Old Jul 09, 2015, 01:28 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Originally Posted by TNug View Post
For fun, I did an advanced search in this thread for "glue" and username Daemon. It turned up 3 pages of results. LOL. I could have saved myself some typing.
Deamon has said repeatedly that CA will make a chemical bond with EPO. Spray one part with kicker, let it evaporate, apply CA to other side and join. After trying it it works well.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Jul 17, 2015, 05:43 PM
hofftari is offline
Find More Posts by hofftari
Sweden, Stockholms lšn, Solna
Joined Jul 2015
I'm wondering about the hinge mods people speak about on blogs/videos etc. How come eveyone is using these round hinges? What's making everyone pick them instead of good old flat hinges?
hofftari is offline Find More Posts by hofftari
Old Jul 17, 2015, 05:45 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
United States, AK, Anchorage
Joined Jan 2010
Not sure of the answer to that? I use the flat hinge style myself.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Jul 18, 2015, 08:19 AM
Forced_Inducti is offline
Find More Posts by Forced_Inducti
Joined Dec 2008
I used packing tape. Easy and cheap and no need to wait for glue to dry!
Forced_Inducti is offline Find More Posts by Forced_Inducti
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
Me too. Flat is easier.
metalbender4by is offline Find More Posts by metalbender4by
Old Jul 18, 2015, 10:32 AM
Quebec, Canada
Joined Sep 2006
I use blenderm tape.
Old Jul 18, 2015, 05:14 PM
Dr. |2udie is online now
Find More Posts by Dr. |2udie
Lower Blue Mountains, Australia
Joined Jan 2006
I need to replace my old 1680 so I'm thinking of getting the 2015 1680 1720mm model. My concern is that the canopy/pod no longer has a flat surface for mounting a gimbal (see pics below).
Does anyone still sell the flat foam mount? I think it previously came with a clear plastic windscreen?
Or what's the alternative these days??
Dr. |2udie is online now Find More Posts by Dr. |2udie
Old Jul 19, 2015, 10:35 AM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nśrum
Joined Jan 2012
My SW 1680/1720 Revolution has the foam canopy in two pieces, where the lower part has a large, flat surface for mounting FPV stuff. It has a sligth (3-5 degrees) forward slant, which I had to take into consideration when mounting my camera.
mike_o is online now Find More Posts by mike_o
Old Jul 21, 2015, 01:18 PM
Joined Dec 2008
my 2015 1720 came with a 1 piece canopy. it had a sm,all amount cut out of it on a 30deg angle or so at the top, but not much use. I bought the plywood canopy for $8. fits perfectly.
Old Jul 21, 2015, 01:30 PM
Joined Dec 2008
if anyones interested, heres a good way to add landing gear.
http://www.rcgroups.com/forums/showt...9#post32214559
Old Jul 21, 2015, 03:47 PM
hofftari is offline
Joined Jul 2015
I've gotten an issue while building my Skywalker that perhaps you guys could help me with.
The Control horns are impossible to center over the hinge line since the "gap" between the control surface and the main part is too wide. I've tried finding a store online that sells control horns that extend further towards the hinge line but without any results.
How did you solve this? Pics showing your control horns are most welcome!
Old Jul 21, 2015, 11:42 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The control horns don't need to be centered over the hinge line.
Letting them run a bit behind the line will give you some mechanical differential (more up
throw than down), which this plane needs anyway.
The only thing I recommend replacing is the pushrods and clevises. I usually
just run standard 2-56 rods with a Z-bend at the servo arm end, and clevis
at the control horn end.
Daemon is offline Find More Posts by Daemon
Old Jul 22, 2015, 09:24 AM
hofftari is offline
Joined Jul 2015
That's all fine for the aileron, but what about the rudder? I came up with this idea that if I let the servo arm have the same angle in neutral position as the angle between the hinge line and the mounting hole for the linkage, then the offset will be compensated. I feel like this should work, am I correct?
Also, I run 1mm linkages and I plan to use linkage stoppers. Are they really that worse off compared to clevises?
Old Jul 22, 2015, 09:37 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, if you make the servo arm parallel to the line between hinge and hole in the control
horn, you'll get equal throws. I've seen linkage stoppers loosen up and slide. Not a big deal for
the rudder, but wouldn't trust the elevator or ailerons to em.
Old Jul 22, 2015, 09:59 AM
hofftari is offline
Joined Jul 2015
Thanks. I'll go with linkage stoppers for the maiden flight and put an order for some clevises for the future
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
