Old Sep 01, 2015, 02:30 PM
MD_Mogge is offline
Find More Posts by MD_Mogge
MD_Mogge's Avatar
Joined Jul 2015
Nice work! The fuselage looks very smooth. And the landing gear struts looks perfect. I want a pair of those, they would fit my MD-87 perfect. Did you by them from Hobby King?
MD_Mogge is offline Find More Posts by MD_Mogge
Old Sep 01, 2015, 05:32 PM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Thanks...
Yes I did... Got lucky on the length, they came out about right, about 1.5 inches ground clearance on the props.
I also bought the retracts from HK after the ChangeSuns didn't work. They are very nice.
ruff1 is offline Find More Posts by ruff1
Old Sep 03, 2015, 07:33 PM
PC Pilot is offline
Find More Posts by PC Pilot
PC Pilot's Avatar
United States, AL, Phenix City
Joined May 2013
I am consistently amazed with the size of airplanes that can be flown with such tiny motors.
Save me a front row seat for the maiden.
PC Pilot is offline Find More Posts by PC Pilot
Old Sep 04, 2015, 06:11 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Yep, a 9x3 prop on 3S with this motor produces roughly 28 ounces of thrust. X2 gives me 56, auw will be approximately 72 ounces. Actual power measured at 71 watts per pound with not so optimal batteries, she should be scale like with max speed of 48 knots. A bit over scale power-wise, with enough to get back from downwind situations. I have a trainer that came in at 65 watts, she isn't fast but can get back to you.
With electrics the way they are I probably won't mess with any gassers.
Old Sep 04, 2015, 06:23 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
She's light, and you've given her plenty of power to spare Kev!
Looking superb!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Oct 10, 2015, 01:15 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Slooow progress...
One of my flying buddies used his 3D printer to print out the proper size nose gear fork. Getting something the proper size kept running into dead ends unless I put out lots of money. The first one isn't quite right with the attachment point to the strut, so he is printing me another.
Now that I have the nose gear fork, I can retract the gear and then measure up to complete the cockpit area. The nose will stretch out a bit from scale, hope it still looks OK and doesn't affect the flying characteristics.
Old Oct 10, 2015, 11:55 PM
Up-Out-&-Gone
Joined Mar 2007
Slooow progress...
Love your 404's nosegear Kev! Looking great!
Old Nov 27, 2015, 07:46 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Bump...
OK, bumping the thread...
Not a lot of progress, one of my flying buddies printed out a nose gear fork plus he had one printed online for about $8. The one he got online isn't as stout as the one he printed but it is much smoother.
You'll see in the pic that I had to extend the nose about two inches to allow full clearance for the strut.
I need to get on to filling in the nose area.
Old Nov 27, 2015, 08:53 AM
Up-Out-&-Gone
Joined Mar 2007
Looking superb Kev! A thought . . . . couldn't you shave 2 inches off the nosegear Strut?
Old Nov 27, 2015, 04:01 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
I thought about that... It would work if I brought the gear down some. I chose this route so I wouldn't have to mess with relocating the retract. I'll give it some more thought.
Old Mar 03, 2016, 07:33 PM
jdlilfan is online now
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
Do you know where I can get a similar nose gear fork? That one looks perfect for a project I'm about finished with.
jdlilfan is online now Find More Posts by jdlilfan
Old Mar 04, 2016, 12:33 AM
Up-Out-&-Gone
Joined Mar 2007
How is your 404 build coming Kev?
Old Mar 13, 2016, 01:46 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Hi DD, it is crawling along unfortunately...
Lot's of stuff going on.
I have the nose underside foam glued up but not shaped yet.
Stay tuned, next post right-away is a request for advice on the nose gear retract and setting up the steering.
Old Mar 13, 2016, 01:48 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Sorry for the delay... Been off the grid for awhile but still want to build.
Do you know if this is the proper size for you? I have a FB who drew this up for me and sent it to a web site that printed it for about $9. I can get that link for you.
Old Mar 13, 2016, 01:52 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Steering Setup Question
Hi,
Question. Have a look at the photo below; this is one of those steerable nose gear retracts from HK, I really like this one as it has metal trunions and works very solid. I'm trying to work out the best way to attach the steering servo (in front) to the arm on the retract. The arm appears to stay in just about the same location as it is when retracted, and I want to know what the builders here think I should do to get them connected. Is there some kind of pivot that will take a wire and slide onto the linkage on the retract?
Kevin
Idea I'm Considering a Martin 4-0-4... ruff1 RC Airliners (Commercial, Cargo, Troop Carrier) 62 Dec 20, 2012 09:56 PM
Sold Sig 1/4 scale Spacewalker,Pica 1/6 scale Spitfire joedoan Aircraft - Fuel - Airplanes (FS/W) 2 Jun 02, 2012 11:45 PM
Sold 1/4 scale 4 1/4" inflatable cub tires lla Aircraft - General - Miscellaneous (FS/W) 0 May 28, 2012 10:55 AM
Build Log L-19 1/4 Scale Vailly Aviation Build Greggo Scale Fuel Planes 5 Dec 02, 2011 08:55 AM
Sold 1/4-Scale Fairchild PT-19 DanSavage Aircraft - Fuel - Airplanes (FS/W) 1 Aug 13, 2007 01:40 PM
