Old Oct 10, 2015, 08:49 PM
wadaduga is offline
Find More Posts by wadaduga
Build-Fly-Crash-Repeat
Joined Jan 2015
My Vapor Has a Boo Boo
I was out tonight with my Vapor, doing some sunset flying with Basicguy. After the first battery swap I noticed that it was acting a little weird. Usually it's me causing it to act that way but after the second time I attempted a right turn with up elevators and it did a nose dive I discovered that the plastic on the right side of the tail had come loose from the frame. I need to repair about 3in of skin, but the question is with what type of glue?
Any suggestions, guys?
wadaduga is offline Find More Posts by wadaduga
Old Oct 11, 2015, 02:26 AM
papadwight is offline
Find More Posts by papadwight
papadwight's Avatar
United States, TN, Murfreesboro
Joined Apr 2013
I use a light clear tape on my night vapor wings or tail and a foam safe ca glue on the body mounts or wheels.
papadwight is offline Find More Posts by papadwight
Latest blog entry: Indoor RC games
Old Oct 11, 2015, 09:21 AM
wadaduga is offline
Joined Jan 2015
Doesn't the tape throw the balance off and/or add weight to the frame?
Old Oct 11, 2015, 10:12 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Glue stick works fine for me.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Oct 11, 2015, 10:19 AM
BoxCar31 is online now
Find More Posts by BoxCar31
Perpetual Noob
BoxCar31's Avatar
United States, NC, Arden
Joined May 2015
Measure once
Cut twice. Put the second piece of tape on the other side if you are worried about it.
BoxCar31 is online now Find More Posts by BoxCar31
Old Oct 11, 2015, 10:41 AM
papadwight's Avatar
Joined Apr 2013
Here's a picture of repairs after bad crash heavy duty tape was used the plane still flew fine after repairs but I use a lighter tape on wings
Old Oct 12, 2015, 02:09 AM
papadwight's Avatar
Joined Apr 2013
here is picture of my night vapor with repair to motor mount and wheels and the old tape repairs put plane on scale to check weight. Still fine after all these repair's tape and glue even some hot glue around motor. The plane still right where it should be.
Discussion My own design "Old Timer" I call the "Boo-Boo" NewZee Vintage & Old-Timer Designs 29 Oct 18, 2015 02:04 PM
Found Vapor, Mini Vapor, Night Vapor, Vapor VAPOR!! LiLBucket Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 31, 2015 10:18 AM
Dumbest E-flight boo-boo KillerWatt Parkflyers 10 May 27, 2002 03:26 PM
GP Spirit modification boo boo joubinrc Electric Sailplanes 4 Mar 29, 2002 12:17 AM
Boo hoo my moth is done but ups won't deliver my new radio on new years eve. The Other Dave Parkflyers 4 Jan 01, 2002 02:41 PM
