Old Yesterday, 11:40 AM
dccdmd is offline
Find More Posts by dccdmd
dccdmd
dccdmd's Avatar
USA, CA, San Diego
Joined Jul 2008
EDF Ducting assistance
I've got a TamJets 1:8 scale F16. It had a TJ100 running on 10S and in my opinion, severely underpowered for a 17lb jet.
I have since acquired a Schuelbler DS77 HST 120mm fan and motor with up to 6000watts! Surely a beast....
The existing ducting was for the 100mm fan. I have begun the painstaking process of modifying the ducting and saddle to fit the 120. The FSA on the Schubi is 77cm2 and I believe I can modify the inlet ducting inside the jet opening it up enough to satisfy the FSA requirement for the fan. (I can't remove the entire inlet ducting without damaging the airframe). I also believe I can make an adapter to the original main ducting to fit the Schubi.
Now it's up the RCG community for ideas and help!
Thanks guys!
DC
dccdmd is offline Find More Posts by dccdmd
Old Yesterday, 11:49 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Put a intake lip on the new fan. Then just end the old duct 3 to 4 in from the intake lip..simple..Or make an adapter which ever you like
Old Yesterday, 12:16 PM
dccdmd is offline
dccdmd
dccdmd's Avatar
USA, CA, San Diego
Joined Jul 2008
I do have the bellmouth - just trying to keep it a closed system.
Old Yesterday, 02:46 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Then cut the old duct back to get a shallow taper and make a new adapter..Unless you want to cut all the old ducting out and make new full length ducts
Old Yesterday, 06:48 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
turbonut:
I agree with turbonut....just add the bellmouth. I am flying a re-powered Stumax 110mm in a Hawk and I removed the intake ducting as he said ...........using the bellmouth on the Stumax..............easy to do and I didn't notice any difference in flight.
Madmax1965 is offline Find More Posts by Madmax1965
Discussion 90MM EDF Duct Treak Electric Ducted Fan Jet Talk 3 Jul 20, 2015 01:30 AM
Discussion 90MM EDF Duct Treak Electric Plane Talk 1 Jul 19, 2015 10:52 PM
Discussion EDF Plus HL3008 1815-13000KV Brushless Motor 30mm EDF Ducted Fan Power System jetjocky Micro EDF Jets and Power Systems 0 Jul 19, 2015 07:59 PM
Sold Delta-V (R) 32 80mm EDF Unit w/BL32 Ducted Fan Motor, 2150Kv jp_36 Aircraft - Electric - Power Systems (FS/W) 1 Jun 08, 2015 01:47 AM
