Old Jan 30, 2016, 06:19 PM
Psychosix is offline
Find More Posts by Psychosix
Blue skies!
United Kingdom, Clacton-on-Sea
Joined Sep 2015
DX6i no longer binds
Hi all,
Really hoping someone can explain the cause of a problem affecting my DX6i.
After binding it without issue to roughly 20 plane since purchased in September, it decided it would no longer bind.. to anything.
I've tried two AR610s, a lemon and a pair of OrangeRX receivers. Same thing happens every time.. Bind plug is in the Rx, battery plugged in.. Rx light starts flashing and I hold the bind switch down and turn on the tx. Brand new model etc. the Rx light does flash as if binding, but then it just flashes slightly slower for about 10 flashes before going off completely. No control over the plane,
Esc is plugged in right way.
Throttle trim all way down.
Voltage on battery and tx is fine (try multiple anyway)
Same Rx bind in seconds with friends Tx
Tried getting further and close to Rx when binding, but nothing has worked.
I'm following the same process I always did, so am wondering if my tx is broken.
Any advice is greatly appreciated.
Psychosix is offline Find More Posts by Psychosix
Old Jan 30, 2016, 07:46 PM
mawz is offline
Find More Posts by mawz
Canada, ON, Toronto
Joined Nov 2015
Does it work with aircraft previously bound?
If not, probably a bum antenna or RF deck. If yes, something odd. Either way it'll need service.
mawz is offline Find More Posts by mawz
Old Jan 30, 2016, 08:01 PM
Blue skies!
Joined Sep 2015
Yes, sorry I should have said.. All my existing bound aircraft are fine, thankfully.
I'll give HH a call.
Discussion no throttle ncps and dx6i bind Jeffrsheli Beginner Training Area (Heli-Electric) 7 Jan 09, 2016 05:13 PM
Discussion OrangeRX R620X binds but will no longer receive - am I out of luck? Chriddler Radios 0 Jul 25, 2015 11:22 AM
Question DX6 no longer binds. RonboDismo Radios 6 Feb 08, 2015 06:58 AM
Discussion New Skyartec Wasp 3 no longer binds with the transmitter rhong Skyartec 9 Jan 24, 2010 01:58 PM
Help! DX7 + AR7000 no longer binding Azile Radios 4 Jun 01, 2008 06:37 PM
