Old Dec 15, 2013, 09:26 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
VQ Kawasaki Hien
http://www.hobbypeople.net/index.php...ry-hatch.html#
Kawasaki HIEN (TONY) 46 EP-GP (with battery hatch)
46 Size Scale Almost-Ready-To-Fly All-Wood Airframe R/C Airplane
Unique, Intimidating.
The Kawasaki Ki-61 Hien was a mystery to the Allied forces. It's reported that the first pilots who saw it thought it was a Japanese version of an ME-109. Later reports said it was Italian designed and won the nick-name “Tony”. However, the Ki-61 was a unique Japanese design. Historically it's a beautiful and unique design. As a model aircraft, the Ki-61 is a fast, clean, high-performance warbird that looks great and flies even better.
Build it stock with the included fixed-gear and you'll have a great looking Japanese warbird with a scale color scheme. Add the custom VQ electric retracts and add to the performance and speed. Either way you'll have it in the air quick and flying great because VQ uses advanced jigs and laser cutting to build a beautiful and straight airframe.
You can power it your way too. This VQ ARF is compatible with glow engine two and four strokes and standard electric motor power systems including the HP-Motors G-46 power system.
Fly something unique, the Kawasaki Ki-61 Hein, only from VQ ARFs
Features:
• Pilot, Painted and Installed
• Factory Laser Cut, Jig-Built, All Wood Construction
• Factory Covered and Finished
• Fiberglass Cowling
• Fixed Gear Included, (Optional Retractable Landing Gear Available, Sold Separately VQARE04)
• Compatible with Glow and Electric Power System
• Complete Hardware Package
Specifications
• Wingspan: 1540mm – 61.62in
• Wing Area: 13.18sq.dm - 595sq.in.
• Wing Loading: 82.7/dm.sq. - 27.1oz/sq.in. (Will Vary with Equipment Used)
• Length: 1120mm - 44in
• RTF Minimum Weight: 3.17Kg - 7lbs (Will Vary with Equipment Used)
• Radio: 5-6 channels - 5 (4 if EP) standard servos
• Engine: 46 Two Stroke, 70 Four Stroke (Sold Separately)
• Motor: G-46 HP Motor, 5 cell 4500mAh, 13x8 propeller (Sold Separately)
• Functions: Ailerons/Elevator/Rudder/Throttle/Optional Retractable Landing Gear
Recommended Items
• 5-6 Channel Minimum Radio. 5 Channels is required for optional retract gear.
• (This airplane features separate aileron servos)
• Airtronics Aquila 6 is Recommended.
• 5 Standard Servos for Glow, 4 Standard Servos for Electric. We recommend Airtronics 94835 Servos. If using a 5 channel radio, Y-harnesses will be required.
Power:
• Four Stroke: Magnum 70 RFS (with 13x6 Propeller) or:
• Two Stroke: Magnum 46XLS (with 10x6 Propeller) or:
• Electric: HP-MTR G-91 Power System (Motor, ESC, and Battery) and 13x8 propeller.
TripleW is offline Find More Posts by TripleW
Old Aug 05, 2014, 11:28 AM
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Is this the same plane that HK is now selling? Sure does look like it...
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Kman
kman24 is offline Find More Posts by kman24
Old Aug 05, 2014, 02:10 PM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
Yes same plane
Mikemynameis is offline Find More Posts by Mikemynameis
Old Aug 05, 2014, 02:33 PM
yank and bank!!
Joined May 2013
Wish someone would make a 800mm version in foam.
failboat is offline Find More Posts by failboat
Old Aug 05, 2014, 03:41 PM
kman24's Avatar
Joined Jan 2010
Originally Posted by Mikemynameis View Post
Yes same plane
Thanks, I was pretty sure it was
Looks like a decent model and they have it in the HK USA warehouse. I am seriously thinking about picking this one up and electrifying it this winter
Kman
Old Aug 05, 2014, 03:43 PM
kman24's Avatar
Joined Jan 2010
FYI - I reached out to HobbyPeople and they no longer carry this plane. They told me it is no longer available. So, does that make the planes that HK has the last ones If so, then these may not last very long.
Kman
Old Aug 05, 2014, 03:44 PM
kman24's Avatar
Joined Jan 2010
Any foam version would be great
Kman
Old Aug 07, 2014, 08:33 PM
kman24's Avatar
Joined Jan 2010
Couldn't resist the price on this one and decided to pull the trigger. Should get it next week sometime
Need to finish up my Phoenix Tucano, which I am getting close to finishing.
Kman
Old Aug 12, 2014, 10:50 PM
kman24's Avatar
Joined Jan 2010
My Tony arrived! Looks like a great model Now to start parts shopping for bits to go on the inside.
Kman
Old Aug 12, 2014, 11:05 PM
hyperknight's Avatar
Irvine, CA
Joined Apr 2003
Kman
I was looking at the same kit. VQWarbirds has them as well.
http://www.vqwarbirds.com/product_in...b126e1c31acdd2
I wanted to get the Kyosho version but can't find it so was looking at the VQ one.
hk
hyperknight is offline Find More Posts by hyperknight
Old Aug 12, 2014, 11:27 PM
kman24's Avatar
Joined Jan 2010
HK is selling them a bit cheaper, but shipping is another factor depending where you live.
I am sure the Kyosho is more scale, but this VQ Model version is hard to beat for the price. I love the color scheme on this model. It really sticks out from all the other models that are out there.
Kman
Old Aug 13, 2014, 12:45 AM
I'm not lost, they are
pullup!'s Avatar
Co.
Joined Jan 2005
I'm about 75% done with mine, got some time off so I'm not going to hurry it.
I did move the E/R servos aft under the cockpit so I can move the battery back further for CG.
My buddies Yak 9 (VQ) was veeeery nose heavy with the recomended battery and servo placement.
I'll post some pics tomorrow of my progress.
pullup! is offline Find More Posts by pullup!
Old Aug 13, 2014, 09:49 AM
kman24's Avatar
Joined Jan 2010
pullup - did your buddy just add some weight to the tail or did he move things around as well?
Kman
Old Aug 13, 2014, 12:47 PM
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I am building the Yak-9, and will just move things around to get a good CG. Planning on 4s with G-46 motor. I bought retracts to suit. Hoping these will be nice models. ------Metalguy
metalguy is online now Find More Posts by metalguy
Old Aug 13, 2014, 01:25 PM
kman24's Avatar
Joined Jan 2010
Sounds great! I am planning on building mine for 4s, as well. What size battery are you sticking in yours?
Kman
Het-RC Kawasaki Hien Ki61 Build questions Spadkun Electric Warbirds 67 Jun 15, 2011 02:22 AM
Build Log VQ kawasaki Hien "Tony" Robert Stinson Glow to Electric Conversions 43 Aug 26, 2008 02:25 PM
New Product VQ Kawasaki Hien Tommy D Electric Warbirds 0 Nov 06, 2007 10:53 AM
Kawasaki ki-61 Hien Helge Sondresen Scale Kit/Scratch Built 11 Jan 15, 2006 05:37 PM
Latest News: Flying Styro Japanese Army AF Kawasaki Ki-61 Hien (Tony) shschon Parkflyers 1 Sep 26, 2005 09:50 PM
