Old Feb 28, 2014, 06:29 PM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
Contest
Scale Build-Off 3 51" span Ilyushin Il-4
Well its been a long time since I rolled my own so here is my entry in the contest an Ilyushin Il-4. The Il-4 was a variant of the earlier DB-3 long range medium bomber by the same company. This variant first flew around 1940 and was used as a long range bomber, torpedo bombing and mine laying. they were used until the end of WW2. My version will be around 1300mm span and made of Balsa and foam.
- Luke -
Au_Arbiter is offline Find More Posts by Au_Arbiter
Old Feb 28, 2014, 07:26 PM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Welcome aboard, Luke! Looks like a unique subject; kind of like the offspring of a DC-3 and a Japanese Betty...
Steve
Steve85 is offline Find More Posts by Steve85
Old Mar 01, 2014, 12:32 AM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Nice! You don't see that one every day at the field.
Paul
Longhorne is online now Find More Posts by Longhorne
Old Mar 01, 2014, 02:12 AM
Soarbird's Avatar
Johannesburg SA
Joined May 2004
Nice to see another WW2 twin being built.
Subscribed
Soarbird is offline Find More Posts by Soarbird
Old Mar 01, 2014, 09:21 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Click!
Colonel Blink is online now Find More Posts by Colonel Blink
Old Mar 02, 2014, 03:49 AM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
Started construction on the fuselage, I'm using a balsa centre structure which is clad in foam blocks then carved and sanded to shape.
Old Mar 02, 2014, 12:39 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
There's an Ilyushin in there somewhere.
Hopefully it's not just an illusion.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Mar 02, 2014, 01:16 PM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Larry
Groan!. You didn't really just make a pun that bad did you?
Jeff
jhspring is offline Find More Posts by jhspring
Old Mar 02, 2014, 03:10 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Jeff
There ain't nobody else here.
Larry
Old Mar 02, 2014, 04:19 PM
Joined Nov 2008
Jeff
Thanks Jeff...............I hadn't noticed until you pointed it out! Talk about dense
Old Mar 10, 2014, 03:17 AM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
Hi all, Just a few pics of my progress. Thought I would do the molds for vac-forming, its part of my day job, so I must be very motivated to do it. I started with a 6.4mm frame which is then filled in with more balsa and carved to shape. They are all .5"/12.7mm taller so they can be adjusted to shape. The final step is to coat the whole thing in epoxy resin and sand when cured. I will be double vaccing to get a real good result, needed given the Ilyushin's large amount of glazing. The final pic shows the turret mold in place, its about 2"/50mm in diameter.
Old Apr 12, 2014, 09:33 PM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
Well life got in the way for a bit but now I can do some more so here is a wing. the frame is very basic with only 4 ribs total, a l/e section and 2 spars all made from 5mm balsa and skinned with 3mm depron. Its a pretty quick way to make a hollow smooth skinned wing that's quite resistant to torsional flexing. Tons of space inside to because of the scale thickness. It looks quite large with the fuselage on it but there are still the nose and tail cones to be added.
Luke
Old Apr 12, 2014, 11:12 PM
Steve85's Avatar
Joined Mar 2004
Good to see you back on the case, Luke!
Steve
Old May 03, 2014, 11:55 PM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
More glacial progress! got around to making and installing control surfaces on the Il-4. I made these again with balsa spars with 3mm depron skins wrapped around them. Since the surfaces are a bit far from the fuselage I decided to use internal horns. The elevators are joined with a piece of carbon rod with a plywood horn. The rudder is different in that it has a piece of brass tube slid onto piano wire that turns the Rudder and tail wheel (the picture is much clearer). All the surfaces are hinged with mylar hinges.
- Luke -
Old May 06, 2014, 05:21 AM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
Got a bit more done. I made the nacelles out of 3mm ply and 10mm sq for the retract bearers. All these parts are bonded to the spar and l/e section with epoxy. The nacelles are going to be clad the same way as the fuselage was. The Ilyushin shape is slowly coming out.
- Luke -
Build Log Scale Build-Off 3 - 41" span P39 Airacobra Colonel Blink Scale Kit/Scratch Built 657 Jan 22, 2015 03:47 PM
Build Log Scale Build-Off 3 - 57" span Northrop Grumman X-47B Rocketman1092 Scratchbuilt EDFs 382 Sep 25, 2014 05:08 AM
Build Log Scale Build-Off 3 - 48" span Beriev be-103 nickchud Scale Kit/Scratch Built 53 May 18, 2014 06:25 PM
Build Log Scale Build-Off 3 - 62" span Lancaster nickchud Scale Kit/Scratch Built 107 May 11, 2014 09:43 PM
Build Log Scale Build-Off 3 - 20.5" span Benoist Model XIV glider90 Scratchbuilt Indoor and Micro Models 10 Jan 09, 2014 05:04 PM
