Old Yesterday, 04:27 PM
Depronicus is offline
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Originally Posted by richord View Post
I keep fracturing the original carbon landing gear during landings on my 51" slick...Any suggestions on...something else that may be stronger, cheaper or more flexible?
Have you done much soldering? Wire gear, done right, is really tough and can be flexible, and usually comes out not much heavier than stock LG setups. See below. The struts fit into brass tubes that are very heavily epoxied to the airframe.
If you're interested, I can give you more details.
Depronicus is offline Find More Posts by Depronicus
Old Yesterday, 05:13 PM
jimmy34256 is online now
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Injunnewity....
jimmy34256 is online now Find More Posts by jimmy34256
Old Yesterday, 07:37 PM
Bloosee is offline
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
I keep fracturing the original carbon landing gear during landings on my 51" slick. It's to the point now that I need to replace the gear. This last time even put a dent in the bottom of the frame. Any suggestions on simply getting the stock gear again or purchasing something else that may be stronger, cheaper or more flexible?
I think the stock gear is just fine. Mine held up for over a hundred flights, it wasn't until I got reckless with the plane and started doing harrier landings. As long as you just "land" normally the gear seems quite strong and durable.
Bloosee is offline Find More Posts by Bloosee
Old Yesterday, 09:07 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
If you don't mind about 20 minutes of work with a dremel sanding drum, the gear from an ExtremeFlight 60" Edge will work and be stronger. They are just wider in the mount base area, so use the dremel to knock a couple of millimeters off of it, and drill new mounting holes and you are done. I used a set of those on my last 51" Slick, and they work brilliantly.
http://www.extremeflightrc.com/store...roducts_id=145
just choose landing gear in the drop down box
ryan_m is offline Find More Posts by ryan_m
Old Today, 04:43 AM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Ryan do you know what the weight delta was?
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
