Old Jan 03, 2015, 10:01 AM
joeflier's Avatar
United States, MI, Plymouth
Joined Jan 2005
If you don't already have the hardware you might want to pick up one of these:
http://www3.towerhobbies.com/cgi-bin...&I=LXD859&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXEWS3&P=7
joeflier is offline Find More Posts by joeflier
Old Jan 03, 2015, 10:16 AM
Joined Jun 2009
Thank you very much. You have been of great help
Regards
Xavk
xavk is offline Find More Posts by xavk
Old Jan 03, 2015, 05:13 PM
Joined Jun 2009
Hi again
Do I need reverse y harnesses to set up the flaps, rudders and the aileron?
Old Jan 13, 2015, 07:15 AM
Joined Dec 2013
Are all Falcon 120 the same manufacturer? I am looking at this one
Coopznz is offline Find More Posts by Coopznz
Old Jan 13, 2015, 07:55 PM
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
I am guessing that the answer is yes but I do not know that for sure. I do know that there are a few different versions. The first generation of the Falcon 120's had sheet balsa leading edges up to the spar and the rest of the wing had an open structure covered with plastic film. They also had one bolt on each side of the boom holding the horizontal stab too the boom. The second generation of the Falcon 120 had fully sheeted wings covered with plastic film. They also had two bolts on each boom holding the stab to the boom. IMHO, both of the Falcon 120's had a problem with poor glue joints and the formers in the fuse were not glued in very well. My first and second generation Falcon 120's all had problems with bad glue joints or lack of glue. The other weak link on the first and second generation Falcon's was the motor mount area was very weak and had a tendency to break if not reinforced.
The latest version of the plane is available here: http://www.rcjetsworld.com/index.php...s/turbine-jets
I have had two of the Navy Cats CF (this is the better built Falcon 120 with a lot of carbon fiber reinforcement in it). The Super Falcon V3 is pretty good. Here is a thread on the Navy Cat: http://www.rcgroups.com/forums/showthread.php?t=2095652
xavk:
Did you ever get an answer to your question?
Ed
A10pilot is offline Find More Posts by A10pilot
Old Jan 14, 2015, 08:23 AM
Joined Dec 2013
Thanks for that, I have just ordered a Jet Joe 1400 so are looking for an airframe for it
Old Jan 14, 2015, 09:01 AM
toolmaker49's Avatar
Lockport NY
Joined Jan 2010
Hopefully you ordered it from Andy @ CRX Turbines as he disassembles them fits, adjusts, and test runs so you get a reliable turbine. He also provide warranty service .
toolmaker49 is online now Find More Posts by toolmaker49
Old Jan 15, 2015, 12:42 AM
Joined Dec 2013
no direct from Jet Joe
Old Jan 15, 2015, 06:18 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
JetJoes are a lot different now to what they were in the past and plenty of help on the Jetjoe forums if there is any issues
xairflyer is online now Find More Posts by xairflyer
Old Jan 15, 2015, 12:04 PM
USA, NY, East Aurora
Joined Jul 2006
It doesn' t really matter where you order from but if/when service needed, I would recommend using a local rep. Cost of shipping to/from China is a lot more than in US and takes longer.
Andy
afioretti is offline Find More Posts by afioretti
Old Jan 17, 2015, 03:59 AM
Joined Dec 2013
Andy
Im not in the US, I am in Australia
Old Jan 18, 2015, 12:27 AM
Joined Jul 2006
I thought you might be from Australia..
Good luck with your plane.
Andy
Discussion EVF and Falcon 120 jentres Electric Ducted Fan Jet Talk 28 Jul 18, 2011 08:57 PM
Discussion Power source for Falcon (BobCat clone) 120 preston_brown Fuel Plane Talk 2 Jun 19, 2008 10:47 PM
