Old Feb 05, 2016, 01:18 AM
ProfitOfDoom is offline
Find More Posts by ProfitOfDoom
CLEVELAND,OHIO
Joined Feb 2003
I ordered the ESC and batteries,Im going for that leopard motor but having a hard time finding a 24mm water jacket to fit it "In the USA anyway" But I ran across a vid where a guy showed how to fit a 28mm jacket on a 24mm motor using a #17 O-ring found at local hardware stores. I see a few 28mm jackets on ebay,Is this a good idea to do this,any problems?
ProfitOfDoom is offline Find More Posts by ProfitOfDoom
Old Feb 05, 2016, 01:45 AM
AirDOGGe is online now
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
I posted a link to a 24mm jacket earlier today: http://www.hobbyking.com/hobbyking/s...m_Purple_.html
AirDOGGe is online now Find More Posts by AirDOGGe
Old Feb 05, 2016, 02:33 AM
CLEVELAND,OHIO
Joined Feb 2003
I tried to add it to my cart, but it wasn't available on the hobbyking usa stores, Only on the international store.
Old Feb 05, 2016, 03:32 AM
Just Plane Nutts
AirDOGGe's Avatar
Joined Dec 2011
That's true of a lot of boat-related things at HK, including propellers. There's not a lot of option in 24mm.
There's a silicone-based cooling jacket at OffShoreElectrics that says it fits motors from 20mm to 28mm diameter, but I don't know much about it.
http://www.offshoreelectrics.com/pro...+Water+Cooling
Scroll down to "Silicone water jacket for 300 Size Motors"
In Stock: 4
Water Jacket for 300 Sized Motors.
Measures 15 mm wide
Fits 20mm to 28mm Diameter Motors
Price: $16.99
Old Feb 05, 2016, 07:53 AM
sundogz is offline
Find More Posts by sundogz
Platinum Card Member
sundogz's Avatar
United States, AR
Joined Sep 2007
It's the coupler!
No need to get hung up and limit motor selection because of the 2.3mm shaft size. The one problem this stock boat has is the crappy coupler. It is the cause of vibration and possible shaft bore wear. Consider this is how SicRc started out by marketing a flex shaft arrangement to help this problem (it may cause even more problems, so I wouldn't consider it). The stock coupler should be discarded and replaced with an aftermarket, better quality coupler which can be purchased in most size(s) you want, from many different vendors - even ebay. This increases the options for motors in the right rpm range. Just search the size you're looking for, i.e. 2.3 x 3mm, 3.1mm x 2.3mm etc. Outside dimensions won't (usually) matter, but make sure it is long enough.
It appears that SicRc has closed down, at least for the time being. Others have tried to contact Steve in the last couple months with no answer. I hope all is well with him.
sundogz is offline Find More Posts by sundogz
Last edited by sundogz; Feb 05, 2016 at 10:59 AM. Reason: needed to lighten up a bit!
Old Feb 05, 2016, 12:04 PM
Just Plane Nutts
AirDOGGe's Avatar
Joined Dec 2011
It has to fit with this narrow space, doesn't it? How do you fit a larger-than-stock one? Do you cut away the plastic?
When I made mine, I had to watch the outer diameter when I selected the aluminum rod to use.
Old Feb 05, 2016, 01:35 PM
Kayaker is offline
Find More Posts by Kayaker
Joined May 2014
I am very sad that SicRC is no longer making jet boats. Steve was the only one making an ABS hull that is strong enough for my application. I run my boat an hour a day, 3-5 days a week, all year long, always in rapids bashing rocks. I believe I just past 450 hours of river time. There are some very nice glass hulls made by Mickie Beez and KMB that a 28mm jet drive will fit but glass hulls don't like rocks. I like the shape of the NQD (HIPS plastic?) 410mm hull and I can make it stronger by putting a very thick layer of ShoeGoo on the inside but it is very hard to fit a proper 28mm jet in this hull. For my application the 20mm, poorly designed NQD jet, even with lots of modifications is still a toy. I am hopeful that Mickie Beez will fill the vacuum with an ABS version of his hull.
This is just my opinion and may not apply to most people that will only run a boat for a few hours before moving on to the next project.
Kayaker is offline Find More Posts by Kayaker
Old Feb 05, 2016, 03:10 PM
sundogz is offline
sundogz's Avatar
United States, AR
Joined Sep 2007
Lol, store-bought couplers that are 2.3 on one end are usually small enough to fit. That won't be a problem.
Old Feb 05, 2016, 03:12 PM
Youngsta is offline
Find More Posts by Youngsta
Youngsta's Avatar
United Kingdom, England, Manchester
Joined Sep 2013
I'll be making some more 2mm abs hulls in the spring,,
but you can still buy the very best in model jet drive units,
they are only a few more $'s than the others drives that have the plastic props, no thrust bearing or integrated cooling nipple,
so really they are the only drive to buy if you care about price and performance,
here's my email, brinksman67@hotmail.com
and a video of the sorts of fun you could have with one of my drives,
BOATS ROCK and RIVERS ROLL (3 min 3 sec)
Youngsta is offline Find More Posts by Youngsta
Old Feb 05, 2016, 07:23 PM
CLEVELAND,OHIO
Joined Feb 2003
I was wondering what the general size of tubing would be use when im hooking up water lines to the motor and esc. I wanted to order a water outlet nipple but I see they come in a few different sizes and wasnt sure which one to get,I see on OSE they have 7/32 or 1/4 and I see on ebay they come in M6 or M8, Im assuming there the same sizes as mentioned above?
This is the water jacket I ordered... http://www.ebay.com/itm/390628701942...%3AMEBIDX%3AIT
And this is the esc I got.... http://www.hobbyking.com/hobbyking/s...r_Cooling.html Thanks!
Old Feb 05, 2016, 08:57 PM
Just Plane Nutts
AirDOGGe's Avatar
Joined Dec 2011
3mm inside diameter tubing is what I use. 1/8" I.D. will do too.
I think this is what you are looking for. You'll have to scroll down the page a ways...
Standard Size Water Outlet machined aluminum with nut and o-ring. For use on 1/8 and 3mm tubing. $2.50
http://kintecracing.com/Water_Cooling_BQFJ.html
Old Feb 05, 2016, 09:34 PM
TheMicroRcWorld is offline
Find More Posts by TheMicroRcWorld
Joined Jan 2015
http://www.banggood.com/2mm2_3mm3mm3...-p-943629.htmlWhich size of these coupler would be the best fit for a 2.3mm shaft?
TheMicroRcWorld is offline Find More Posts by TheMicroRcWorld
Old Feb 05, 2016, 10:09 PM
Kayaker is offline
Joined May 2014
Youngsta, that looks like a fun play spot. You have very good piloting skills.
I want one of your ABS hulls when you get back to making them. Do you make Lexan decks and hatches that can be painted on the inside? Tell me about your front bumper.
Old Feb 05, 2016, 11:25 PM
Just Plane Nutts
AirDOGGe's Avatar
Joined Dec 2011
Below the price where you select SIZE there are several selection boxes with two dimensions listed, such as "2.3mm-3mm". These are the bore internal diameters of each end of the coupler. ... "2.3mm-3mm" means one end of the coupler fits the pump's 2.3mm diameter shaft and the other end will fit a motor with a 3mm diameter shaft.
As long as one end of the coupler is 2.3mm, it should fit the jet. The other end will have to match your chosen motor shaft's diameter.
A 2.3mm-3mm or a 2.3mm-4mm will fit most motors. Yet I just ordered a new motor for my Barbwire XL that has a 3.5mm shaft and the stock motor it replaces has a 3.2mm shaft. Pick a motor and find it's shaft size first.
I cannot be sure if the outer diameter of those couplers will fit the cavity of the pump where it is suppose to sit though. banggood does NOT provide that dimension.
The webpage shows a photo of the coupler next to a scale to show it's length. I used Photoshop to duplicate the image and rotate it 90 degrees to approximate the diameter...Looks like 9mm. I do not know the width of the pump cavity for clearance at this moment.
Old Feb 05, 2016, 11:39 PM
Joined Jan 2015
A 2.3mm-3.18mm(1/8") or a 2.3mm-4mm will fit most motors. Yet there are some motors with 3mm shafts and I just ordered one for my Barbwire XL that requires a 3mm to 3.5mm coupler. Pick a motor and find it's shaft size first.
I cannot be sure if the outer diameter of those couplers will fit the cavity of the pump where it sits though.
Well, My motor shaft is 2.3mm and that means none of them fit. I have asked my hobby shop to see if they have any as well. Thanks for the reply!
Build Log My NQD "Tear Into" build thread. wparsons Racing Boats - Electric 69 Feb 17, 2016 08:47 PM
Wanted Anyone have a NQD Tear into jet boat kicking around? Energy Boats (FS/W) 3 Mar 22, 2011 07:41 PM
Discussion Brushless NQD torn into jet boat mortonj69 Micro and Sub-Micro Boats 3 Feb 14, 2011 07:02 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 06:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 06:48 PM
