that you can have fun with your car, for example, just by mounting this on the car, and you will have live video and also HD video recorded on card. No need to mount may components.
Old Jun 17, 2014, 07:34 AM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
I didn't think it would
The big advantage to me is that it is all in one because if you have a HD camera on board + Tx + camera = 3 items to be carried and connected.
And if you buy this + Fatshark base goggles instead of say, the Fatshark Attitude system it is $37 CHEAPER
Old Jun 17, 2014, 07:50 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
yeah, but bear in mind that this one does not use fatshark frequencies, so it will not work with fatsharks out of the box. Or you have to buy separate video module for fatshark in order be able to use boscam frequency, or you'll have to use and external receiver with your goggles.
Old Jun 17, 2014, 07:51 AM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
But why did they make it RP-SMA?
Going to need an adapter RPSMA/SMA
HK don't seem to have them
Do you know a supplier?
Old Jun 17, 2014, 07:57 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
almost every Chinese brand will use RP-SMA instead of SMA.
Unfortunately I can not recommend any cheap adapters except ReadyMadeRC
RP SMA Female to SMA Female Adapter
RP SMA Male to SMA Male Adapter
Old Jun 17, 2014, 08:01 AM
FPVGuerilla
United States, VA, Chester
Joined Jan 2012
Come on FATSHARK..where u at!
Markw177 is offline Find More Posts by Markw177
Old Jun 17, 2014, 08:02 AM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
Mmmmmmm. Thanks for the heads up. Didn't know that.
What would be the video module I would need?
Old Jun 17, 2014, 08:24 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
I know Simon have one module worth trying. Check this thread http://www.rcgroups.com/forums/showthread.php?t=2086365
Old Jun 17, 2014, 08:42 AM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
Thanks, but it seems to me the simplest (but more expensive) way to go is forget FS and go Boscam goggles + TR1
Besides, I hear Boscam goggles are better than FS
Old Jun 17, 2014, 09:05 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
considering the trend of using different style of goggle like Quanum http://www.rcgroups.com/forums/showthread.php?t=2184050) I bet fatshark will lose a lot of room.
Old Jun 17, 2014, 10:29 AM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Interesting
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Jun 19, 2014, 02:32 AM
Joined Aug 2011
Power supply
I can't work out whether or not we need to hack into the USB cable for the power supply to the unit. Anyone knows?
Emparri is offline Find More Posts by Emparri
Old Jun 19, 2014, 02:34 AM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
i opened a thread about this camera, have many questions how it's working, but no answers yet....
http://www.rcgroups.com/forums/showthread.php?t=2179777
deno6031 is offline Find More Posts by deno6031
Discussion Boscam tr1/ Rctimer imago aio camera discussion deno6031 FPV Equipment 6 Sep 27, 2014 08:06 AM
New Product Micro FPV All-In-One Solution Z06 Tony Mini Multirotors 4 Dec 02, 2013 09:55 PM
Discussion New All-in-one IDEA FLY Brushless Camera Gimbal will be available soon Quadcopter MQ80 Multirotor Talk 4 Oct 29, 2013 12:05 PM
Sold All-In-One Foxtech BOSCAM Goggle fabianabegglen Aircraft - Electric - Multirotor (FS/W) 4 Jul 16, 2013 06:57 AM
Sold All in one - GoPro + FPV Camera Pan & Tilt (Version 2) crd FPV Equipment (FS/W) 9 Jun 09, 2013 06:38 PM
