Old Apr 27, 2015, 02:02 PM
Brian Koester is offline
Find More Posts by Brian Koester
Blue Stick's Dad
Brian Koester's Avatar
Westchester, Ca
Joined May 2003
Controlling a hovercraft without a rudder
I bought this 1978 free flight hovercraft on ebay. I'm going to convert old 049 engine to 300 class motor and make it free flight again. But then I started thinking that the fake engine pods could house real motors and maybe be used for steering. I found a 28mm EDF motor/fan that would fit perfectly in them from eflite. So I know I can fit all three motors in the hovercraft. The thing is I have no experience with setting up a receiver to control three motors. One motor on throttle to control altitude and two motors set up on rudder or aileron to control steering by turning on only one of the two motors. It would be a slow turn maybe but at least it would be something and it wouldn't require any noticeable mods to the exterior. BTW I'm knowingly passing on mounting a prop with rudder behind like a swamp boat because again that would ruin the look. Quad copters do this multi-motor thing so I was wondering if my problem is easy or hard to solve?
Brian Koester is offline Find More Posts by Brian Koester
Old Apr 27, 2015, 02:45 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
What you're talking about is steering with "differential thrust" and it's been used quite a bit in all sorts of craft including hovercraft (that's how the little AeroAce toy planes steer).
It's easy enough to do if your transmitter has the mixing capabilities required. Most modern TXs with 6 or more channels can probably manage it. Not that you need all the channels, it's just that TXs with less channels usually have no controllable mixes. You want mixing so that you can control the forward speed as well as the direction.
Steve
slipstick is offline Find More Posts by slipstick
Old May 05, 2015, 12:44 PM
Rusty Mustard is offline
Find More Posts by Rusty Mustard
Die DX8, DIE!
Rusty Mustard's Avatar
Joined Feb 2013
What tx do you have? Plug it into google with the term 'differential thrust' and you'll find out how to mix it.
Differential thrust works great, and you don't need much if the nozzles are spaced wide enough.
Go for it!
Rusty Mustard is offline Find More Posts by Rusty Mustard
Old May 05, 2015, 02:18 PM
FiftySlicks is offline
Find More Posts by FiftySlicks
United Kingdom, Scotland, Edinburgh
Joined Jun 2014
If you're stuck with a very basic tx that doesn't offer mixing, you can get differential thrust using a V-tail mixer and two normal channels (throttle and direction). There's a few quirks to using one of those but it does work.
FiftySlicks is offline Find More Posts by FiftySlicks
Old May 05, 2015, 07:08 PM
Die DX8, DIE!
Joined Feb 2013
Or, if you're stuck without a mixing radio or v tail mixer, put the left edf on the throttle channel and the right one on the aileron stick, you can then use both sticks, push both up and let off on one to turn that way, like driving a hover-tank, hehe!
Old May 08, 2015, 07:51 PM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
I have a Multiplex Royal Evo 12 so I can do any kind of mixing I want.
Old May 08, 2015, 07:55 PM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
So I've ordered parts and I have them all in and I've started construction of the modifications. Turns out that a 28mm fan fits perfectly inside the engine nacelles so I ordered two eFlite EDF fans and motors. These will make it go forward and turn. I bought a 1000k/v 400 motor to lift it off the ground.
Old May 08, 2015, 10:52 PM
windnsea is offline
Find More Posts by windnsea
Australia, VIC, Bass
Joined Jan 2013
Looks like a fun project. I remember having this model years ago and was fascinated how well it hovered without a skirt, especially when i removed the dummy engines to save weight.
Be interesting to see how well it works with the mods you are doing - i bet you will end up modifying the hull as well to improve lift as its not a very efficient design -but looks great anyway.
windnsea is offline Find More Posts by windnsea
Old May 09, 2015, 11:39 AM
Die DX8, DIE!
Joined Feb 2013
Cool! Keep it coming!
Old Jun 09, 2015, 08:06 PM
mokermeister is online now
Find More Posts by mokermeister
United States, NH, Fitzwilliam
Joined Jan 2014
Great model to have for it!!
mokermeister is online now Find More Posts by mokermeister
Old Jun 10, 2015, 01:30 AM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
I'm on my third motor. First one not strong enough. The second overheated. Hope the third is the right one.
Help! Flying the Super Sky Surfer 2000 without rudder control the man Foamies (Kits) 0 Feb 06, 2014 01:42 PM
Discussion can we fly heli without rudder control? sam1741 Electric Heli Talk 7 Oct 31, 2011 03:23 AM
Discussion GWS Spitfire without rudder control zetland76 Electric Warbirds 6 Feb 26, 2008 08:10 PM
Discussion Slowflyer RC Control without any rudder flattermann Electric Plane Talk 2 Dec 27, 2006 12:23 PM
airplane without elevator and rudder control therealdreamer81 Electric Plane Talk 3 Sep 24, 2004 05:37 PM
