Old Oct 20, 2004, 12:11 PM
igorkv
igorkv
Guest
n/a Posts
Looking for guy with name Clive about Hitec 645MG fix
Hi,
If you are Clive who wrote the fillowing on 2001-09-06:
"I have been using a Hitec 645MG high torque but not fast servo on my
1/8 car. I found it interfere with the other servo which is standard
servo, if I try to move stick. However, I move the other stick there
is not any problem at all. I guessed that because the 645MG interfere
with receiver cause the problem. So, I disassemble the Hitec servo and
add a small capacitor across the servo motor and add a capacitor on
the power wire inside the servo. And also, I add a capacitor to a
receiver power wire that would give the receiver a regular power
against the peak power required by servo start to move and stop. After
all jobs done, all problems are solved. That is my experience."
can you send please the characteristics of the capacitirs and some kind of schema?
I have the same problem with my car.
Thanks in advance,
Igor
Question Looking for the thread with the guy building a CF fan _Pattern_Man Electric Ducted Fan Jet Talk 2 Jul 13, 2006 07:04 AM
looking for a hoot with flaps? How about a Mini Graphite with flaps.... soholingo Aircraft - Electric - Airplanes (FS/W) 14 Aug 16, 2004 09:30 PM
looking for parkflyer with ailerons... alien Parkflyers 6 Apr 29, 2003 05:21 PM
Looking for help with placement of aileron servos... DavidHyams Modeling Science 3 Aug 23, 2002 06:21 AM
Looking for transmitter with model memory (5+ models, futaba or hitec) jocappy Aircraft - Electric - Airplanes (FS/W) 8 Jun 12, 2002 09:26 PM
