Old May 13, 2015, 01:33 AM
lassehellsten is offline
Find More Posts by lassehellsten
lassehellsten's Avatar
Sweden, Gävleborg County, Gävle
Joined Aug 2012
Originally Posted by MrRCFlying View Post
Thank you tbeller!
It has been quiet in here for a while. Any questions or anything?
Andrew
Rainy, windy and cold. Completing my Tempest 1450 mm with 2 TT25. Used them far front to correct CG instead of adding lead
Suprastar F3A scratch built with 1 TT25 also soon completed.
Will show pics of installations
Is V5 still on hold?
Lasse
lassehellsten is offline Find More Posts by lassehellsten
Old May 14, 2015, 01:33 AM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
Andrew
Andrew you gotta get a grip on HK or you may regret what you wish for!!!
Here's a quote of a Q at http://www.hobbyking.com/hobbyking/s...nd_System.html
" MasterB 268 points - 5/05/2015 - So what are the airframe requirements for this to work well? I mean, would it work in a light plywood and monokote structure of my 1.9m supercub? I assume the transducer needs to be fixed to something solid to work? "
There's *NO* mention of the TT-25 being a 'transducer' other than the vague reference in the title 'speakerless sound system.' Then they use the word speaker a couple of times in the description anyway.
I tried to write something explaining the differences but I wrote it as about 5 separate spaced sentences and HK posted it as on looong paragraph so it's pretty illegible and no one is gonna waste their time reading that much text. Duh.
You need to get HK to straighten up the description or you're gonna be flooded with 'I plugged the TT-25 in on my table and can't hear at all!!??'
jbarchuk is offline Find More Posts by jbarchuk
Old May 14, 2015, 05:02 AM
buzzbingle is offline
Find More Posts by buzzbingle
Joined Jun 2014
Suplementry details
Andrew, if you are going to get full value from HK sales, may I suggest you include details on different ways to install transducers in your fitting instructions. IE for balsa and monocoat, add a small piece foam to the monocoat not touching balsa framing, for best results and any other tips you have found along the way, add to the box, also directions to here and your site.
Just an observation I am sure you have it under controle.
Good luck with everything
buzzbingle is offline Find More Posts by buzzbingle
Old May 14, 2015, 09:32 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
I have been using 1/4" foam plate about 4" round or square secured to the balsa frame and the covering. Should the foam plate not touch the frame? What about a fiberglass cowling?
I agree with these posts. We could use some "suggested installation techniques."
tclaridge is online now Find More Posts by tclaridge
Old May 14, 2015, 09:56 AM
Joined Nov 2005
I went to the Hobby King site and posted some comments and my YouTube videos. Hope it helps.
Old May 14, 2015, 04:06 PM
MrRCFlying is offline
Find More Posts by MrRCFlying
Joined Feb 2012
Thanks guys! I will check into this and see if the wording can be changed.
Andrew
MrRCFlying is offline Find More Posts by MrRCFlying
Site Sponsor
Old May 16, 2015, 12:49 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Here's the F-16 with added base transducer.
F-16 another early morning flight (3 min 10 sec)
urrl is offline Find More Posts by urrl
Sold NIP Eagletree E-logger V4 150A & GPS V4 xzd FPV Equipment (FS/W) 3 Feb 28, 2013 11:19 PM
Sold NIP Eagletree E-logger V4 150A & GPS V4 xzd Aircraft - Electric - Power Systems (FS/W) 2 Feb 28, 2013 01:48 PM
Sold NIP Eagletree E-logger V4 150A & GPS V4 xzd Aircraft - Electric - Power Systems (FS/W) 0 Feb 06, 2013 10:12 PM
Discussion Love Connection host talks assault weapons Fokker Ace Life, The Universe, and Politics 76 Jan 06, 2013 11:09 PM
Whoops! This is why we talk about the weather a lot... Norman Adlam Life, The Universe, and Politics 32 Jan 05, 2013 05:41 PM
