Old Feb 26, 2015, 08:45 AM
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
So you're saying, I should chuck the stock antennas in the bin and get a decent set?
Dipoles or something?
jkishan16 is offline Find More Posts by jkishan16
Old Feb 26, 2015, 11:03 AM
Joined Mar 2009
Dipole or better, but even a DIY dipole is OK.
Depends on the range you're looking for.
If you're using a very good antenna on TX side (something on a tripod), you could consider keeping the stock antenna on RX.
The stock antennas are not tuned to the good frequency. I wonder if this is not done deliberately, to have a low radiated power, maybe for legal reasons.
flipflap is online now Find More Posts by flipflap
Old Feb 26, 2015, 01:50 PM
Beaumont ,peoples republic of Kalifornia
Joined Jan 2004
Interested in setting up the Beacon......Have a FRS hand held ...so do all I have to do is enable beacon for say channel one frs.....and thats it.? ...have telemetry turned off will this still work?
Who else has beacon set up ?
debogus is online now Find More Posts by debogus
Old Feb 26, 2015, 01:59 PM
Joined Sep 2009
Yes me
Openlrsng Lost Model Finder Demo. (2 min 3 sec)
billhally is offline Find More Posts by billhally
Old Feb 26, 2015, 05:05 PM
KragerÝ, Norway
Joined Jun 2010
I have the orange rx too. I want the rssi to be more accurate. It jumps quite much when I have the antenna from tx 1 ft away from the receiver. What capacitor, resistor should I use between the rssi cable from the rx, and to my OSD?
Voguna is online now Find More Posts by Voguna
Old Feb 26, 2015, 05:11 PM
KragerÝ, Norway
Joined Jun 2010
Originally Posted by mathieu974 View Post
billhally, could you confirm the value 100k for the R anc 100mF (milli?) for the C?
http://static.rcgroups.net/forums/at...8960783202.jpg
I use a mini OSD from HK with ClOSD, should be good no?
What if you have a eagle tree OSD? Where does ground go to?
Old Feb 26, 2015, 09:47 PM
Joined Jan 2004
Originally Posted by billhally View Post
Yes me
Does it work when telemetry is turned off ? and on the FRS it only does the first 7channels from what Ive found or can you pick others?
Next Ill need to McGuiver me a directional antenna on to the FRS ..
Old Feb 26, 2015, 10:04 PM
Canada, SK, Division No. 7
Joined Aug 2014
If you've ever heard of a ham radio "Fox hunt" you will know that you can use your body as a signal blocker to locate the signal source.
Tuck your RX against your body and turn until the signal fades. Then go the opposite direction. When you get really close, if you have a removable antenna, pull it off.
Works pretty good and fits in your pocket! Conveniently the worse the radio is, the better it usually works - and it doesn't get much worse than FRS
rectifier is offline Find More Posts by rectifier
Old Feb 26, 2015, 10:52 PM
Joined Jan 2004
I do that with my quad when it goes down in tall grass with my frsky telemetry.... This is going to be a dedicated tool......
Hams have another game where they track unlicensed stations/violators they use yagis and they will find you ..... Pretty sure that would cut down search time
Old Yesterday, 06:30 AM
Joined Dec 2014
one of my hk orange modules lights up the flashing red warning light and it stays on. cant flash it...bootloader problem? thanks for any help
juano2001 is offline Find More Posts by juano2001
Old Yesterday, 07:50 AM
Joined Mar 2009
With ULRS, the meaning of LED is different, one means "sending packet" and the other one means "receiving packet". From your screenshot, the firmware was correctly uploaded, for a RX.
Do you have a running TX too ? If yes, both LED should turn on (flickering).
Old Yesterday, 02:42 PM
KragerÝ, Norway
Joined Jun 2010
The orangelrs receiver outputs an analogue voltage signal for RSSI up to normally 3.3 volts for full signal strength. The OSD is looking for a digital input so you need to have a filter to make the conversion. Its nothing fantastic just a resisitor and capacitor built into the connecting lead.
Is this the correct Capacitor?
http://www.ebay.com/itm/10-x-100uF-5...item3cb9519f8a
Old Today, 05:58 AM
Joined Sep 2009
Originally Posted by Voguna View Post
You have PM
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 03:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 10:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 07:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 02:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 04:19 PM
