Old Aug 03, 2015, 04:45 PM
Suko is offline
Find More Posts by Suko
Suko's Avatar
United States, WA, Mukilteo
Joined Apr 2013
I bought an apprentice off a guy at a swap meet a month ago. It was a fantastic deal and I got it for my newbie friend to get better on. I fixed it up and gave it no less than a dozen test flights, including loops, rolls, etc without issue. I went out with my friend yesterday for him to give it a whirl and he somehow crashed it 5 minutes into the flight...a total nose-dive into the dirt from 100 ft up. I honestly have no idea how he did it. He has at least a few hours of flight time by now and a plane like this almost takes zero effort to fly.
He claims he did a dive and then lost control. He suspects the ailerons got disconnected. However, I saw the plane right before his crash and the wing was still on top of the fuselage. We had FOUR rubber bands securing the wing, so I really don't think that was the issue.
I suspect he dived and when he pulled up, the wings separated a little from the body. This likely caused the Rx/Gyro to wig out a bit, but instead of being calm and letting it settle down, I think he freaked out and lost control. I guess the "Oh Crap" switch doesn't help much when you forget to use it.
This friend of mine has an interest in flying RC, but with how infrequently he flies and how much trouble he has when he does fly, I'm beginning to think this hobby isn't for him.
Sorry, I realize this is a rant. But I had to rant to some people who care. My wife doesn't understand. She just tells me to find a less stressful hobby. =D
Suko is offline Find More Posts by Suko
Old Aug 03, 2015, 05:17 PM
Neil_M is offline
Find More Posts by Neil_M
Neil_M's Avatar
Joined Feb 2010
So sad poor plane.
Neil_M is offline Find More Posts by Neil_M
Old Aug 03, 2015, 07:38 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Sorry for the crash. In my experience, 4 rubber bands aren't enough on the Apprentice. It can do the lifting thing if you pull too much elevator. You need all 8 if you're using the stock ones.
xmech2k is offline Find More Posts by xmech2k
Old Aug 03, 2015, 08:47 PM
gobigdave is online now
Find More Posts by gobigdave
United States, MA, Scituate
Joined Apr 2007
Definitely want all 8'of the stock bands.
gobigdave is online now Find More Posts by gobigdave
Old Aug 03, 2015, 10:21 PM
Suko is offline
Suko's Avatar
Joined Apr 2013
It's strange then. I've been using 4 this whole time without issue and I felt like I really gave the plane some stress flights before letting my friend fly.
Old Aug 03, 2015, 10:36 PM
iflypby is offline
Find More Posts by iflypby
Watch this!
United States, FL, Port St Lucie
Joined Aug 2014
The original rubber bands that came with my Apprentice were longer than the new issue from Eflite. I use all eight, plus one under the fuselage to help hold the battery door closed. Even then, I get some wing to fuselage flex if I am really cranking her around. I have longer bands that I use for storage to keep the pressure from damaging the wings. The ailerons disconnecting should not cause her to go straight in. She just becomes a rudder aircraft for turns. Maybe the elevator clevis became disconnected? Hopefully, Easy to repair. Maybe some buddy box time to help him get some confidence back.
iflypby is offline Find More Posts by iflypby
Old Aug 04, 2015, 01:20 AM
Suko is offline
Suko's Avatar
Joined Apr 2013
Yeah...that's the thing. I buddy box'd him quite a bit already. An accident of this magnitude should have been well beyond what I thought his current skills where at. Maybe it was a completely legit mechanical failure...but not being the pilot at the controls makes that tough to know for sure. I will probably do wireless buddy box the next time we go out for sure.
Old Aug 04, 2015, 11:25 PM
iflypby is offline
Watch this!
Joined Aug 2014
Suko, where do you fly? I have been flying my Apprentice(and others) at the Arlington Eagles field this summer.
Old Aug 05, 2015, 06:37 PM
Suko is offline
Suko's Avatar
Joined Apr 2013
The instance above was at 60 acres in Redmond. I usually fly at the local middle school or high school when I'm by myself. I don't belong to any of the clubs because most are pretty far away from where I live.
Old Aug 07, 2015, 05:55 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Almost no doubt the crash was caused by using only 4 rubber bands. This is what would have happened......he put it in a dive, it picked up lots of air speed, then when he tries to pull out, the force is too much for the rubber bands, and they stretch, allowing the leading edge of the wing to lift up, and you then lose control. You could get away with mild flight, but pulling out of a big dive is too much. I've had it happen with 8 old rubber bands and recovered, but with only 4, the effect would be severe, and possibly the main wing got quite displaced while loose.
Harrow is offline Find More Posts by Harrow
Old Aug 09, 2015, 09:45 PM
Surgi is offline
Find More Posts by Surgi
Surg on YouTube
Surgi's Avatar
United States, PA, Lancaster
Joined Jul 2014
Enjoying the Apprentice with a different rx, motor, esc , prop and tires. Once you get rid of the safe receiver, the plane takes on a whole new dimension. Awesome plane for sure!
Apprentice S 15e Runcam HD - LCRCC - 8/9/15 (10 min 26 sec)
Surgi is offline Find More Posts by Surgi
Old Aug 09, 2015, 10:00 PM
GLHS592 is online now
Find More Posts by GLHS592
GLHS592's Avatar
United States, TN, Nunnelly
Joined Aug 2012
I've been flying mine converted to taildragger. It changed a plane I was kinda bored with into something much more fun to fly. I bought a Dubro tailwheel assembly and it worked perfect. I hadn't flown this plane in several months before the conversion. Now, I'm taking this plane with me almost every time I fly.
GLHS592 is online now Find More Posts by GLHS592
Old Aug 09, 2015, 10:13 PM
Surgi is offline
Surg on YouTube
Surgi's Avatar
Joined Jul 2014
I didn't realize how great of a plane it really is. I know I'll also be taking it with me every time I head to the field now. I think I viewed your pics on the conversion. Looks like a lot of work? (I am one lazy you know what haha)
Old Aug 23, 2015, 05:30 PM
FR4-Pilot is offline
Find More Posts by FR4-Pilot
Long Live Flybar !
FR4-Pilot's Avatar
United States, IL, Lombard
Joined May 2009
Nice Video Surgi! I like the view from the tail - I might have to try that Nice long flight times wit this plane & battery combo.
I had a good flight a couple weeks ago -two Mobius camera went for a ride that day. Actually it was a bunch of flights, all on one battery. This one was the shortest:
Two Camera Views (3 min 26 sec)
FR4-Pilot is offline Find More Posts by FR4-Pilot
Old Mar 14, 2016, 03:17 PM
marair23 is offline
Find More Posts by marair23
Joined Aug 2012
Does any one know the receiver range of this plane? And where on the tail was your camera mounted Surgi?
marair23 is offline Find More Posts by marair23
Discussion Pitts Model 12 15e ARF by E-flite I got one!! helifann Parkflyers 7 Nov 19, 2008 10:23 PM
New Product Wrong area Get Real Beginner Training Area (Aircraft-Electric) 0 May 16, 2008 05:27 AM
Sold SOLD Blade CP RTF Electric Micro Heli by E-flite Lakepilot Aircraft - Electric - Helis (FS/W) 3 Nov 26, 2007 05:40 PM
For Sale E-Sky King V1 hopped up, RTF w/ Spektrum Radio zero9046 Aircraft - Electric - Helis (FS/W) 0 May 16, 2007 12:34 AM
Odyssey EP by E-Flite for a beginner flyer? Bellavance Beginner Training Area (Aircraft-Electric) 0 Oct 09, 2001 07:23 PM
