It's not quite clear, yet...Are you replacing a metal dihedral joiner with wood?
Maybe a picture would help. If it's a metal joiner, it should remain there. Usually the wing is designed to work together, with the joiner and sockets.. |
Latest blog entry: The 'Ancient Modeler"
If the round joiner is a straight piece of tubing, the dihedral is built into the first few wing ribs.....This would require a wood joiner be built with reverse angles, to reduce the dihedral.
That COULD be done with plywood center pieces, filled out with balsa, to keep the weight down. It would be an unorthodox solution, without cutting into the wing to relocate the tubing receivers. Still would like pictures. |
Now that we can see your problem, the dihedral can be removed most easily by cutting loose the tubes already installed in the wing. This is also the strongest way.
Some work is required of course, and some recovering. You'd have to cut loose all the glued areas retaining the wing tubes, readjust the wing to the desired dihedral angle, the epoxy well. Before any gluing, the wing must be blocked to the correct angles,being careful no warps are built in as the regluing is done. As Mr. Matthews suggests, with out ailerons, you're wasting your time. |
Joined Jun 2012
The plane has ailerons it is a hobbico supper star 40 I am recovering the whole plane and taking care of the wing damage the metal wing Joiner is bent and I figured this would be the time to make any changes I was thinking it wouldn't be a big deal since I'm gonna have it tour apart...
The Hobbystar is best set up as a ruggedized model to withstand anything that you may do to it. As such the ONLY way that makes sense from a cost and strength view is to simply replace the metal rod with a same size piece of music wire from the local hobby shop.
It's quite possible that the previous owner bent the rod by accident during a hard pullout from a dive rather than on purpose. It's hard to say without seeing how springy the original rod is. But with cost cutting it's not hard to believe that the joiner rod might well not have been correctly hardened and tempered to the proper spring temper. Also that rod has to withstand a very high bending load. A solid carbon replacement might do the trick but I would not slip in any old tube from the rack that happens to fit. A thin wall carbon tube would not be strong enough. So your best bet is still to measure the diameter of the rod and buy a 3 foot length of the same size music wire. You'll need something like an angle grinder and a cut off disc to cut it as the music wire is tough stuff. Do NOT use any old regular hardware store steel as that is mild steel and will most certainly bend on the first hard pullout and likely result in you crashing the model. It MUST BE the spring tempered music wire. Basically if you can bend it by hand then it's simply not the right stuff. |
Why don't you just try taking the angle out of the bar? The wing rod is hardened but can be straightened. A vice-grip or large plier to hold the bar end, a hammers, and a block of thick wood like a 2x4 or 2x6. Hold the bar securely —if it flies loose it can damage something or someone— with the bend up on the wood. Hit the angle until it is straight.
Note that the SuperStar .40 is supposed to have some dihedral. The manual says with one wing flat on a surface, the other wingtip should be 3¼ to 4¼ off the surface. |
| Thread Tools | |
| Help! optimum carbon tube spar for undercambered wing | Arnold E | Foamies (Scratchbuilt) | 6 | Feb 13, 2013 07:18 PM |
| Sold Misc Buck Huck parts- Wheel pants, wing spar... | RickBee | Aircraft - General - Miscellaneous (FS/W) | 1 | Feb 05, 2013 04:23 AM |
| Discussion Spar location for bagged wings | bbbp | Hand Launch | 11 | Jan 16, 2013 08:28 AM |
| Question Carbon reinforcement for Woody Wing Spar | Niko03 | Thermal | 15 | Jan 08, 2013 11:42 AM |
| Discussion Spars in a skinned foam core wing | Schoolya | Composites Fabrication | 4 | Jan 06, 2013 12:29 PM |
