Old Jul 01, 2014, 10:30 PM
George Jure
Hamilton, Ontario
Joined Aug 2005
Question
Old Radio System with New Main battery
Hello
I have a PT boat which is setup with a Futaba 4 ch. 75mhz FM radio system. The boat also has an OLD Dumas servo operated mechanical speed control. It has dual brushed motors, dumas and I would like to replace the speed control for ONE electronic speed control for both motors and I would like to use a Lipo battery 7.4v 2C to power the boat.
My questions are:
1) Can I run a lipo battery with this old radio technology safely?
2) What strong ESC can I buy that will handle both brushed motors and work off of a Lipo battery?
Any wiring with fuse protection diagrams would also be appreciated.
Thanks for your help.
George
George Jure is offline Find More Posts by George Jure
Old Jul 01, 2014, 11:25 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
George,
1) yes
2) how much do you want to spend?
that might sound a bit lame, but we really need to know more about the boat and motors. what size is the boat, what size are the motors, and what size are the props.
tsenecal is offline Find More Posts by tsenecal
Old Jul 02, 2014, 05:25 AM
Bradford West Yorkshire, UK
Joined Apr 2010
Try these people George :- http://www.action-electronics.co.uk/ , whatever you want to control, there's likely to be a diagram for it.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Jul 02, 2014, 11:21 PM
George Jure
Hamilton, Ontario
Joined Aug 2005
Originally Posted by tsenecal View Post
George,
1) yes
Hi
Thanks for the reply. The PT boat is a Lindberg PT109 1/32 with a Dumas running package in it with the OLD mechanical speed control. As for prop size, from my tape measure, it looks like 1 1/4" dia. two bladed plastic WHICH for sure has to be changed to brass 3 bladed props. I want to still use the Radio gear and brushed motors. So I need a Speed control that will work with Lipo and what 3 bladed props to use.
George
Old Jul 03, 2014, 03:27 AM
Blackpool, Lancs
Joined Feb 2006
Test with a meter to figure out the current draw, double that, use the next available higher rating to get an ESC from a non-oriental source. If going oriental, move the decimal point in their claim one or two places left. Any ESC will be quite happy with LiPo, but it might need a low voltage warning device added, since LiPo do react badly to over discharge.
mfr02 is offline Find More Posts by mfr02
Old Jul 03, 2014, 04:30 PM
George Jure
Hamilton, Ontario
Joined Aug 2005
Hi, Thank You mfr02 for the tips. Good lessons for the ESC and the lipo.
George
Any idea what size of 3 bladed brass props I should use for the PT boat?
Old Jul 03, 2014, 06:04 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
for that boat i would recommend a pair of 30mm 3 bladed props, maybe even a pair of 27mm. the props you have now are 32mm. i buy my brass props from http://cornwallmodelboats.co.uk , you will have to verify what size shaft you have, and buy accordingly. I assume since everything else is Dumas, your propshaft is probably not metric.
to be honest, i don't have a recommendation for a brushed ESC. the last model i bought was in 2005, and it was a mtroniks. don't know about their current models.
i did find this one at hobbyking, but i don't think it has a high enough amperage to run both motors. it is probably cutting close
http://www.hobbyking.com/hobbyking/s...Search=brushed
Old Jul 04, 2014, 11:09 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
The ESC Tsenecal linked to is used widely in scale boats and gets good reviews.
Two 500 size motors may be on the edge, but you could put a small fan on top (like the similar sized car ESC's) or add watercooling by adapting the heatsink to accept a piece of square aluminum or brass tubing with nipples glued/soldered onto it.
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Sold JR XP652 Radio system, New in the box, Servos, batteries, receiver RSTEARMAN Aircraft - General - Radio Equipment (FS/W) 1 Apr 28, 2014 03:58 PM
Sold New-in-Box JR X9503 Mode 2 Heli Radio System with R921X Receiver - No Servo MTDV Aircraft - General - Radio Equipment (FS/W) 4 Feb 14, 2014 10:49 AM
Discussion Old Airtronics servos totally dead in new FlySky system pcrussell50 Radios 6 Oct 21, 2013 04:57 PM
Discussion Old plane with old batteries or new plane with new lipo? yamabiker Electric Plane Talk 33 Jan 03, 2011 07:05 PM
Sold Futaba used Radio System (Skysport 6A) with servos and new batteries striker24 Aircraft - General - Radio Equipment (FS/W) 0 Nov 02, 2010 02:21 PM
