FoxtechFPV Pivot Retractable Multirotor Landing Gear
With the explosion of 3 axis brushless camera gimbals the need for affordable retraceable landing gear has never been greater. FoxtechFPV to the rescue!
Get those landing gear out of your shot!
The explosion of 3 Axis brushless gimbals the demand for an affordable set of retractable landing gear has never been greater. And with the size of heavy lift rigs getting bigger and bigger a set of retracts that can hold some decent weight is required as well. FoxtechFPV is a company with their finger on the pulse of the multirotor world and saw this demand and met it! Just today FoxtechFPV released the Pivot retractable landing gear for any rig with 16, 22 and 25mm booms.
From the pics released, it looks like Foxtech has used a dedicated electric retract/servo per gear leg. And from the specs released each leg can hold 10kg (around 22lbs per leg!) which will allow these to be used on many of the current heavy lift rigs! ** Please note these gear mount to the arm boom so certain boom configurations will only work without a custom mount. . Y" Hex, and I" Octo will work with no modifications.
SPECS:
Weight: 280 grams (per leg)
  • Load Limit: 10kg per leg
  • Retract Speed: 4.5 sec descending/3.5 sec ascending
  • Input Signal: PWM 900us - 2100us
  • Power Consumption; 400mA (ascending)/ 300mA (descending)
  • Price: $130 (Pre-order) $150 Normal (Per leg)
For more info check out: FoxtechFPV
Old Apr 23, 2014, 12:47 PM
Closed Account
Joined Aug 2006
I ordered a set... we will see how they perform.
My wife and wallet are not happy so I hope they are GOOD!
Sleepyc is offline Find More Posts by Sleepyc
Old Apr 30, 2014, 01:07 PM
United States, TX, San Marcos
Joined Apr 2012
Mine are arriving today I think, I dont remember ordering anything else from Tianjin China. Hopefully they work out well.
kfennell is offline Find More Posts by kfennell
Old May 01, 2014, 10:30 AM
The Valkman's Avatar
Joined Nov 2011
Does a carbon tube, retract servo, 2 tube clamps and a few springs cost $150?! Thats $300 a pair! You could probably make them for $60 a pair.
The Valkman is offline Find More Posts by The Valkman
Old May 01, 2014, 03:43 PM
Joined Apr 2012
Probably, but at least 3 hours of cutting carbon involved.
Old May 01, 2014, 10:06 PM
Closed Account
Joined Aug 2006
Got mine today, I think they are worth the $225!
Mount them soon!
Old May 02, 2014, 03:52 AM
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Mount them soon!
What do you mean they are worth $225?, preorder is over , $300 a pair!
koolkiwikat is offline Find More Posts by koolkiwikat
Old May 02, 2014, 04:16 AM
Joined Jun 2013
Do they come pre constructed? Would it be easy to shorted to any length?
mshakeshaft is offline Find More Posts by mshakeshaft
Old May 02, 2014, 07:57 AM
Joined Apr 2012
Partly, and yes if you have ablade for cutting CF tubes.
Old May 06, 2014, 04:45 PM
Joined Jun 2013
Does anyone have any feedback on these yet? Wondering whether to order?
Martin
Old May 06, 2014, 06:14 PM
Joined Apr 2012
I have them, I like them, seem well built, and I haven't seen other retracts, but they have a well designed mechanism that doesn't look like it can fail. They go up and down in a few seconds. Come with all the parts you need.
I think the only downfall that I have seen is that you can't adjust the end points individually to my knowledge. I would like for them to not raise so high, but to change that I would have them go past vertical on the down position, so I am stuck with what they have.
Old May 07, 2014, 10:34 AM
Closed Account
Joined Aug 2006
Preorder was $110 each + $24 shipping.. i got them straight from the site!
EDIT:
Ahhhhh it changed! Sorry about that!
Old May 14, 2014, 03:56 PM
Joined Jun 2013
Any more feedback guys? I am thinking of using them on my Vulcan Mantis 900mm Hex.
Old May 14, 2014, 06:09 PM
Joined Apr 2012
With a 900mm you should be fine with them.
Warning for a 1200+ size copter.
You will likely need to cut the legs a LITTLE shorter then stock maybe just a few inches to feel good about the stability. I also have some longer 10mm cross bars on order that I will cut to around 750mm as I think that the copter is pretty wobbly at 500mm. I am still happy with them!
Old May 19, 2014, 04:10 PM
Joined Nov 2011
Not at all. Just add a metal retract servo to the top of the legs! Lots on YT with lots of methods ideas on how to do it.
Good job this is not a DJI product or it would be twice the price!
Sold NEW PRICE RC Lander Large Metal Electric Retract Landing Gear bwoollia Aircraft - General - Miscellaneous (FS/W) 8 Oct 29, 2013 03:34 PM
Question Is there cheap retractable landing gear? flohio117 Multirotor Electronics 4 Oct 24, 2013 12:40 PM
For Sale DJI Flamewheel 550 Retractable landing gear cfrea Aircraft - Electric - Multirotor (FS/W) 0 Sep 27, 2013 02:38 PM
