Old May 14, 2015, 03:39 PM
ChristianAustena is offline
Find More Posts by ChristianAustena
Norway
Joined Nov 2010
hobbyking lipo.
Anyone tried and have any knowing regarding the quality of this battery?
http://www.hobbyking.com/hobbyking/s...0mAh_1pc_.html
I like the size of it.
ChristianAustena is offline Find More Posts by ChristianAustena
Old May 14, 2015, 03:42 PM
jyzoom is offline
Find More Posts by jyzoom
Singapore (Asia)
Christian,
Many of us have been using the following with good success on our dlg
http://www.hobbyking.com/hobbyking/s...ll_Lipoly.html
JOnathan
jyzoom is offline Find More Posts by jyzoom
Old May 14, 2015, 03:46 PM
Norway
Joined Nov 2010
Is it easy to solder connector on these?
But still the other one I linked is allowing servos more forward mounted.
Old May 14, 2015, 04:51 PM
jyzoom is offline
Singapore (Asia)
very easy to solder .... I have use the 600 or 900 quite a bit on my vibe , vortex, flitz quite a bit to get it very much fwd compare tot he square since the shape actually allow it to good deeper into a typical fuse.
Old May 15, 2015, 01:48 AM
vanhalen1970 is offline
Find More Posts by vanhalen1970
Germany, SH, Schwarzenbek
Joined Oct 2013
Maybe someone could give me a hint, how to solder the connector cable properly to the round cells.
Never bought Lipo's without installed cables before, so I'm a little bit precarious, how to solder and secure the cable safely against tear-off.
greetings from germany
Stephan
vanhalen1970 is offline Find More Posts by vanhalen1970
Old May 15, 2015, 02:46 AM
Odisej is offline
Find More Posts by Odisej
Odisej's Avatar
Slovenia
Joined Sep 2006
It's written everywhere and there are quite a few warnigs, but still: very, VERY CAREFULLY! Lithium cells are very sensitive. Do not overheat the cell, you can at least damage or destroy it, but it's known that explosions also could happen... Just a heads up
Odisej is offline Find More Posts by Odisej
Old May 15, 2015, 04:28 AM
AlexxH is offline
Find More Posts by AlexxH
United Kingdom, Hertfordshire
Joined Sep 2014
I only started this hobby late summer last year. I wasn't too sure either how to solder connections to LIPO batteries.
I didn't think it was any more difficult than solder an extension lead on a servo wire. Just use some normal thickness wire (not super thin DLG servo wire) and get some connectors (I use JST at the moment) of your choice to crimp on with the correct crimp tool.
It really is not that difficult at all. They are cheap as chips, so just buy some and try.
I might even buy every year new LIPO to avoid having issues with older ones.
Only warning with LIPO's is not to overcharge them or pierce them. Never heard/read a story of LIPO issues when soldering.
AlexxH is offline Find More Posts by AlexxH
Old May 15, 2015, 06:43 AM
jyzoom is offline
Singapore (Asia)
This should help.. Very easy.
Old May 15, 2015, 07:59 AM
Odisej is offline
Odisej's Avatar
Slovenia
Joined Sep 2006
One thing is soldering a connector to a pre-soldered wire, a completely other thing is soldering the cable directly to the lipo cell. Just saying, use caution, Lipo's do burn
Old May 15, 2015, 02:29 PM
Norway
Joined Nov 2010
But I take it not many has tried the battery I linked? Well. I think I might. It can't be that bad?
Old May 16, 2015, 12:09 AM
rofly is offline
Find More Posts by rofly
Retirement is good
United States, CA, Huntington Beach
Joined Jun 2011
Stephan
Greetings from America. Not sure anyone answered your question. This is how I setup those round 1S cells and charge them:
http://www.rcgroups.com/forums/showp...3&postcount=22
Hope this helps a bit.
Dick
rofly is offline Find More Posts by rofly
Discussion Anyone using the E-OSD (Hobbyking) with 4s lipo? BIGTACO FPV Equipment 7 Sep 11, 2016 09:00 PM
Question Would 4S LIPO work with Hobbyking F30A esc paired with Turnigy 2836 1100k motor? dropout Multirotor Electronics 1 Mar 27, 2015 09:21 PM
Found Hobbyking eco 6-10 or equivalent lipo charger. ianpugh Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 14, 2015 05:15 PM
Discussion HobbyKing only shipping lipos "FedEx Priority" now??? TheNiceGuy Batteries and Chargers 10 Jan 25, 2015 08:30 AM
News HobbyKing Trackstar LiPo Storage Case Paul Onorato Car Talk 0 Oct 09, 2013 10:25 AM
