Old Jul 12, 2015, 04:31 AM
delboyandrodney is offline
Find More Posts by delboyandrodney
New Zealand, Otago, Dunedin
Joined Feb 2012
Build Log
HMNZS Moa
Hi all time for another build.
This time I'm setting in to build HMNZS Moa. The decision to build this particular model came about by it being the local navy volunteer reserve ship here in Dunedin . I took a trip as a sea cadet on her when I was only 15 for 3 days and ended up joining the RNZN some two years later. Now several years after leaving what better model to build I thought.
I obtained the pdf set of the plans from the RNZN museum after sending an email through to them. These were printed out to a scale of 1/24.
I decided on the scale of 1/24 for this model to bring it to a size of 1100mm or so. These ships ( which 7 were constructed) were only 27m long would be rather small in any other scale. I also have found that macs mouldings have a subsantial range of 1/24 scale fittings which are perfect for this.
So far I'm at the stage of skinning her frame in 1.5mm ply, later to be fiber glassed. Frames are 6mm marine ply.
For anything I haven't covered please ask away
delboyandrodney is offline Find More Posts by delboyandrodney
Old Jul 12, 2015, 05:46 AM
steve mahoney is offline
Find More Posts by steve mahoney
Joined Jun 2006
I'll be watching this. There's one here in wellington as well, not sure which one.
The original Moa is a legend.
steve mahoney is offline Find More Posts by steve mahoney
Old Jul 15, 2015, 05:09 PM
Antipodes is offline
Find More Posts by Antipodes
Joined Aug 2012
Nice
Saw this build in the flesh last night at OMES boat group. I also used to see the real thing moored in Otago harbour. Looking forward to this build.
You now nearly have as many started/unfinished projects as I do.
Antipodes is offline Find More Posts by Antipodes
Old Jul 26, 2015, 05:15 AM
Joined Feb 2012
Hi all
The last few weeks I have finished skinning the hull in 1.5mm ply. I took some time to fair the hull also. i used epoxy and mircro balloons(white areas) as well as builders bog(pink areas). more fairing to be done once glassed.
So today as it was a rather warm winters day I fibreglassed 1 side of her in 100grm fibreglass. All going well I will get the second side done tomorrow.
Thoughts have now turned to props,shafts, motors and rudder choices
Old Jul 26, 2015, 05:38 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
He he yes we all know that... too manny ships out there we all want to build..
Nice ship HMNZS Moa
It is always good to have the real close at hand delboyandrodney
Sharky1dk is offline Find More Posts by Sharky1dk
Old Jul 26, 2015, 08:05 AM
mariner02 is online now
Find More Posts by mariner02
Brought to u by letter "Arr!"
mariner02's Avatar
United States, NC
Joined Sep 2009
Great choice of subject; interesting and unique. The hull is coming together nicely too!
mariner02 is online now Find More Posts by mariner02
Old Jul 26, 2015, 09:33 AM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
I'm watching .
Mark
the goon is offline Find More Posts by the goon
Old Jul 26, 2015, 10:13 AM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Great to see such an unusual subject being modeled ~
Tim B. is offline Find More Posts by Tim B.
Old Aug 09, 2015, 04:31 AM
Joined Feb 2012
Hi all, I'm now at the stage of having taken the hull off the building board. The hull has been completely fibreglassed, re coated with resin and micro balloons, sanded back, re coated with resin and sanded back. All this has give me a fairly good surface to work with. There is still a few imperfections at this stage but they will no doubt be sorted later on. I've then decided to remove her from the building board to continue with the installation of the prop shafts and rudders.
I will need to build a stand shortly also.
I sourced the drive train parts over the past few weeks from cornwall model boats, motion co and macks products. I'm very happy with all the items. It will be the first time I have used a gearbox and belt drive. Also with having a motor obtained from my local club a custom motor mount was needed. With the help of another club member with all the metal working tools needed the following was produced
Old Sep 06, 2015, 04:17 AM
Joined Feb 2012
Hi all this weekend sees the installation of the prop shafts and rudders. Used a simple set of spacers to set the prop shafts up to match the spacings of the gearbox. All was tacked in place with 5min epoxy, later permanently fixed with norski 24hr epoxy with aerosil. Also I have taken the blank rudders and skinned them with 0.8mm ply to give them a bit of shape
Old Sep 07, 2015, 09:42 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
G'day Mate,
Hull coming along nicely!!
Who's your supplier for the motor??? I could use several for various projects.... I have never seen one looking that new!! please PM me if they have a few more!!
Cheers Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Discussion MOA Crawlers nickel417 Rock Crawlers 6 Jul 26, 2015 06:23 AM
Wanted FMS Moa BBill Aircraft - Sailplanes (FS/W) 0 May 17, 2015 04:36 PM
Sold Leupold Deltapoint 3.5 MOA Reflex Red Dot Sight JHawk19 Non R/C Items (FS/W) 0 Apr 06, 2014 01:11 PM
