Old Dec 21, 2013, 06:06 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
New Product
64mm Change Sun 12 blade
Another member stumbled across this. found here.
http://www.rcgroups.com/forums/showthread.php?t=2059432
Was just wondering if any others have gotten this and done any testing.
May be a great alternative to the heavy dps units.
D_FAST is offline Find More Posts by D_FAST
Old Dec 21, 2013, 07:37 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I'll bet, motors that once worked in the HET and mini-pro 70mm fans, will work in this. Less load than the CS 10 70mm.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old May 28, 2014, 08:36 PM
Jacksmobile is offline
Find More Posts by Jacksmobile
United States, FL, Port St Lucie
Joined Aug 2004
Ok guys I have personally put this fan that I first purchased on Banggood.com was fan and motor they at that time had a 3s and a 4s I'll post some videos of my F-18 with this fan in it the 3 cell is in a concept X and flies nice not a speed Demon but the sound is intoxicating the thrust numbers were 3s 540g at 29 amps and the 4s was 720g at 32 amps these thrust numbers were done on a test stand with the front ring on the fan it's amazing the difference w/ and wo the fan inlet ring now the numbers do drop in the frame but it makes up for it in the air
Jacksmobile is offline Find More Posts by Jacksmobile
Old May 28, 2014, 08:40 PM
Joined Aug 2004
By the way if you go to banggood.com I posted on how to finish the balancing. And yes they needed balancing I'll try to get that post and bring it here it's really easy if you know the principle the iphone has a vibration app that I down loaded to verify my balancing I always balance my fans to one cell higher than where I run it at for durability
Old May 28, 2014, 08:43 PM
Joined Aug 2004
http://www.banggood.com/RC-Model-12-...-p-912235.html
Old May 28, 2014, 08:44 PM
Joined Aug 2004
Ok I purchased 4 of these and they are an excellent fan to have in jet the sound is incredible having said that I had to finish balancing it even thought they come pre balanced I had to complete the balancing myself on each and every fan I purchased the best way to know if it's not completely balanced is to first draw a line from one blade to the center of the center cap mounting screw this way you know the position of the cap now remove the cap and stick a 3/16 strip of 1/2 in wide electrical tape to the inside of the cap exactly 180 degrees to the small dab of epoxy weight the manufacture put in there to balance the fan originally and place the cap back on to the fan in original position and run it up and if it sounds better and feels better ( less vibration) if it does then the balancing process has been improved so now loosen the cap just enough to be able to rotate the center cap one way or the other an 1/8 of an inch from the line you originally drew and tighten and retest you will know when the fan has found its happy place a balanced fan is a happy fan not to mention the motor will last longer repeat the process till it's vibration free now if adding the tape makes it worst then move the tape over the epoxy if it's better you'll need to ad a bit more epoxy to theirs please sand the epoxy in the cap before adding a bit more once dry retest the balance till your satisfied I balance all my fans to 1 cell higher than where I run them don't run the 4s fan too long on 5 s or you could burn out the motor I generally spool it up to full speed and back to off 2-4 seconds enough to get a reading on my iphone app
Old May 28, 2014, 08:46 PM
Joined Aug 2004
http://x-flight.com.hk/index.php?p=6&id=251&lang=en
Old May 28, 2014, 08:48 PM
Joined Aug 2004
29.00 and the motor looks like an improved one or updated
That's where I would purchase from I have purchased from this site many times and all the orders were correct every time
Old May 28, 2014, 09:11 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
how about an amp eating 900W 2.6 lb thrust
hit 1000 with a thrust tube @90% and lip
Change Sun 64mm 12 Blade EDF (1 min 41 sec)
Old May 28, 2014, 09:44 PM
Joined Aug 2004
Here are a few pics Name: F-18.jpg
Description: Airfield 64mm F-18 w 64mm change sun fan 4s
Name: 12 blade change sun fan 64mm.jpg
Description: 4s 1800 mah. Battery
Name: 64mm Concept X with 3s.jpg
Description: Business end of the 64mm change sun fan 3s
Name: 64mm change sun 12 blade fan.jpg
Description: These needed balancing even though they mention  pre balanced  I always balance my fans to one cell count higher than what I run it at .
Old May 28, 2014, 09:48 PM
Joined Aug 2004
There's an iphone App that will help u determine if the balance is better or not it's called VR Mobile once u open the app use the accelerometer it's very flexible I rubber band the iphone against the outside of the fan before I spool it up and read the vibration numbers
Old May 28, 2014, 09:55 PM
Joined Aug 2004
Here's a link to the F -18 in action I split the video in two 1st the take off and 2nd the fly bys
Airfield F-18 64mm change sun fan 4s 1800 mah 40c battery a must 2 minute flights tops (0 min 29 sec)
Old May 28, 2014, 09:57 PM
Joined Aug 2004
Check out this 2nd video fly by and sound is incredible !!!
Fly By (2) Airfield F-18 64mm change sun fan 4s 1800 mah 40c battery a must 2 minute flights tops (0 min 34 sec)
Old May 29, 2014, 01:25 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
64mm works really well with the CS12 rotor, I started cutting them down soon as the 70mm came out. Nice to see they have done an actual 64mm rotor now, will save me a lot of time! What's the actual inside diameter of the housing?
Extreme_RC is offline Find More Posts by Extreme_RC
Old May 29, 2014, 05:43 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
thats the kicker. its only a 20.5mm motor hub.
its why i went with a dons wicked standoff.
The NTM line the end bell comes factory balanced.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 64mm 12blade unit w/3200kv - 3s JGuilty13 Foamy EDFs 672 Mar 17, 2016 08:12 AM
Discussion Change Sun 12 blade 120mm scatsob Electric Ducted Fan Jet Talk 1050 Sep 13, 2015 07:12 AM
Sold New Change sun 90mm 12 blade fan with hk 1400kv motor maccdaddy Aircraft - Electric - Jets (FS/W) 0 Oct 05, 2013 11:12 PM
Sold (2) New Change Sun 90mm 12 Bladed Shrouds $35 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Dec 29, 2011 08:02 PM
