Old Oct 25, 2009, 11:56 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Hyperion 1913/1919 question
I'm about to get a new motor for my Easy Star, and have set my mind on a Hyperion. I have been looking at the 1913-06 / 1913-08 and at the 1919-04 / 1919-06. I do not need a fast plane, but at plane with a good climb rate and some power to lift my camera.
The 1913-06 seems to be for fast planes and the 1913-08 seems to be for medium fast plane. For my purpose, should I choose the 1913-06 or should the 1913-08 be better ? I will use the 6x4E prop.
I have also been looking at the 1919 serie, which have more power. Again there is a fast-motor and a medium-fast-motor. Not sure what to choose.
Link to data about Hyperion 19x
SpookiePower is offline Find More Posts by SpookiePower
Old Oct 26, 2009, 07:28 AM
Giz is offline
Giz
Find More Posts by Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
It depends on what your battery is. 2 cell lipo? 3 cell lipo? NiMH?
On the Easy Star you are limited by prop diameter so on a 2s lipo I would go for the P1913-06 and on a 3 cell I would go for the P1913-08. Both with the largest diameter prop I could fit.
If I wanted lots of power I would use the P1913-06 with 3s.
Giz is offline Find More Posts by Giz
Old Oct 26, 2009, 08:12 AM
Joined Jun 2009
I'm a bit confused now, sorry.
Does the 1913-06 has more power with a 3s, than the 1913-08 would do, also with a 3s ?
I'm not sure if I'm going to use 2s or 3s.
Old Oct 26, 2009, 09:08 AM
Giz is offline
Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
Yes, the 1913-06 will draw more current with the same prop than the 1913-08. Take a look at the prop data for the 1913-06 and the 1913-08. It shows lots of things for 2s and 3s batteries with different props.
Check the power you get with say a APC 400 EP 5.5x4.5 which is about the biggest prop you can use:
1913-06 on 2s = 64.4 watts
1913-06 on 3s = 194.3 watts
1913-08 on 2s = not shown - prop too small
1913-08 on 3s = 99.75 watts
Old Oct 26, 2009, 09:49 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
For the Easy Star, any motor with a kV between 2000 and 2200 and able to handle 20 amps continuously will haul that camera just fine on a 3s Li-Po and an APC 6x4E prop.
It's the motor of choice for a majority of Easy Star owners looking to upgrade their planes and/or haul cameras.
I personally use an E-Flite Six Series 2000 kV on 3s and the APC 6x4E, but there's nothing special about the E-Flite motor.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 26, 2009, 01:10 PM
Joined Jun 2009
Ok, now I start to see how things works together.
There is really a big difference between the power with a 2s or 3s.
Old Oct 26, 2009, 01:13 PM
Joined Jun 2009
I can see that with a 3s, 6x4E and the 1913-06 that the current is 17.8 amps. I'm planning to get a 30A ESC, but would it be enough with a 20A ECS - or have does 17.8 amps nothing to do with the size of the ESC ?
Old Oct 26, 2009, 01:31 PM
Giz is offline
Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
It's always best to have a good bit of headroom with the ESC rating over the actual current drawn. In your case, I would go for the 30 amp and that will be safer now and more useful to you in the future.
Old Oct 27, 2009, 07:23 AM
Joined Jun 2009
If I compare the 1913-06(186watt/17.8amps) with the 1919-04(233watt/21.8amps) - still using a 6x4E prop.
I get a lot more power for not that much money.
Would it still be safe to use a 30amp ESC, with the 1919-04 (21.8amps) ?
and is there a big different between a 1919-04 and 1913-06, mounted on a Easy Star ?
Old Oct 27, 2009, 08:33 AM
Giz is offline
Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
Yes.
The 1919 is a longer motor but it is still a smaller diameter and shorter length than the original speed 400. That should make it easy to mount in a plate glued to the back of the existing motor bulge without the outrunner rubbing on the sides. It should be a nice installation.
233 watts in a Easy Star is a lot! I used to run mine at 180 watts and it got very squirrelly at full power. I would choose the 1919-04 on 3s but maybe prop down a bit. I got very good results with an APC 5.7 x 3 ".049" prop on the original Speed 400. That would give something like 175 watts on this motor but without too much pitch speed.
Old Oct 27, 2009, 08:47 AM
Joined Jun 2009
I'm not going to fly full speed when flying horizontal, I need the power to get a good climb rate, when I have my camera mounted. Would it be possibly to go vertical with 180 watt or with 233 watt ?
Do you know how much watt the original Permax 400/V6 6s NiMH give ?
Old Oct 27, 2009, 09:07 AM
Giz is offline
Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
Just about!
About 50 watts. A bit more on 7 cells. But they are only about 50% efficient so not much gets to the prop. Your outrunner will probably be 70+% efficient.
Question Hyperion 606 charging question kwt99 Batteries and Chargers 3 Sep 07, 2009 10:54 AM
Discussion Hyperion Titan 80A Question.. adamkerrnz Power Systems 2 Jun 12, 2008 06:47 AM
Discussion Need Help with Hyperion 1913-06 SHAFT guyg Electric Motor Design and Construction 0 Aug 11, 2007 02:47 AM
Question Hyperion EOS5i charger question Mike_Then Batteries and Chargers 2 Jul 26, 2007 08:25 PM
Discussion hyperion e-meter Question FASTALJR Electric Plane Talk 2 Aug 07, 2006 09:47 PM
