This thread is privately moderated by skunkworks2006, who may elect to delete unwanted replies.
Old Oct 12, 2012, 08:15 PM
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
Originally Posted by rclab1 View Post
bah7566
What was the tally/total price you spent to make that foam board FPV plane? That is a tough one to answer but if you were to add up materials, glue and tape it's probably no more than about $20.00 in the airframe. I have way more time in it than cash. I used 5 sheets of Dollar Tree foam board that cost $1 each, some colored packing tape from tapebrothers.com, hot glue, gorilla glue and colored duct tape from Walmart.
Looks soo stable!
just a few questions if you have the answers since you just maiden'd it!
1. flight times (Lipos used? 3s or 4s?) I'm using 3300mah 4s / estimated flight times around 20 minutes
2. cruise amps I don't know for sure as I have no OSD onboard but I would guess about 10 to 15 amps and 35 amps at full throttle
3. Where did you get the foam boards? The foam board is from Dollar Tree store $1 each 20"x30" 5 sheets for this build
4. CoG? Best CG should be from 20 to 25%, mine is at about 24%. After the first flight I am going to adjust it to 20% and see how it does. Optimum for this airplane may be at 23%. That's percentage of the wing chord. My chord is 9.5 inches and my starting CG is 2.25" from the leading edge.
I like these types of planes, the tractor style with prop behind camera is great!
....plus tractor is more powerful and effecient.
I like your plane and its similar to this plane coming out.... Thank you!
http://onedrone.com/store/index.php?...&product_id=71
That's a neat looking airplane but mine is not as pretty. Mine is also just a little cheaper to make. I got most of my ideas and building techniques from Ed at experimental airlines on Youtube. Here is a link to his page. He has mastered economical foam board building and has a gold mine in build videos and information posted for all of us to use. He couldn't be a nicer guy and he is very generous sharing his ideas. He is a true asset to this hobby.
Experimental Airlines on Youtube http://www.youtube.com/my_subscripti...cSWVA0OC4_B7dI
Colored packing tape http://www.tapebrothers.com/Default.asp
Dollar Tree foam board http://www.dollartree.com/arts-craft...6450/index.pro
Get creative, get building and share your ideas with us.
Bruce
bah7566 is offline Find More Posts by bah7566
Old Oct 19, 2012, 12:05 PM
Finland
Joined Mar 2011
My good night FPV plane.
Weight: 1,5kg
Wingspan:1,4m
Battery:2200mAh 3s
Motor: turnigy 200w
Esc 18A
Video tx: 2,4Ghz 100mw, with coverleaf
Hobbyking Osd
rchemmo is offline Find More Posts by rchemmo
Old Oct 20, 2012, 04:32 PM
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
yesterday I lost my plane , today prepped new FPV wing
camera/tilt survived hard landings :
new FPV SkyFun (2 min 15 sec)
sf f20 (0 min 47 sec)
fmkit is offline Find More Posts by fmkit
Old Oct 22, 2012, 01:22 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by chanyote66 View Post
Especially if it uses the same crap as the hubsan spyhawk... or what ever that thing was... Looks like the same Remote/Screen stuff
A friend of mine was going to write a review on that plane... could not get anything to work right or fly right- I think he might have turned it down until they could improve the product...
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Oct 22, 2012, 02:53 PM
Aviation industry participant
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Nice! Really like how you're thinking outside the box. One question if you don't mind, what type of cable have you used for the video connection? Looks like a USB cable.
Sub.
subsonic is offline Find More Posts by subsonic
Old Oct 22, 2012, 03:42 PM
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
thanks! I used microphone cable, picked at industrial junkyard.
more info about this type of wing
Old Oct 22, 2012, 06:02 PM
United States, NE, Lincoln
Joined May 2010
Not fully FPV but with HoryzonHD camera mounted on tail, this was a mix from Experimental Airlines Photon design and a Polaris Tail for the camera. Unfortunately it only lasted one flight. Im not sure if the CG was off or it was the 15-20Mph winds that spun the airplane to the ground.
LNKATC is offline Find More Posts by LNKATC
Old Oct 22, 2012, 09:03 PM
DJO
Dream on!
DJO's Avatar
United States, CT
Joined Oct 2011
Here's my FPV build, it's working very well so far great flight times 20 minutes + full throttle, over 25 when just cruising around. Just embedded the electronics and took off as much weight as I could from the airframe, so now it should be a little bit more efficient. Just need a microSD card for the keychain cam and then I'll get some video. For now, all I have is the video from 2.4 GHz 10mw.
PopWing FPV Compilation I :: First Exposure (4 min 10 sec)
https://sites.google.com/site/djopro.../thefpvproject
Dan
DJO is offline Find More Posts by DJO
Old Oct 22, 2012, 09:24 PM
Joined Aug 2010
Here is my late Mini Pulse XT complete with eagletree OSD/GPS/Return to Home. Unfortunately one day I flew too low, lost video signal, and she went into the drink. R.I.P
2nd fpv (2 min 24 sec)
FPV 2nd flight (crash landing) - Montara Beach, California (5 min 38 sec)
rancidsquirrel is offline Find More Posts by rancidsquirrel
Old Oct 23, 2012, 12:31 AM
Every day Im FPV'n
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Sorry for your loss... One question though, why do you have an inverter from your car to get 120v AC and then convert it back to low voltage for your Video RX Most Video RX's are already running on 12v... Just another piece of equipment that can fail. I try to use the KISS method and use as little equipment as possible.
I figured you use the inverter for the laptop as well though.
chanyote66 is offline Find More Posts by chanyote66
Old Oct 23, 2012, 09:26 AM
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Agreed.
Use the inverter for the laptop and you just need 12v direct for the receiver.
Shadrack is offline Find More Posts by Shadrack
Old Oct 23, 2012, 01:17 PM
purplys's Avatar
Greece, West Greece, Aigio
Joined Sep 2011
My first Skywalker
purplys is offline Find More Posts by purplys
Old Oct 24, 2012, 10:17 PM
Joined Aug 2010
Originally Posted by Shadrack View Post
Agreed.
Thanks chanyote66,
It was because I'm lazy and the netbook also ran off the inverter.
I'll probably be putting FPV on a Sniper Pushy Cat in the future for some fast-paced flying.
Old Oct 26, 2012, 11:52 AM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Does anyone have a High effeciency Home built aircraft? Im looking for probably a tractor style, Inrunner powered, minimal body.... Im wanting to exceed 1+ hours of flight without going above 2x 2650mah 4s batteries...
My latest wing may get close but I wanted to see what others have done...
Old Oct 26, 2012, 02:55 PM
DJO
Dream on!
DJO's Avatar
United States, CT
Joined Oct 2011
Just get a glider! Set up a Radian with a 2200 mah 3S and you'll be flying forever!
Dan
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 54 Apr 18, 2011 09:31 AM
Gallery Show us your plane! (Part 2) skunkworks2006 Video Piloting (FPV/RPV) 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove Video Piloting (FPV/RPV) 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
