Old Apr 27, 2015, 08:19 PM
thrustboy is offline
Find More Posts by thrustboy
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
The Ofna Mini-Start is the box I bought. I got it off of Amazon. It is listed for as high as $60 or more elsewhere. The only modification is the slot in the chassis for the starter wheel to fit through. That was about 10 minutes work with a dremel tool. Then, the starter box has to be setup for right side engines and fitted to the chassis, another 10 minutes or so. You will also need a 7.2 volt stick pack with a Tamiya plug. I already had the battery. Most who have had cars of any kind already 1 or 2 lying around.
It is one extra thing to haul out, but this thing is pretty small. The speed of the starter wheel justifies it for me so far.
thrustboy is offline Find More Posts by thrustboy
Old Apr 28, 2015, 09:30 AM
chly3001 is offline
Find More Posts by chly3001
Singapore
Joined Apr 2014
did u have to adjust the height of the engine to use the starter box? i read somewhere that the engine is too high and they had to lower it. if it's just dremel work it can be done easily.. i'd still prefer a pull start for a first nitro buggy though hmm (less cost too!)
chly3001 is offline Find More Posts by chly3001
Old Apr 29, 2015, 06:14 AM
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
No. What I wrote in the previous post is all the modification that was necessary. I think the engine height issue is with the .05 engine. I know they use a motor mount since I've seen it listed as a spare part. The .07 mounts directly to the chassis.
That's actually the best thing about starter boxes. Once you're set up, it's the most trouble-free starting. It even makes installing the body shell easier since you don't have to accommodate the starter handle.
Old May 15, 2015, 01:41 PM
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
Just a quick update for those interested. I haven't had a lot of time to run the buggy since the last post, but the results have been pretty good. I have been running it on a dirt track with jumps, all sized for 10th scale vehicles. It drives okay and has survived a lot.
I have had a steering bracket break a on crash and the dogbones bend really easily, but it's not doing too bad so far. Early on I broke teeth out of a couple of spur gears, but I've been setting the mesh a little looser and haven't had another break.
There is also a lot of slop in the steering, which you can retighten screws to eliminate, but it returns soon. On the whole I can't really offer a glowing opinion of this little buggy, but if you can tinker and want a really small nitro car, you might want to give it a try.
Old Jun 05, 2015, 10:51 AM
helicycle is offline
Find More Posts by helicycle
R/C addict...
Joined Aug 2006
Just a quick question...I'm assuming that this buggy is the same platform HK is using for the Truggy. I like the Truggy look, and haven't owned a nitro care in a very long while, so I figured I might give this one a shot. Thanks!
helicycle is offline Find More Posts by helicycle
Old Jun 07, 2015, 07:02 PM
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
I appears from a quick glance that the two share many or most, possibly nearly all parts in common. I would expect similar issues...
Discussion Turnigy 1/16 Brushless 4WD Mini Rally - Extreme Edition messir Off-road Cars 6 Oct 31, 2014 12:12 AM
Video 1/16 Turnigy Racing Buggy / Monster Beatle with mods. ezarc Car Talk 0 Sep 17, 2012 07:39 AM
For Sale HPI Nitro 1/10 Scale 4wd Belt Drive Car w/ Camaro Body lhartman89 Cars - Cars and Parts (FS/W) 3 Aug 15, 2012 05:52 PM
Sold 1/16 4WD Nitro Buggy/Truggy (RTR) $100 Oracus Cars - Cars and Parts (FS/W) 0 Aug 10, 2010 08:20 AM
Mini-Review Sportwerks Chaos 1/16 4WD nitro buggy Slink Micro Cars 5 Mar 21, 2008 11:40 PM
