Old May 01, 2003, 07:37 PM
New Jersey, USA
Joined May 2003
Learjet 23
The Learjet is a stable slow flyer using 2 GWS EDF-50s, Pico Rx, Pico servos for flying stab & ailerons, GreatPlanes 10A ESC and 350mAH, 7.2V nicads for 2 min. flights. WS: 38" WT: 12.2oz. WL: 9.16oz.
I found that setting 2 deg. engine down thrust has proved too much in opposing 2 deg. positive wing incidence. Full power only pushes the nose down, while at half power she flys very nice.
My question is: Is there a rule for setting EDF fan thrust angles that are different from fuel powered prop engines?
I'm planning a Boeing 727/100 using twin GWS EDF-75, or EDF-50s. I'd like to set the fan thrust to perhaps "0"deg., or make it adjustable.
David
Post 73 has PDF files for converting the Flying Models (March 2004) LearJet 23 Plan, CD218, from flat bottom to semi-symmetrical.
David A Ramsey is online now Find More Posts by David A Ramsey
Old May 01, 2003, 10:29 PM
Joined Mar 2003
Wow!
Exactly what I'd like to build next! Can you pleasepleaseplease post some construction photos? I'm assuming that everthing is stringers and formers. If so, you have done a marvelous job of avoiding the "starved horse" look. Cool cool.
EDF Newbie is offline Find More Posts by EDF Newbie
Old May 02, 2003, 05:15 AM
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
I'd love to buy a set of plans!!!!!!!!!
skyhawk is online now Find More Posts by skyhawk
Old May 02, 2003, 07:56 AM
crazy about airliner
forest MS, USA
Joined Mar 2002
hi david
if i may ask who is the maker of this plane !!! i will love to have one ! and one of 727 plane !!!
jermaine is offline Find More Posts by jermaine
Old May 02, 2003, 08:21 AM
New Jersey, USA
Joined May 2003
To EDF Newbie & Skyhawk:
An actual plan on one piece of paper does not exist at this time. Flying Models Magazine is interested. I have 20 flights so far and I'd like another twenty using 9.6V, 750mAH niMI cells in order to get some extended flight times to really evaluate its performance.
I have 2 construction photos, but I don't see a way to attach them in this reply. If I have to, I'll put them on a new thread.
David
Old May 02, 2003, 09:02 AM
New Jersey, USA
Joined May 2003
To Jermaine:
The Learjet plans were scaled from a Testors plastic model and the 727 will be done the same way.
Old May 02, 2003, 09:04 AM
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
David...please give us some specs. That is a gorgeous design! Have you considered using some LiPoly's in it?
Never mind...I was so busy looking at the pic, I missed it it the post...who can blame me?
zbrubaker is offline Find More Posts by zbrubaker
Old May 02, 2003, 09:19 AM
New Jersey, USA
Joined May 2003
TO: zbrubaker
Thanks for the complement. The Learjet specs are pretty much as origionally posted. I've never bothered to figure out the scale.
My son is pushing me to try LiPolys, but after 40 years of trusting nicads, I'm only beginning to look at niMHs. I appreciate the suggestion.
Old May 02, 2003, 09:25 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Listen to your son...1200Mah Kokam's (2 cells, 7.4v) only weigh 1 3/4oz and would probably yield 10-15 min flights!
Old May 02, 2003, 09:47 AM
New Jersey, USA
Joined May 2003
TO zbrubaker:
WOW! 1 3/4oz. The Learjet will be tail heavy and loose 1oz. Glad I put in a long battery tray. And I just ordered 2 NiMi packs. Think I'm gona bypass NiMI technology.
Thanks.
Old May 02, 2003, 09:55 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Check out FMA Direct's website here
Old May 02, 2003, 10:02 AM
New Jersey, USA
Joined May 2003
Will do! thanks
Old May 02, 2003, 10:08 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
David,
Do you know which rotors your using in the EDF50? Is it the stock rotor, or did you 'upgrade' to one of the other ones?
Old May 02, 2003, 10:28 AM
89" Kool Aid drinker.
Smash McCrash's Avatar
United States, CA, Ventura
Joined Dec 2001
Beautiful... I will be waiting for the plans.
Smash McCrash is offline Find More Posts by Smash McCrash
Old May 02, 2003, 11:34 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
David,
It looks as if you are restricting your exhaust quite a bit...what is the dia. of the duct at the back of the nacell?
LEARJET 23 CONSTRUCTION PHOTO No. 1 of 2 David A Ramsey Electric Ducted Fan Jet Talk 6 May 02, 2003 10:32 PM
LEARJET 23 CONSTRUCTION PHOTO 2 of 2 David A Ramsey Electric Ducted Fan Jet Talk 2 May 02, 2003 01:36 PM
