Old May 03, 2016, 06:54 PM
Wildvortex is offline
Find More Posts by Wildvortex
United States, SC, Anderson
Joined Feb 2016
Flight problems with Trex 450L
I bought a used 450. When I got it it had a stripped gear on one of the ds430Ms. I replaced that with a ds416m since I saw somewhere that the 430 is discontinued and replaced by the 416.
We went through the Gpro FBL setup and I replaced all linkage ends.
We ran the 450 up to a little over half stick and had not lifted off. We let it sit a second with no stick movement. Suddenly it started to roll to the left and had a Blade strike. Of course the swash to blade linkages pulled with the strike. We have no idea what happened.
Has anyone had this problem or have an idea of what to look for?
Wildvortex is offline Find More Posts by Wildvortex
Old May 05, 2016, 09:07 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
When you mix and match servos not a good idea. They should be all the same. I know who wants to change all three but Could be problem ?
dankar04 is offline Find More Posts by dankar04
Old May 05, 2016, 11:14 AM
Joined Feb 2016
That is what I was thinking. I have new gear set for the 430m odd thing is itcsat there without stick movement before it tilted.
Old May 12, 2016, 06:26 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Align 450L is pretty good heli. Mix and match cylic servos not wise. Jamed servo can cause problems. I have seen servo work but were damaged and it shows up flying. Most times that doesn't end well.
Old May 13, 2016, 06:55 AM
Joined Feb 2016
Rebuilt the 430m servo and put back into play.
What is the best RX/TX combination for the Trex. I have a Turnigy 9xr pro. The DSMX module (orange HK module) died on me. Looking for other options. Trex has a Spektrum satellite on it but willing to change.
Discussion Trex 450L with Gpro FBL servo issue Wildvortex Mini Helis 2 Apr 24, 2016 08:09 AM
Sold Align Trex 450L Dominator with fuselage $300 Chrstj888 Aircraft - Electric - Helis (FS/W) 0 Dec 13, 2015 06:02 PM
Sold ((( SOLD ))) Align TRex 450L Dominator New Build, 3 Test flights Mahu Aircraft - Electric - Helis (FS/W) 2 Nov 05, 2015 04:05 PM
Sold f/s two brand new trex 450 #1 trex 450L bnf #2 trex 450 dfc plus rtf sergeyo Aircraft - Electric - Helis (FS/W) 1 Oct 22, 2015 11:11 PM
Sold Trex 450L Dominator + 6 Batts+ Spares ~ 30 flights old Ifly101 Aircraft - Electric - Helis (FS/W) 0 Dec 09, 2013 11:16 AM
