Old Jul 18, 2015, 06:46 PM
NJKEV is offline
Find More Posts by NJKEV
Joined Jun 2015
Help!
Sky Zone Goggles - 2.8 or 3.6 Camera
Hi, I want to order a camera to hook up with my SZ 3D goggles, don't want to use the 3D camera yet, will save it after I learn how to fly.
My question is, 2 different sights, the default camera lens has 2.8 another uses 3.6.
Does anyone know, with the SkyZone 3D goggles, yes, I'm just talking about the goggles (fpv) does it matter, or make difference which MM lense I use? Will one work better then the other or what is the actual "default" for the skyzones?
Thanks so much for any help, I've been trying to find out an answer for the past 4 hours, should of come here first :/
NJKEV is offline Find More Posts by NJKEV
Old Jul 18, 2015, 06:57 PM
aerojunkie is offline
Find More Posts by aerojunkie
United States, NC, Kannapolis
Joined Jul 2012
To my knowledge the lens size is just a preference thing, it depends on if you want a larger field of view but some distortion. Or a narrow field of view thats clear. This is what I have with a 2.8 lens and it works great with my skyzone 3ds.
http://www.surveilzone.com/sony-960h...-camera-cc1526
aerojunkie is offline Find More Posts by aerojunkie
Old Jul 18, 2015, 07:04 PM
Joined Jul 2012
I would suggest buying the other size lenses for that camera, they are cheap and gives you the option to try them all.
Old Jul 18, 2015, 08:14 PM
NJKEV is offline
Joined Jun 2015
http://www.securitycamera2000.com/pr...C-%252dUS.html
Something like this one? 20.US Dollars
Old Jul 18, 2015, 09:13 PM
Joined Jul 2012
That one looks good but to be honest I dont know anything about it. There is a 600tvl camera that is basically the gold standard for fpv, the pz0420 or the surveilzone 1333. I believe this is the plastic cased version. I would get a case, only a few dollars and now the lens is not mounted directly on the board but screws into the case. If the camera hits something lens first its less likely to drive the lens through the circuit board and break it.
http://www.securitycamera2000.com/pr...-%252d-US.html
Old Jul 20, 2015, 07:22 AM
John Snow is offline
Find More Posts by John Snow
Joined Aug 2014
If you want plastic case version, choose HS1163, http://www.surveilzone.com/plastic-c...-camera-hs1163
John Snow is offline Find More Posts by John Snow
Wanted Explorer 2 wing 3.5 or 3.8 meters Dimman22 Aircraft - Sailplanes (FS/W) 4 Jun 30, 2015 06:09 AM
For Sale Sky zone goggle with original box bnn1044 FPV Equipment (FS/W) 3 May 04, 2015 05:37 AM
Discussion 2.8 or 3.6 lens for FPV camera? GBR2 FPV Equipment 36 Sep 05, 2014 12:55 PM
Wanted 1.2 or 1.3 module to replace 5.8 in Attitude v2 goggles?? wootenelli FPV Equipment (FS/W) 4 May 30, 2014 08:10 AM
Wanted WTT: My 3.6 for your 2.8 camera lens turbodriven FPV Equipment (FS/W) 5 Aug 03, 2012 11:04 AM
