Old May 17, 2015, 09:01 AM
Nashuanl is offline
Find More Posts by Nashuanl
Joined May 2015
Hello, i just read from 2013 to know but can get a conclusive idea if the tslrs works good with a naza on a quad. Can someone give me a clear answer if i can fly my quad (blacksnapper) with a dji naza with an uhf from Scherrer or does the naza create that much noise that the tslrs is not recommended?
Greets martin
Nashuanl is offline Find More Posts by Nashuanl
Old May 17, 2015, 03:11 PM
boopidoo is online now
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I've used naza v1 in very close proximity to tslrs without any problems.
boopidoo is online now Find More Posts by boopidoo
Old May 18, 2015, 03:50 AM
Nashuanl is offline
Joined May 2015
Oke, so if i make sure the noise of the naza is set to minimal i can fly with tslrs.
i know have ferrit rings from my esc's to the Naza and one from the Naza to the RX. I saw that people do copperfiol round the Naza? will this also help?
Old May 21, 2015, 08:21 AM
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
anything that emits radio noise in the same band as any type of receiver,
will affect the maximal range possible.
if you dont need to take advantage of max range, then most likely you dont see any problems, even if you have sevaral noisy units on board..
Naza board is known to be noisy in the UHF band..
so take precautions. and perform the range tests as explained in your TSLRS manual.
thomasscherrer is offline Find More Posts by thomasscherrer
Old May 21, 2015, 08:24 AM
Joined May 2007
>The RX700 NR MK has only ppm out?
yes so far..
no one ask for SM bus receivers, we did make one, and tested it,
if you feed a need, then ask via our support section, main webpage, tslrs.com
Old May 22, 2015, 03:38 AM
Nashuanl is offline
Joined May 2015
Thomas,
i emailed tslrs.com if it is possible to get sma connectors on a new longrange receiver.
this is possible right?
i dont dare to use my own slodering skills to change them.
Old May 22, 2015, 07:44 AM
Joined May 2007
sure can, I even paint them green if you ask for it :-)
Old May 27, 2015, 02:45 PM
Nashuanl is offline
Joined May 2015
Thomas, when i do a camouflageplane green would be oke😜.
is nobody answering the e-mails on Tslrs.com? Stil have not got a quote what the costs will be for sma connectors on a lr receiver.
Greet. Martin
Old May 27, 2015, 04:43 PM
voda1 is online now
Find More Posts by voda1
Joined Aug 2014
Thats the only Problem from tslrs and his Team. You need a lot of patience.
voda1 is online now Find More Posts by voda1
Old Today, 05:32 AM
Joined May 2007
they only work 7.5 hrs pr day, and during normal working hrs,
so when you are off your work and need help, it will arrive next day..
if your questions are of a more normal type, try ask your friends here :-)
Old Today, 06:11 AM
Nashuanl is offline
Joined May 2015
Hi Thomas,
Can you tell my how i can order the lr with the sma connectors and what the price will be?
If i but the lr in the basket there is no option to change the connectors.
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 500 Feb 25, 2014 02:22 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 06:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 08:24 PM
