Old Dec 17, 2014, 08:21 AM
Hungary, Borsod-Aba˙j-ZemplÚn, Miskolc
Joined Mar 2011
I'd set it up as a regular plane, then under Channels change channel 4 to J3. Since you don't need throttle differential, you don't need any special mixing. Reverse channel 4 accordingly if you have to.
Oh, and calibrate the throttle on the two ESCs.
Sterby is online now Find More Posts by Sterby
Old Dec 17, 2014, 03:39 PM
Could you not mix two channels using a switch. So switch in pos 1 will give you front motor control, switch in pos 2 will then mix in motor 2 to the input from the throttle stick?
Speed_Freak is offline Find More Posts by Speed_Freak
Old Dec 17, 2014, 03:49 PM
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
Thanks Sterby.
That is how she is currently set up, but what I'd like to do is switch ch4 or force it's output in order to prevent the motor from running while I hand launch.
If I can't then I guess I'll have to discus launch the thing.
brett.c is offline Find More Posts by brett.c
Old Dec 19, 2014, 08:59 AM
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
I am flying a DLG in Glider mode. I need elevator and rudder trim on launch. The built Launch mix only allows elevator and aileron.
I assume flight modes is the way to go but I don't understand them. Do I create a flight mode, press T-link, and then add different trim in? So the TX saves two different trims depending on flight mode selection?
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 05:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 11:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 11:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 08:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 11:29 PM
