Old Nov 23, 2012, 10:32 PM
Watch this! *crunch*
nforbesrc99's Avatar
United States, GA
Joined Jul 2012
Equivilant
I need to know an equivalent to the hacker A30-12XL that is a lot cheaper but has the same amount of power (or slightly less) and it needs to fit in the 3DHS 51" AJ Slick. (Maybe something from Hobbyking?)
nforbesrc99 is offline Find More Posts by nforbesrc99
Old Nov 23, 2012, 10:50 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Here's how you could go about it.
They key specs for the A30-12XL are Kv of 700 and weight 177g. If you want to see what HK has similar, pick any motor, scroll down until you see the big Compare buton under the motor dimension graphic. Clicking that lets you choose rough motor size with the slider. Th A30s are 37mm, so 35-45mm is a good start.
That gets you to this page: http://www.hobbyking.com/hobbyking/s...sp?diameter=40
Scroll down til you find the right Kv, and a motor similar in weight. G25-710 has the right Kv and weighs 185g, or there's a G15-710 that weighs 170g.
Read up on the dimensions to see if either will fit. Done.
Match Kv and weight, then read around for reports on that motor. And research the model for power systems others are using.
scirocco is offline Find More Posts by scirocco
Old Nov 23, 2012, 10:58 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
Keep in mind that a much cheaper motor will tend to be less tolerant of high levels of electrical abuse, so for a given set of specs (size, weight, Kv) you won't be able to push the cheaper motor as hard as you could push the more expensive option.
Other than that, pretty much just do what Scirocco said. If you can't find anything that's an exact match, you'd do best to err on the side of heavier and/or lower Kv than the recommended Hacker.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Nov 25, 2012, 05:12 PM
United States, GA
Joined Jul 2012
Ok thanks! I'm probably not getting the plane anyway, but it was nice to know what I have to do if I don't want to have to pay a ton for a motor LOL ! Thanks
Discussion what type and size of brushless motor is equivilent to a .67 nitro? jasperchris2007 Racing Boats - Electric 3 Sep 18, 2012 07:20 PM
Discussion Hobbyking equivilent of the supercub with aileron jamiek123 Beginner Training Area (Aircraft-Electric) 5 Aug 08, 2012 01:44 PM
Wanted Webra Blackhead 10cc side exhaust- or equivilant Rossi EscapeFlyer Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 06, 2012 01:55 PM
Sold 5055-700kv motor, Power 46 equivilant MNMadman Aircraft - Electric - Power Systems (FS/W) 1 May 21, 2012 12:33 PM
Discussion Elec Motor wattage equivilant to a 46 size nitro engine dakoris73 Beginner Training Area (Aircraft-Electric) 16 Apr 15, 2012 04:01 AM
