Old Yesterday, 02:50 PM
BM3
?EDM or EDF?
BM3's Avatar
United States, CO, Denver
Joined Aug 2013
Replacement retract question
I see that most of the replacement retracts come with a straight strut wire as opposed to the stock retracts that normally have the bend so that the wheels slide on.
Take for instance these...
http://www.pw-rc.com/product_info.ph...e4d6db0fb9f47f
are these made straight so that you bend them yourself to get the proper height? If so, how in the heck do you get the bend correct?
BM3 is offline Find More Posts by BM3
Old Yesterday, 05:34 PM
United States, CA, Sacramento
Joined Dec 2005
There are a couple of solutions.
These bolt on Axles will work. Many versions and brands are available. Just order a set that will fit your gear legs. A visit to the local hobby shop would be the quick fix.
http://www.hobbylinc.com/htm/gpm/gpmgpmq4281.htm
Measure and bend the gear leg. Make sure you bend in the correct direction based on the upper flat for the screw that secures the leg.
You can also make your own axles using brass stock and some music wire.
Regards,
ec121connie is offline Find More Posts by ec121connie
Discussion Replacing Spring Air 600 Series retracts for better looking and working versions demetrius Electric Ducted Fan Jet Talk 5 May 13, 2014 01:07 PM
Discussion Electric retracts replacement s for 1700 p 40 BUD JOYNER Electric Warbirds 1 Apr 19, 2014 12:09 PM
Question SK Big Lazy Hawk replacement gear question MiniChopper4Me Ornithopters 7 Dec 29, 2013 10:06 PM
New Product Replacement Electronics For Electric Retracts LJE4357 Large EDF Jets 2 Nov 29, 2013 11:57 AM
Discussion Airfield P-40 1400mm Retract & Servo Questions Tbolt65 Electric Warbirds 11 Sep 20, 2013 11:08 PM
