Old Mar 18, 2014, 05:53 PM
(ACCELLERATII INCREDIBUS)
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
New Product
West Michigan Park Flyers LIBERTY Biplane
The Liberty is a full fuselage, 6mm thick EPP, 3D biplane. Its large ailerons and counterbalances give it a very fast roll rate. The large elevator and rudder allow for precise control during acrobatic maneuvers. The 30" wing span and AUW under 7oz allow the Liberty to float through the air.
The Liberty EPP biplane is available at http://www.wmparkflyers.com/
Here are some of the Specs:
- Wing span – 30”
- Length – 31”
- Weight - (with battery) 6-7 oz
- Center of gravity is 2-5/8” from front edge of upper wing. ( On the spar)
- landing gear included
- Motor: 2204 – 1800 KV
- Prop: 8x4DD
- Battery: 460 mah to 800 mah 7.4 V
- Speed Control: 10 Amp
- 9 gram servos, 1 total
- 5 gram servos, 2 total
Liberty EPP Biplane (2 min 14 sec)
Liberty kit contents:
- 6mm White EPP Pcs
- 9mm Black EPP windshield
- Plywood accessory pcs
- Dubro EZ connects 2 pcs
- Dubro micro EZ links 2 pcs
- Wire z bends
- Shrink wrap
- Landing gear wheel kit
- Carbon fiber spars, control rods, and trussing
aircontrol is offline Find More Posts by aircontrol
Old Mar 18, 2014, 05:54 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Liberty PDF Build instruction guide.
http://www.wmparkflyers.com/wmpfmedi...ionGuide-1.pdf
Carbon fiber is precut to these lengths.
2mm rod carbon fiber pcs
- 5.5" x 2 (landing gear)
Large flat carbon spar
- 22.5"
Small flat
-21" x 2 (leading edge of wings)
-14.25" x 4 (trailing edge of each aileron)
-2" (tail wheel)
2mm tube (spars)
-23.5" x 2 (wings)
-6.5" (rudder)
-11.5" (elevator)
-5.437 x 2
1.2mm rod
-15" (elevator control rod)
-17" (rudder control rod)
-10.25" x 2 (wing trussing)
-10.625" x 2 (wing trussing)
-4.25" x 2 (tail trussing)
-4.75" x 2 (tail trussing)
-4.75" x 2 (vertical control rods between ailerons)
I recommend Foam-Tac for all foam assembly and CA glue for wheel gear.
Some of my build pictures
Old Mar 18, 2014, 05:55 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
LIBERTY XL!
The Liberty XL is a full fuselage, 6mm and 9mm EPP, 3D biplane, similar to the original but LARGER! The 36" wing and 10x6DD prop allow it to blast through the wind and yet float like a butterfly.
Here are some specs:
- Wing span – 36”
- Length – 36 ”
- Weight – 14 Oz (with battery).
- Center of gravity is 2-1/2” from front edge of upper wing, at the root or center.
- Motor: (40 to 50 grams) 2826/32 – 1050KV (10x6DD prop)
- or 2826/26 – 1270KV (9X5DD prop)
- Battery: 800 mah to 1300 mah 11.1 V
- Speed Control: 20 Amp.
- 9 gram servos, 2 for ailerons and 1 for elevator.
- 5 gram servos, 1 for rudder.
Liberty XL (3 min 22 sec)
Liberty XL kit contents:
- 6mm EPP Pcs
- 9mm EPP Pcs
- 10 Wire Z bends
- 2 Wire L bends
- Shrink wrap
- Fiberglass drywall tape
Liberty XL PDF build instruction guide.
http://www.wmparkflyers.com/wmpfmedi...on%20Guide.pdf
Old Mar 18, 2014, 06:19 PM
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
All I can say is I love the Liberty! Flys through the air like a knife! Hardly any coupling in knife edge!
The roll rate is incredible!
Get yours soon!
TMAC4123 is online now Find More Posts by TMAC4123
Latest blog entry: UMX Icon A5 Lights!
Old Mar 20, 2014, 01:13 AM
dynodude's Avatar
El Cajon, CA
Joined May 2007
Very cool looking bipe. Love the color scheme on it! When will it be available and how much are the kits? Will you be selling an ARF version also?
dynodude is offline Find More Posts by dynodude
Old Mar 20, 2014, 01:23 PM
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
We will have Kits in Akron ( NEF ) Price is yet to be determined, still crunching numbers.
We will have them on the site after we get back from Akron next week.
PNP availability I have been quoted a 80.00 build charge for this airframe. The builders time is limited so PNP's will be very limited until we can get the other builders up to speed on this kit. Give us a call AFTER Akron and we will see what we can do.
GM
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Mar 20, 2014, 02:06 PM
United States, FL, Keystone Heights
Joined Dec 2012
very nice.
with a name like Liberty i assume no other color options will be available?
swampflyer is online now Find More Posts by swampflyer
Old Mar 20, 2014, 04:26 PM
Jenison
Joined Nov 2009
Originally Posted by swampflyer View Post
very nice.
I need to do some work on the other planes paint schemes then we will change up the liberty and offer something new ... not for a wile though ... maybe in the fall.
Old Mar 21, 2014, 06:16 AM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Nice job, it looks great.
rcrich is offline Find More Posts by rcrich
Old Mar 21, 2014, 09:04 AM
Jenison
Joined Nov 2009
NEF BOUND !!! Just got out of the drivers seat for a bit ... Starbucks Break !
Old Mar 21, 2014, 07:38 PM
corsair214's Avatar
United States, IN, Danville
Joined Mar 2007
wmpf
hi are you guys going to Toledo?
corsair214 is offline Find More Posts by corsair214
Old Mar 21, 2014, 07:48 PM
Grand Rapids, MI
Joined Jun 2005
Yes they will be there!
Hornetnz is offline Find More Posts by Hornetnz
Old Mar 28, 2014, 09:50 AM
PA, WMPF & HE Team Pilot
AndreasHeger's Avatar
United States, OH, Amelia
Joined Apr 2008
I am looking forward to get the Liberty from Greg at the Toledo Show! He does an incredible job with those airplanes and the paintjobs are the killer!!! Nick was flying the Liberty at the NEF, incredible, great job Nick! See you soon!!!
Andreas
AndreasHeger is offline Find More Posts by AndreasHeger
Old Mar 28, 2014, 01:27 PM
God is Good
TMAC4123's Avatar
Joined Jan 2011
Awesome airplane!
Old Mar 29, 2014, 01:37 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
I have been building a Liberty plane for Andreas and came up with a better spot for the RX, ESC, and Battery. My first prototypes had the RX hidden in the lower side of the fuse, but it was hard to get at when I needed to bind it. Now with the nose top open, I can easily tuck the battery in and out, pull the ESC and RX out if needed, and it all stays hidden inside the fuse. Here are some pics of what I did.
New Product West Michigan Park Flyers Highlander Super Stol bush plane aircontrol 3D Foamies 394 Jul 23, 2014 10:19 PM
