Old Jun 18, 2015, 08:39 AM
BHChieftain is offline
Find More Posts by BHChieftain
Joined Apr 2010
Venders
Hi,
I'm looking for some good US vendors for parts. Right now I'm looking for a throttle cable for my G1 mono.
Chief
BHChieftain is offline Find More Posts by BHChieftain
Old Jun 20, 2015, 03:59 PM
Xfactor940 is offline
Find More Posts by Xfactor940
United States, NC, Durham
Joined Apr 2011
Exactly what kind of parts are you looking for? Is this an insane mono?
Xfactor940 is offline Find More Posts by Xfactor940
Reply With Quote  (Disabled)
Old Jun 21, 2015, 09:21 AM
Joined Apr 2010
It is a Y6 racing hull for G1 NAMBA class. Looking for misc parts line throttle cables, pipe mounts, radio box parts, flexshafts, collets, zenoah spare parts
I saw insane has some parts but looked pretty limited.
Chief
Old Jun 21, 2015, 09:55 AM
Joined Apr 2011
did you check zippkits or aeromarine? hate to say it but ebay isnt the worst place to go.
Old Jun 21, 2015, 03:03 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Boaters rarely use throttle cable setups anymore. Most use 2-56 or 4-40 threaded rod.
www.zippkits.com sells just about everything on your list except for Zenoah parts.
Try www.gizmomotors.com for Zen engines and parts, probably the best prices on them.
Ron Olson is offline Find More Posts by Ron Olson
Old Jun 21, 2015, 08:27 PM
Joined Apr 2010
Thanks.
My current boat has threaded rods, but I have a 90 degree linkage routing so there are way too many screws/pivots to fail (took me out of 1 heat already...)
Much prefer a continuous link from the servo to the throttle.
Chief
Old Jun 21, 2015, 09:05 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Maybe something like this then? This isolator rotates the carb for a straighter shot.
http://zippkits.com/~zippkits/index....roducts_id=533
Old Jun 22, 2015, 08:05 AM
Strictlybusiness is offline
Find More Posts by Strictlybusiness
Strictlybusiness's Avatar
United States, NC, Graham
Joined May 2015
I use braided flexible cables or small diameter spring steel rods for direct linkage between the throttle arm & the throttle servo. Braided cables can easily be bent 180*, if the radius is large enough by using supports such as those shown. They have very low friction & can have their cable housing ends effectively sealed with heat shrink tubing. Heat shrink tubing is also used on solid rod type linkages. The size of solid spring steel rods that could be used is determined by the flexibility needed & their housings are also supported. Lubriplate #2 Marine grease is injected in both housing types with a small diameter syringe in the initial set up & remains there through out the life of the boat. All carburetor types have positive mechanical stops for full wide open & full closed positions.
Jim Allen
Strictlybusiness is offline Find More Posts by Strictlybusiness
Old Jun 22, 2015, 11:10 PM
darwindingo is offline
Find More Posts by darwindingo
darwindingo's Avatar
Australia, NT, Darwin
Joined May 2015
Jim,
I really like the heat shrink sealing idea..!
Jeff
darwindingo is offline Find More Posts by darwindingo
Old Jun 23, 2015, 03:41 PM
Expresscraft is offline
Find More Posts by Expresscraft
cocoa, Fla
Joined Jul 2009
zippkits has been fantastic and they support r/c groups as well.
Expresscraft is offline Find More Posts by Expresscraft
Old Jun 23, 2015, 06:42 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
I used some Sullivan cable on a RE RCMK JAE gas 'rigger but used antenna tube to dress it up some I greased the cable to help prevent water from coming in.
Question Which Boat Venders will be at Weak Signals in Toledo 2015 George Jure Dock Talk 5 Mar 24, 2015 09:36 AM
Discussion Venders on flight line what do you think ? Happymcc SEFF 2014 43 May 24, 2014 01:31 AM
NiCad venders Michael Hall Batteries and Chargers 3 Jun 21, 2004 01:29 PM
Question Venders that sell ARF foam kits Mac8 Foamies (Kits) 4 Jan 28, 2004 02:20 PM
