Old Jan 15, 2016, 08:38 PM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
A home made 5cc (010) 4 stroke
A long time ago (50 years!) my Dad, who was a serious model engineer, made this.
Description:
One of the first small model plane 4 strokes it ran on petrol.
Even more unusual (even now!) it has a pressure oil feed to the big end and a dry sump so it ran on 'pump' petrol with no oil in it.
He produced this section drawing as well.
Description:
An advanced layout with 45 degree inclined valves, a two ring slipper piston, hemi head with free flow ports and a float carburettor. No 'transistor' ignition then so it used a tiny contact breaker with a conventional HT coil.
Description:
It was actually built to attempt the world endurance record for planes limited to 10lbs weight which then stood at 13 hours with a conventional glow 2 stroke.
My dad reasoned that not only does petrol have a higher calorific value than methanol but there would be an additional 5% advantage not having the oil in it . The other benefit of a 4 stroke is its much superior part throttle economy. An important feature on a plane where the fuel would constitute 50% of its take off weight.
The 5cc was extensively tested and demonstrated that it would run for something like 24 hours with a decreasing throttle setting using just 5 pints fuel.
The plane was never built as shortly after completing the engine the FAI abandoned the power endurance record on safety grounds.
It does still run but not for long in respect to its age and coupled with the fact I do not have the necessary skills to mend any part of it!
5cc aero engine (0 min 37 sec)
It does blow a bit of oil smoke at tick over, it really needs an oil scraper ring adding, but the exhaust clears completely at full power.
Quorneng is offline Find More Posts by Quorneng
Old Jan 15, 2016, 09:15 PM
JeffMac is offline
Find More Posts by JeffMac
I'd rather be flying.....
JeffMac's Avatar
United States, IA, Story City
Joined Oct 2013
What a nice story and engine ! Thanks for the video !
best regards,
jeff
JeffMac is offline Find More Posts by JeffMac
Old Jan 15, 2016, 11:02 PM
danny mz is offline
Find More Posts by danny mz
Diesel Danny
danny mz's Avatar
Joined Nov 2013
Excellent - A very skilled father!
Thanks for sharing it.
* Danny M *
danny mz is offline Find More Posts by danny mz
Old Jan 15, 2016, 11:35 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
If 10 cc's is a 60 then I think 5 cc's should be a 30.
datsunguy is offline Find More Posts by datsunguy
Old Jan 16, 2016, 03:56 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Nicely made engine
Reginald is online now Find More Posts by Reginald
Old Jan 16, 2016, 05:15 AM
Taurus Flyer is offline
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Quorneng,
Very nice designed and built engine.
Taurus Flyer
Taurus Flyer is offline Find More Posts by Taurus Flyer
Old Jan 16, 2016, 07:49 AM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
Wow! Your Dad was the Man!
Patxipt is offline Find More Posts by Patxipt
Old Jan 16, 2016, 08:18 AM
SrTelemaster is online now
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Quite the engineering masterpiece! Your Dad was a genius & master craftsman. I really like the dual exhaust. It gives it quite the throaty tone.
Wouldn't 5cc = .30 cu in ?
SrTelemaster is online now Find More Posts by SrTelemaster
Old Jan 16, 2016, 10:43 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is a great little engine. Your dad was a master. I think it is much more difficult to make a small engine than a larger engine. As the tolerances become ever more critical as the engine gets smaller. The engine design is nice too, quite creative.
earlwb is online now Find More Posts by earlwb
Old Jan 16, 2016, 11:00 AM
706jim is offline
Find More Posts by 706jim
The castings alone are impressive. Not to mention the O.S. type of cross driven cam gear (which in my opinion is a more "elegant" design that the spur gear setup that Saito uses).
All in all VERY impressive!
706jim is offline Find More Posts by 706jim
Old Jan 16, 2016, 11:13 AM
em14 is offline
Find More Posts by em14
USA, FL, Alachua
Joined Aug 2009
Outstanding!
Leo
em14 is offline Find More Posts by em14
Old Jan 16, 2016, 11:17 AM
I TOBOR is online now
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
The spur cut gear is more efficient, the helical cut gears having more friction therefore generating more heat. The helical cut gear is stronger but strength is not an issue on the Saitos.
I TOBOR is online now Find More Posts by I TOBOR
Old Jan 16, 2016, 12:29 PM
1QwkSport2.5r is online now
Find More Posts by 1QwkSport2.5r
In SuperTigre we trust.
1QwkSport2.5r's Avatar
United States, MN, Cottage Grove
Joined Dec 2014
Which gear style gives a more precise engagement/timing?
1QwkSport2.5r is online now Find More Posts by 1QwkSport2.5r
Old Jan 16, 2016, 01:05 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
That's dependent on gear tolerances and backlash.
Professor Chaddock was very knowledgeable of model engines and this design shows.
FAI still has a category for duration flight. Maynard Hill's Atlantic crossing flight held the record until FAI removed the autonomous category and required 80% of the flight to be piloted by the record holder. One of Hill's earlier flights still holds that record.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jan 16, 2016, 01:39 PM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
I am impressed with the force feed lubrication.... I'd like to know more about that....
Some time ago I was a bit "brain-designing" for something similar on an OS 91 fourstroke, and my thought was just to adapt the backplate with a (rather large) oil exit, and have a small pump inject oil via the original breather nipple, assuming that if the oil leaking past the ring is able to lubricate the conrod, then so would an amount of oil sloshing around, being replenished all the time.
Never built it, it was just for fun, but what I see here (oil feed through a rotating distributor in the backplate) borders on brilliant....
Can't see how the oil is being returned to the sumptank though....
Brutus1967 is offline Find More Posts by Brutus1967
Sold Novarossi 3.5cc Nitro Buggy Engine - Plus 21-4 BTTS .21 Tuned/Turbo Long Stroke Bigflyer70 Cars - Accessories (FS/W) 2 Jul 05, 2015 04:34 AM
Sold RCV 58-CD Four STROKE .58 IN 9.5CC MODEL AIRPLANE ENGINE MADE IN ENGLAND rcrube Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 04, 2015 04:28 PM
Sold Rcv 58-cd 4 stroke .58 in 9.5cc model airplane engine made in england rcrube Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 26, 2015 12:06 AM
Discussion Home made 4-stroke engine Mitchilito Engines 9 Jul 12, 2014 06:11 PM
Found Small 4 stroke engine (5cc/0.30) RobertPoland Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 21, 2011 10:49 AM
