Old Aug 10, 2014, 05:12 AM
United Kingdom, Portishead
Joined Aug 2014
t-45 70mm motor advice
Out
ukgoshawk is offline Find More Posts by ukgoshawk
Old Aug 10, 2014, 07:25 AM
Joined Aug 2014
Out
Old Aug 10, 2014, 08:18 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
So far you havn't given any useful info to go by.--
First, all 70mm fans are not the same --- who makes it and how many blades does it have?? That will determine what Kv motor you need. Does it take an outrunner or inrunner?
Once you have the Kv, then you can figure out what sized ESC and batteries will be needed.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 10, 2014, 10:57 AM
Joined Aug 2014
Out
Old Aug 10, 2014, 12:27 PM
Joined Dec 2008
Take a look at the specs on the HK BAE Hawk - Red Arrow 70mm EDF Jet kit
http://www.hobbyking.com/hobbyking/s...hite_EPO_.html
Specification:
Required:
Your own TX & RX (with V-type mixing)
Motor: 2826 3200kv
ESC: 25A
Servo: 9g * 3pcs
Battery: 1600mAh 3S1P 20C Lipoly Pack
What you should do, is go to the foamy edf forum- http://www.rcgroups.com/foamy-edfs-377/
Do a search on T-45, and see what they are running in there 70mm fans. More than likely, they have bumped up there system from stock , for better performance.
For Sale Sapac t-45 hawk,70mm lorhd2005 Aircraft - Electric - Jets (FS/W) 7 Feb 04, 2014 03:50 PM
Found 70mm airframe only, T-45/F-22/or??? 3rd-dem Aircraft - Electric - Jets (FS/W) 1 Dec 08, 2013 02:52 PM
Sold T-Motor MT2814-770kv NIB $45 ea Garret H Aircraft - Electric - Multirotor (FS/W) 4 Oct 19, 2013 10:20 AM
Sold Sapac T-45 V2 70mm w/fan and motor SkylineFlyer Aircraft - Electric - Jets (FS/W) 12 Mar 16, 2010 07:45 PM
