Old Feb 22, 2015, 08:07 PM
Airbud's Avatar
Canada, BC
Joined Jan 2010
Question
JR 9503 swithch from NiMH to LiPo
I am interested in changing my JR 9503 from NiMH to LiPo.
Has any one have any experience or thought about this.
Airbud is offline Find More Posts by Airbud
Old Feb 22, 2015, 08:15 PM
yorkiepap's Avatar
SW PA
Joined Aug 2010
I use LiFe's in my JR10X's & used them when I had a 9303. There is a notation from JR that a LiPo can damage the internal circuity. Some use them....personally, I wouldn't.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Feb 22, 2015, 11:01 PM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
This is one of those situations where you can probably get away with doing it but it's definitely risky. Why use LiPo when LiFe gives the correct voltage?
By the way, if you use anything other than NiCd or NiMH, don't forget to tape over the charge jack so you don't accidentally plug in a charger.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 22, 2015, 11:15 PM
RC Warjet
United States, CA, Jamul
Joined Mar 2013
Don't do it! LiFe or low-discharge NiMh like here: http://www.alofthobbies.com/transmitter2100.html
Warjet1950 is offline Find More Posts by Warjet1950
Old Feb 22, 2015, 11:52 PM
Airbud's Avatar
Canada, BC
Joined Jan 2010
Thank you all.
I think its time I learn a new battery Chemistry .
Big help.
Wayne
Old Feb 23, 2015, 12:42 AM
rajazo's Avatar
Chile
Joined Jul 2010
I burn a futaba 8u with a lipo.... now 2 years without problem with LiFe on my second 8u and 9CAP
rajazo is offline Find More Posts by rajazo
Latest blog entry: OV10 bronco
Old Feb 23, 2015, 02:59 PM
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Originally Posted by Airbud View Post
Thank you all.
Big help.
Wayne
Some guys like the LiFe batteries but the discharge curve on those batteries is so flat that by the time a volt meter tells you it needs charging, it's very nearly dead.
Those and the original A123's make great rx packs, but you fly them by time because of this consideration. Some guys do it by number of flights, I prefer to use the timer on the radio and I know what each model uses per minute and when to recharge.
This is why I don't think they make good tx batteries. I'd go with the Eneloop cells and several of the vendors will make those for you. They are a low self discharge NiMH battery and you can charge with your existing charger/setup.
The battery packs linked to by Warjet claim to be low self discharge but I have no experience with that vendor.
Zeeb is offline Find More Posts by Zeeb
Old Feb 23, 2015, 03:54 PM
Virginia Beach, Virginia, United States
Joined Jan 2004
I dropped one of these in my 9303 about 2 years ago. Works perfectly and zero issues. Think I may charge it 3 or 4 times a year.
Tyler
http://www.hobbyking.com/hobbyking/s...4_TX_Pack.html
pylot2b is offline Find More Posts by pylot2b
Old Feb 23, 2015, 09:38 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I've been using LiFe packs in my transmitter and receivers for close to 5 years and never had issues. My transmitter low battery alarm is set up for 3.15V per cell and I can get at least another 10 minutes after the alarm sounds - this is the maximum I've used it when the low battery alarm kicks in.
Normally I'd charge the transmitter pack when the battery voltage drops to or below 3.25V per cell.
Receiver LiFe packs get charged before a day of flying and I can get at least 10 flights of 12 minutes each or 7-8 flights at 15-18 minutes each.
Ivan
ivanc is offline Find More Posts by ivanc
Old Feb 24, 2015, 10:13 PM
Airbud's Avatar
Canada, BC
Joined Jan 2010
Thanks Guys. I have a lot to chew on now. You have opened my eyes to some new ideas. I think it is time to get to know some different battery chemistry now.
Thank you again.
Wayne
Sold JR 2500mah NiMH tx battery and wall charger 9503/9303 $30 shipped HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Feb 22, 2015 02:09 AM
Sold JR 9503 DSMX Indistinguishable from New sammydabull Aircraft - General - Radio Equipment (FS/W) 2 Feb 10, 2015 11:39 AM
Sold JR 9503 Indistinguishable from new with box, papers, and two Life batteries sammydabull Aircraft - General - Radio Equipment (FS/W) 3 Jan 06, 2015 10:57 PM
Discussion RC Car upgrade from NIMH to Lipo sahil80 Car Talk 4 Dec 17, 2014 11:51 AM
Discussion How get power from JR 9503 Radio felipesalomao FPV Talk 3 Oct 01, 2013 07:30 PM
