Old Jul 12, 2016, 11:16 PM
lftort is offline
Find More Posts by lftort
Joined Jul 2016
Battery balance plug is tricky?
I have a 7S 6300 mah battery (big one) that i used for creating an electric longboard last year (Brand is Alien Power Systems).
Today i wanted to charge it, but the charger only recognizes 6 cells instead of 7 ( I have a G.T.Power A8 charger).
I measured one by one the cells in the balance plug and all of them were btw 3,45 - 3.5 V, so everithing should by good and working in the plug i though.
The next thing i did was to conect another battery (4S) in the 7S plug, and yes, the charger did recognized the 4S, no matter if i plugged the balance connector on the left, on the middle or on the right.
So apparently all my stuffs are OK, but something is not working.
Any advice?
I think is the battery balance plug because i used the charger earlier today and it worked good as always.
i hope you can help me..
Thanks!
lftort is offline Find More Posts by lftort
Old Jul 13, 2016, 03:34 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
First off ,anything below 3.7V per cell is not really O.K.
Some chargers count the number of cells by detecting voltage on the balancing connector to determine what the total battery voltage should be and also measures the total battery voltage on the main power leads if these two do not match an error is created. Many Li Poly chargers will not charge a cell if voltage is below 3.5 or so volts or if there is more than a few tenth difference in the cells voltages.
Often the info in the Sticky Threads can be a great resource.
http://www.rcgroups.com/forums/showthread.php?t=1074181
Charles
Old Jul 13, 2016, 09:45 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
In that case, the charger's balance capacity is very small? Modern one is capable up to 1A. What does that mean?
prodriverex is offline Find More Posts by prodriverex
Old Jul 13, 2016, 10:08 PM
losi man is offline
Find More Posts by losi man
United States, MI, Detroit
Joined Oct 2015
do all 7 cell register or show up on a8? . do a standard charge to 3.78 volts each cell..around 26.5 volts then see if charger will see 7 cells..if not then stand dard charge to 28.7 then charge each cekk on its own to 4.2..
losi man is offline Find More Posts by losi man
Reply With Quote  (Disabled)
Old Jul 13, 2016, 10:35 PM
lftort is offline
Joined Jul 2016
thanks for the reply´s.
I charged each cell to 3,58 V (since its 6300 mah capacity it was taking forever to reach 3,78 V), and still the charger doesn´t recognizes the 7 cells. Tomorrow i will charge each of them to 3,78V as adviced and see what happen.
Thanks! I will post if the problem was solved. If not, maybe i lost a lot of money on that battery. haha
Old Jul 14, 2016, 05:59 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
My guess is your balance connector has a bad pin inside of it. Most likely it is your red wire's pin.
Rick
rampman is offline Find More Posts by rampman
Discussion TRAXXAS "iD" battery balance plug??? FORT 26 Batteries and Chargers 2 Jan 19, 2016 08:46 PM
Discussion Ground Station battery lipo alarms only on the balance plug or direct wiring ok? markm75 FPV Equipment 4 Jan 17, 2016 03:54 PM
Discussion Battery Voltage different When Measured on Balance Plug and JST Plug Tracks FPV Talk 3 Sep 02, 2011 03:08 PM
For Sale Multiple different battery plugs and balance plugs bpink43 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 23, 2011 02:58 PM
Discussion Balancing Hypersonic A123 Batteries w/ Anderson balancing plugs? Dan_K Batteries and Chargers 1 Oct 17, 2008 01:36 PM
