Old May 24, 2014, 04:51 PM
Joined Feb 2014
Question about batteries and range
I'm looking to increase my flight time. I already have the radio system for it (DragonLink) and now I'm working on the power system.
It has been my understanding that as long as the C rating on batteries are the same, you can use any size (in terms of mAH) that you would like.
Ex: If a plane requires a (theoretical) battery of 1800mAh with a 20C rating, I could use a (theoretical) 3600mAH battery with a 20C rating and have a longer flight time.
Am I understanding this correctly? I've been told the "C" means circuit and refers to the amount of power flowing into the system from the battery.
Kevlarburrito is offline Find More Posts by Kevlarburrito
Old May 25, 2014, 01:36 PM
Joined May 2014
Use the 3600mah cells, they'll last longer. Do not mix different capacity cells!! Or different voltages!
bladexxl is offline Find More Posts by bladexxl
Old May 26, 2014, 12:06 PM
Joined Nov 2007
The C rating tells about the battery discharging ability.
It is also in relation to the battery size in mAh. 1800mA : 20C x1.8A= 36A discharge current max.
Theoretically with 3600mAh you would need only 10C to sustain same max
discharge current (36A).
sweflyer is offline Find More Posts by sweflyer
Question Question about little quads that go out of control range jprcq Multirotor Talk 3 Feb 16, 2014 02:40 PM
Discussion Dumb Question about Battery Voltages & Capacity tlr-boise Batteries and Chargers 7 Feb 05, 2014 09:55 PM
Discussion questions about lipo batteries joker208 Batteries and Chargers 21 Jan 03, 2014 06:02 AM
Discussion quick question about battery rating. acessford101 Multirotor Electronics 2 Nov 19, 2013 08:22 AM
Discussion question about parallel charging 2S umx connector batteries? Drewkc Batteries and Chargers 3 Oct 15, 2013 03:36 AM
