Old Nov 20, 2014, 10:43 PM
Joined Sep 2014
My first P-51 Mustang!!! My first scratch build!!
I think it came out pretty good!!
Rain1dog is offline Find More Posts by Rain1dog
Old Nov 20, 2014, 10:44 PM
Joined Sep 2014
Not to bad!!
Old Nov 20, 2014, 11:00 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
very nice.
cmdl is online now Find More Posts by cmdl
Old Nov 20, 2014, 11:05 PM
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Good job , you should post it in the " Foamies - scratchbuilt " forum !
When's the maiden flight ? If possible , shoot a video !
Al
balsa or carbon is online now Find More Posts by balsa or carbon
Old Nov 21, 2014, 08:14 AM
Joined May 2012
Nice! Just picked up the materials for a 36" span P-51, balsa build with a foam core wing.
Yet another scratch build from plans although I am using a different airfoil than what is on the plans, using NACA 00 series airfoils.
Sibe is offline Find More Posts by Sibe
Old Nov 21, 2014, 11:23 AM
Joined Sep 2014
Anyone have any suggestions on getting the t28 motor to mount to a firewall? I got that plastic piece which the motor mounts to from the 28 but when I line it up to the firewall it's bigger and screw holes don't line up. Also it seems if I mount the motor directly to firewall there is a piece on the motor that spins, on the backside. Is that every motor? Keep in mind this is my first time doing this.
I'm about to take pictures of firewall.
Old Nov 21, 2014, 11:26 AM
Joined Sep 2014
That's the piece I'm trying to mount the motor to.
If I'm leaving out any information let me know.
I was thinking of gluing that plastic housing to the wood then just have the motor mount like it normally would. I just get nervous during high G turns and suck that the bond will sheer apart mid flight.
Old Nov 21, 2014, 11:30 AM
AMA#1032179
Somethin' Extra's Avatar
United States, MN, Fairmont
Joined May 2013
is the piece that spins like a ring or collar connected to the shaft? if so, that is normal. if i were you, i would put a piece of plywood behind the foam firewall, glue it in place, then use woodscrews to attach the motor mount to the plywood. the woodscrews should go through the foam firewall, like to clamp it.
Somethin' Extra is online now Find More Posts by Somethin' Extra
Old Nov 21, 2014, 11:33 AM
AMA#1032179
Joined May 2013
use M3 screws to attach the motor to motor mount, woodscrews to mount the motor mount to the firewall.
Old Nov 21, 2014, 11:45 AM
Joined Sep 2014
Here is a picture...
See that black cylinder shaped piece on the back? It spins.
Old Nov 21, 2014, 11:48 AM
AMA#1032179
Joined May 2013
yep. supposed to spin.
Old Nov 21, 2014, 12:01 PM
Joined Sep 2014
Yeah...
I need to find a metal housing that will attack to that firewall that will allow for that shaft to spin.
The plastic housing stock from the 28 is a tad bigger in diameter than that wood firewall. That's my problem I'm trying to solve.
The hobby shops here don't carry motors so I got to order them which I don't want to do and wait another week...
They sell motor mounts, I just have to go d the correct measurements from the parkzone t/8 1400 mm motor to get proper motor mount.
I can't wait to fly this thing. From the videos I've seen this plane fly's like a dream for a bigger like me!
Old Nov 21, 2014, 02:21 PM
Joined Sep 2014
I have two hobby shops within 20 miles of me... And they carry nothing.. Grrr.
I need to find a way to mount this motor. Even shaving the plastic one to fit.
Old Nov 21, 2014, 02:39 PM
Joined Sep 2014
And the A-10 is one fam sexy plane.
Old Nov 21, 2014, 09:02 PM
United States, WA, Woodinville
Joined May 2014
As long as the part with the wires and the part that attaches to the plane doesn't spin it's all good.
James_S is offline Find More Posts by James_S
Build Log Vickers FB5 "Gunbus" My First Scratch Build hammerd Scale Kit/Scratch Built 58 Dec 14, 2014 06:10 PM
Build Log My first large scale scratch build Shadow-D Scale Kit/Scratch Built 20 Nov 20, 2014 09:29 AM
Discussion Looking for a balsa build P-51 Mustang kit dmtuska_co Fuel Warbirds 6 Oct 14, 2014 10:07 PM
Discussion P-51 Mustang Park Flyer Maiden - Scratch build BennettOZ84 Foamies (Scratchbuilt) 2 Jul 29, 2010 11:54 AM
Yippee! Newbie first steps into foamie scratch building... RCM P-51 Mustang. iam Foamies (Kits) 25 Apr 26, 2004 06:42 PM
