Old Feb 05, 2016, 12:46 PM
MariusPrinsloo is offline
Find More Posts by MariusPrinsloo
South Africa
Joined May 2009
Yip , the rear wing fixing are just like you say .
This will be my first edf and I can't wait to get some air over those wings !
Thank you so much for all the help
MariusPrinsloo is offline Find More Posts by MariusPrinsloo
Old Feb 05, 2016, 03:45 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
The wing fixing is OK till fuselage flexes and then the pins come out of the holes. This is good that it avoids damaging structure but needs just a little addition to be secure in stressed flight. I put a run of tape along that joint. The plastic guide pins slot into - make sure that is well glued in place.
The nose cone - fill with expanding foam and then hollow out to allow nose wheel mechanism to work. The plastic cone is fragile and splinters on a bad landing.
Personally - I removed the wheels and hand launched / belly landed. That's worth maybe another minute flight or 5mph ...
If you want help on setting her for bungee launching - then pm me.
Nigel
solentlife is online now Find More Posts by solentlife
Old Feb 06, 2016, 12:33 PM
solentlife's Avatar
Joined Jan 2010
Hope the attached helps ....
CoG and settings for surfaces.
If you need a scanned copy of the Lanyu manual ... let me know via PM.
Nigel
Old Feb 09, 2016, 01:43 PM
South Africa
Joined May 2009
Thank you very much! Apologies for the late reply
Old Feb 12, 2016, 10:27 AM
ianicolo is offline
Find More Posts by ianicolo
Joined Sep 2012
I made a model of the T45 nose cone for 3d printing. You can download the stl model here:
http://www.thingiverse.com/thing:1336754
The model has a hickness of 1 mm so it can be a little fragile. I glued internally some foam pieces to strenght the nose cone.
ianicolo is offline Find More Posts by ianicolo
Old Feb 15, 2016, 04:05 PM
gator is offline
Find More Posts by gator
Gator's here to see you:)
gator's Avatar
United States, FL, Sarasota
Joined Sep 2002
Make a simple cheap mold
......Or you could simply make a few basic casts of the nose out of plaster of Paris before killing the original irreplaceable flimsy nose and make any number of light weight duplicates. I cast 4 from the nose cone of my new T-45 kit using one $6 box of plaster of paris from Lowes.
Brush a good layer of Dawn into the nose for a release agent, stand it upright in a red solo cup to hold it up, mix up enough plaster ( just a little on the runny side) to fill the nose piece about 1/16" from the lip, fill quickly and wait an hour.
Remove your new PP cast from nose piece mold, fill any voids on the outside of it with drywall mud or spackling, sand the cast to a smooth finish, wax it heavily, brush on some 2 part epoxy and lightly layer with cloth. Wait overnight, Remove your new fiberglass inverted nose mold cast and (A) Wax it heavily and fill with spray foam, remove and core it out, paint it and bash away knowing the identical replacement is easily reproduced.
OR (B) heavily wax your cool new inverted fiberglass mold and lightly brush with epoxy and layer with light cloth, wait overnight, remove your awesome new nose piece, finish and bash away knowing the replacement is easily reproduced.
Here's all the stuff, except the epoxy and cloth or foam. Good luck, Mike
gator is offline Find More Posts by gator
Old Feb 15, 2016, 10:28 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
That is a very good idea!!
Make molds at least, right away...... if not spare nose cones too.
Though in my case, its crash destroyed the entire T-45 so having spare nose cones would be no use.... LOL
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 16, 2016, 09:04 AM
gator is offline
gator's Avatar
Joined Sep 2002
WOW! Hey, quite an impressive pile of what looks like a really nice setup. Balsa tails, 4s, batt tray. Bummer. No amount of creative molds will fix that. Looks like your intent was to try and drill down to the U.S.
I just started on the kit last night and began by grinding out the motor mount to fit a 70mm EDF that I intend to fly it on 4s. My previous jets have been so high strung that I was looking for a nice cruiser to possibly adapt to FPV or just cruise around. My intent is NOT to drill to OZ..... but gravity often has it's way.
I haven't read all 370ish pages of this thread but maybe you, or anyone, could just summarize a few main tips from their experience with the T-45 prior to the day of infamy.... Your preferred CG, throws, batt size, most useful mods, quirks, etc. Thanks for any info (from anybody).
I also noticed that there seems to be a plastic shield to form over the intake ports that I didn't get in my kit. Is that a deal breaker that I should try and find or just tape or glass 'em? This whole plane seems exceptionally frail.
Hey, I'd send you a new nose piece with a drill attached but I'm afraid it just wouldn't be enough.
EDIT: read through all 5pgs of attachments which was helpful. Plenty in there. Found a nice set up summary on pg 106 post# 1578. A few things that seemed like good build tweaks at 1st glance w/o going crazy:
(a)stow RX and batt inside fuse and ditch orig batt box
(b)add secure but removable battery tray with access from removable cockpit w addl cockpit retention mods
(c) 4s 2200 50c batt w 6 blade 70mm EDF and 50a ESC
(d)reinforced tape or carbon rods in tails and wings (OR)
(e) Cover tails and ailerons w "New Stuff" film, or replace w balsa, or at least tape leading edges
(f) MG servos and stiffer rods/clevis' w attn to rod/clevis closure
(g) CG 90mm (fwd limit). 100mm (good for maiden or trainer flights). 110mm ( perfect). 120mm (aft limit where it gets really “snappy” close to the stall).
(f) lightly fiberglass the inside of the nose cone for durability then fill w foam AFTER making a few replacement molds that are easily shaped to a more scale size
(g) hand or catapult launch this plane to keep it simple/clean/light
(h) tweak/clean n sand the foam "nubs" off the whole plane especially the exhaust, line w mylar film or thin water bottle liner, clean n sand intake tubes, and add a cheater hole under wing near frt of fan
(h-2) Add reinforced packing tape to frt and rear wing>fuse joint and main wing leading edge.
(I) add PnT FPV cockpit cam like post #4144 on pg 277
(J) do a range check, proper pre-flt ck and go fly
Old Feb 16, 2016, 03:51 PM
PeterVRC is offline
Joined Nov 2006
The plastic intake bits are just to give those foam edges some more support/protection. It wouldn't really matter to not have them, and you are unlikely to damage them in transport/storage. They won't collapse due to intake suction either.
Old Feb 26, 2016, 05:46 AM
samson2001 is offline
Find More Posts by samson2001
United Kingdom, England, Stafford
Joined Dec 2014
Just looking at replacing my broken 64mm stringer with this and you've just saved me 300 pages of searching for info I needed thanks Gator brill summary Think if I go with this shell I'll stick with my 64mm I've already got though me thinks.
samson2001 is offline Find More Posts by samson2001
Old Feb 26, 2016, 10:33 AM
gator is offline
gator's Avatar
Joined Sep 2002
Sam, Glad it helped. It was kinda OCD but I read the whole thread and was looking for something that summarized over 5500 posts but couldn't find it, much less remember the highlights so I tried to do it up there. The easiest way to cull the noteworthy bits was to eventually review just the attachments (only 5 pgs) and dive in from there. Tons of good stuff shared in there.
Here's my T-45 just finished last night and ready to fly in the next few days when we get a calm day. I applied almost all the mods I had listed a few posts back. Other than that the decals weren't sticky enough, there might have been a mold release agent on the foam, so I misted them with 3M77.
I'll post a flight report, even though there are others buried in the thread. Cya, Mike
Old Mar 20, 2016, 08:41 AM
falcon01 is offline
Find More Posts by falcon01
Joined Feb 2013
I gave the CAD file to another guy in our club that has a 3d printer and he is having difficulties with it. He said the file seemed to be corrupted, any tips I can forward to him?
falcon01 is offline Find More Posts by falcon01
Old Apr 21, 2016, 06:15 PM
RDowson is offline
Find More Posts by RDowson
Joined Nov 2014
Just got mine yesterday.
Couple of questions:
- How does it fit a normal size 2200mah 3s lipo? The battery door and compartment is small. Does it require some modification?
- Mine came with the ESC in the box and not connected. All three wires are the same colour. What connects to what on the motor?
RDowson is offline Find More Posts by RDowson
Old Apr 21, 2016, 06:32 PM
Gene is offline
Find More Posts by Gene
United States, CA, Anaheim
Joined Aug 1999
I chose to make the canopy removable and put the battery pack inside the canopy. The only way you can tell which wires on the ESC attach to which wires on the motor when the three ESC colors are the same color is to hook it up to the motor and fan unit before it's installed and then run the motor up at a slow speed to see which way the wind blows. In a case like this, I do the testing then apply colored electrical tape the the ESC wires for later reference. Keep the motor speed SLOW for safety reasons.
Gene is offline Find More Posts by Gene
Old Apr 22, 2016, 01:42 AM
solentlife's Avatar
Joined Jan 2010
I use different colour heat shrink tube on the lead ends.
Nigel
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
