Old Jan 18, 2016, 12:15 PM
Jasen40 is offline
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
Have you considered a CPS canopy? They more durable than the cpx version. They made from similar plastic as the xtreme cpx canopy.
Jasen40 is offline Find More Posts by Jasen40
Old Jan 18, 2016, 12:27 PM
CraigHB is offline
Find More Posts by CraigHB
crash tested
CraigHB's Avatar
United States, NV, Reno
Joined Dec 2014
I've been using BL Heli Protos style canopies. They look really nice and they're really tough;
http://blheliparts.weebly.com/store/c4/Ncpx.html
The unpainted ones are super cheap if you don't mind doing it yourself.
CraigHB is offline Find More Posts by CraigHB
Old Jan 18, 2016, 12:48 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Ooh, I like those, CraigHB. I'll have to look into those some more.
@Jasen40, I've thought about that, but I'm going to pick up a CPS for my son soon and don't want to confuse Dad's helis with the ones he's flying.
I might also look at the Skyartec wasp CP canopies to see if I could mod one of those to fit.
But since I already have the Xtreme yellow and want a spare, I'm going to see if I can exhaust my options on that first.
RoboHeli is offline Find More Posts by RoboHeli
Old Jan 18, 2016, 01:28 PM
Jasen40 is offline
Joined Jun 2012
Also nine eagles solo pro canopies work with small bit of modding.
Old Jan 18, 2016, 01:53 PM
farquward is offline
Find More Posts by farquward
Today is a good day to fly
farquward's Avatar
United States, CA
Joined Sep 2014
Thanks for the link Craig, really like that Goblin style.
farquward is offline Find More Posts by farquward
Old Jan 24, 2016, 11:09 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Friend sent me a Micro heli figreglass canopy made for Nano. fit perfect and much stronger then stock. they are expensive to say the least. I need to make a list for HH. Some new 150 ma 45 C batteries/ servo for Nano.
I have couple good flying Mcp-x's in need of new motors. They work great indoors and shame to waste them.
dankar04 is offline Find More Posts by dankar04
Old Jan 24, 2016, 11:29 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I just got five new ones in the mail from HH. Still about the best batt for this copter, imho.
tracknoob is offline Find More Posts by tracknoob
Old Jan 25, 2016, 08:55 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I tried a few other brands but no more. E-flite 150 ma 45 C for me.
Old Jan 31, 2016, 03:17 PM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
Throttle hold button
My DX4e throttle hold button is acting up, sometimes requiring 3-5 pressed before registering. It seems as if gets worse when in idle up, which would point to the actual heli being the problem! I really hope its the simpler "its the button" thing. Has anyone changed the button to a switch? Or could I fix the button somehow?
sandos is offline Find More Posts by sandos
Old Jan 31, 2016, 04:08 PM
BababooeyHTJ is offline
Find More Posts by BababooeyHTJ
Joined Jan 2016
How many cycles do you figure that you actually get from these cells before you start seeing a noticeable drop off in performance?
BababooeyHTJ is offline Find More Posts by BababooeyHTJ
Old Jan 31, 2016, 04:17 PM
bvrrocks5150 is offline
Find More Posts by bvrrocks5150
bvrrocks5150's Avatar
United States, OK, Oklahoma City
Joined Jul 2014
It's definitely the button.....
I had similar problem with having to mash down hard on the button to get bind. It was annoying. When I started using my DX4e on a CX450SE-V3 with Kbar FBL, I replaced the button with a toggle switch so I could use that channel for a mode switch. It seems to work better for me when binding..... less finger work.
Its not difficult if you can use a soldering iron. The switch is a bit of a trick to remove and replace due to the tight fit in the corner, just be careful.
I also did the mod moving the Aux switch to the other side of the Tx. You have to re-route the wire for the Aux switch so it will reach the other side... if you choose to do that mod.
(These mods saved me from having to buy a new 6-channel Tx. Kbar setup software has ability to assign channels from Tx.)
bvrrocks5150 is offline Find More Posts by bvrrocks5150
Old Jan 31, 2016, 09:51 PM
eggma is offline
Find More Posts by eggma
eggma's Avatar
Canada, ON, Markham
Joined Mar 2013
Yea, my DX4e had the same problem very early in its life. Then I only use the it for Phoenix flight sim, and after 2 years, the tail rudder control is messed up too.
I've been using my Devo7e ever since the DX4e bind button failed. The devo7e is a good controller, the gimbals are a little sloppy though, but it's a superior given its low price. And it controls many many different brands of helis after flashing the firmware and install deviation. Definitely beats the DX4e by far.
eggma is offline Find More Posts by eggma
Old Feb 01, 2016, 12:28 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Flew my #2 bl Nano CP-X for first time in several weeks. Flew fine. #1 needs new elevator servo. I'll clean old one on removal as back up.
Real windy out and get some indoor flying.
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6113 Jan 15, 2016 02:20 AM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 09:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
